Re: Cherry Pi III Is Available June 15, 2015 07:43AM |
Dejay
Thanks for the answer! I didn't realize you used Vslot wheels on normal extrusions. I've decided to just order some mini V wheels plus some V slot extrusions for the verticals only.
Re: Cherry Pi III Is Available June 15, 2015 07:52AM |
vreihen
Andy is using Bosch/Rexroth 2020 T-slot extrusions, IIRC. The mini-V wheels ride inside the beveled edges of the slots, although not as nicely as they do in the proper V-slot extrusion.
As a caution, the mini-V wheels do NOT work that great in the slots of Misumi 2020 extrusions, as Misumi cuts their slots with more square edges and the wheel barely gets a bite in the slot.....
Re: Cherry Pi III Is Available June 15, 2015 09:39AM |
Re: Cherry Pi III Is Available June 15, 2015 10:16AM |
Dejay
I wish motedis would sell fitting delrin wheels for their aluminium profiles. It's a great shop with very fair prices in Europe!
Hmm I think we need is kind of an "inverse kickstarter". Customers request / pledge for certain items to be manufactured and companies can bid to make them!
Re: Cherry Pi III Is Available June 15, 2015 11:10AM |
David J
Interesting - I haven't tried slic3r yet with this printer, as I normally get quicker prints from Cura. Worth a try, as it won't cost me anything!
Re: Cherry Pi III Is Available June 15, 2015 06:09PM |
Re: Cherry Pi III Is Available June 15, 2015 09:57PM |
Re: Cherry Pi III Is Available June 16, 2015 07:09AM |
Re: Cherry Pi III Is Available June 16, 2015 06:19PM |
dougal1957
ooznest do the Delrin Openbuilds mini V-Wheels and ship out same day if in stock they also do V Slot extrusion at a fair price (Tho not as cheap as Motedis)
Re: Cherry Pi III Is Available June 17, 2015 02:59AM |
Dejay
dougal1957
Oh thank you! I saw ooznest before on ebay but never checked out their online store where they are much cheaper than on ebay. About ~20% markup compared to openbuilds incl vat. 43.39 € for 9 mini v wheels including shipping. Well still expensive but YOBO right? (you only build once)
Re: Cherry Pi III Is Available June 17, 2015 06:27AM |
Re: Cherry Pi III Is Available June 17, 2015 06:32AM |
Re: Cherry Pi III Is Available June 17, 2015 08:57AM |
Matt,Wheatley
Doug,
Do you have a picture of your carriages using the 4 v-wheels, you have peeked my interest.
Matt
Re: Cherry Pi III Is Available June 17, 2015 05:40PM |
Re: Cherry Pi III Is Available June 17, 2015 06:55PM |
Re: Cherry Pi III Is Available June 17, 2015 07:15PM |
Re: Cherry Pi III Is Available June 18, 2015 03:05AM |
vreihen
His carriages (like Andy's CP-III ones) look an awful lot like the OpenBuilds mini-V plate that these wheels were originally intended for:
http://openbuildspartstore.com/mini-v-wheel-plate/
I'm not a huge fan of this design in general, as the OpenBuilds plate and eccentrics will not provide me with enough adjustment range to take all of the slop out of the wheels on their V-slot extrusions.
FWIW, Andy's CP-IIIs rod holders fit just about perfectly on the OpenBuilds mini-V plates.....
Re: Cherry Pi III Is Available June 18, 2015 08:09AM |
dougal1957
The reason I didn't use them is the hole pattern on them (For mounting the Rod Carrier's) was not quite right (I could have got them to fit but would only of used 2 holes and ofset from the joint centres which I didn't want) hence I took the openbuild design and extended the height by 10 mm and put my own bolt pattern in for the carriers.
I find that there is plenty of adjustment in them for the Openbuilds V-Slot rails which is after all what they are designed for.
Re: Cherry Pi III Is Available June 18, 2015 08:23AM |
vreihen
dougal1957
You can see in the picture above what I wound up doing. I drilled two holes from the back, and used a pair of low-profile SHCS to attach the plate. (The screws are also black, and coincidentally wound up with the tips being flush with the printed rod mount if you look inside the belt holder and the dimple in the big open space.)
When I ordered the set from OpenBuilds (1.5 years ago), they recommended two eccentrics and two standoffs for the four wheels. When I crank the eccentrics all the way in, I am *barely* getting a play-free carriage on their V-slot. Maybe they adjusted the plate or are recommending 4 eccentrics now, but the parts that I received were marginally usable. Plus, I don't think that they ever considered the off-center carriage shift of a few millimeters when using the eccentrics. I'm still planning to use them on my spin of the HotBot2 (as pictured), but will probably replace them with a new design as soon as I can use it to print ABS without warping.....
Re: Cherry Pi III Is Available June 18, 2015 02:35PM |
Re: Cherry Pi III Is Available June 18, 2015 05:55PM |
itaysp
I'm starting my build now, and I want to use all the 220mm of the MK3 round aluminium heated bed.
What is the calculation I need to do in order to know the length or the rods I need to cover all this area?
I'm using 10mm balls and not 8mm.
In the BOM at thingierse, Andy says that the build area is about 190x190 mm, and he cut to rods to 225mm.
Also, I want to get 300mm build height, 650mm extrusion will be enough with the longer new rods?
I know I can cut 270mm rods and use 700mm extrusion and it probably fit my needs, but arms longer than I need will reduce the printable height, and I want my printer to be as small as possible.
Thanks!
Re: Cherry Pi III Is Available June 18, 2015 07:39PM |
Re: Cherry Pi III Is Available June 19, 2015 03:30AM |
Re: Cherry Pi III Is Available June 19, 2015 03:55AM |
itaysp
I did some calculation for 220mm printable diameter, but I didn't know if i'm correct.
After you said you are using 350mm arms for 300mm printable diameter I think they might be right
Arms length: 269.76mm
Degrees between arms and tower: 36.31
lost height: 217.36mm
This is the length of the arms when they are at the end of the 220mm bed, and the arms are 90 degrees with the tower, which I don't think is good.
Adding 9% to the arms will give me:
Arms length: 294mm
Degrees between arms and tower: 32.91
Lost height: 236.92
For 300mm printable diameter my calculation gave 337mm rods, so I did the right calculations.
Thank you!
Re: Cherry Pi III Is Available June 19, 2015 04:06AM |
Re: Cherry Pi III Is Available June 19, 2015 07:43PM |
Re: Cherry Pi III Is Available June 19, 2015 07:53PM |
Re: Cherry Pi III Is Available June 20, 2015 02:13AM |
Matt,Wheatley
Hi All,
I have just put a duet controller into my Cherry Pi and I am having a strange issue. If I move the motors, everything moves okay but once the motor stops at the correct place it is still making a noise for 10+ seconds after. If I hit the emergency stop the noise stops. I have taken a video of it here:-
[drive.google.com]
Anybody know what I have done wrong?
I have the motor ratings in the config.g file set to 1700, which is what the stepper motors are supposedly rated for, but setting this at 1000 doesn't appear to make a difference to the noise after move.
Thanks
Matt
Edit:
Reading around about stepper motors and I think I understand. The noise when the motor is not moving is because you have to keep the stepper energised to stop in moving. I never heard this on the ramps, but I guess the voltage to hold the motor was different in the drivers I had on the ramps.
Re: Cherry Pi III Is Available June 20, 2015 12:04PM |
Re: Cherry Pi III Is Available June 20, 2015 01:37PM |
