Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 29, 2015 11:11AM |
Deguello
I wonder if a 16 gauge stainless steel disc would work under glass?Quote
thevisad
Aluminum has a .2 inductive profile...
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 29, 2015 12:55PM |
thevisad
Deguello
thevisad
This shows .4 for the aluminum and it is definitely not that. I have to be 2 MM away to detect it, I tried copper and it matches the aluminum profile. According to this chrome/nickle would be the best. I can test some stainless that I have to see if it will trigger it like the chrome. All my sensors trigger at roughly the same location, whether they are 4mm or 12mm detection. There is another sensor that is inductive prox that works on anything in its field. I am looking for that one, but I am moving over to FSR sensors as they will detect when the tip touches the bed.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 29, 2015 02:38PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 29, 2015 02:49PM |
llamatrails
Instead of an inductive proximity sensor, look at the capacitive ones. US$ 13.50 for a 25mm sensing distance, [tinyurl.com]
Rick
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 29, 2015 03:59PM |
bluesmike
Print results not spectacular. I hairsprayed the bed and it started fine. Got a little lifting in one corner and as the job went on lots of boogers from the nozzle. I'll post a pic in a moment.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 29, 2015 10:09PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 29, 2015 10:28PM |
bluesmike
Oh nice! I think my issue now is bed adhesion. I tried hair spray and it did ok, next I tried glue stick, not so great. I'm going to hit Microcenter and pickup some Kapton (sp?) sheets. They actually have it in sheets. I had picked up a spool of ABS, maybe I should have started off with PLA.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 30, 2015 10:10AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 30, 2015 10:16AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 30, 2015 10:19AM |
Deguello
When I complained about this Folger said there was a misprint in the manual and that M3x8 screws would fit. They will, but it's a real pain. Go back to HD...Quote
cman8
m3x10mm cap head screws
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 30, 2015 01:52PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 30, 2015 03:22PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 30, 2015 03:48PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 30, 2015 04:40PM |
tadawson
I kinda gathered that, but Folger shipped *ZERO* M3x10 hardware with my kit. . . .and the 8mm have almost no extra length in the T nuts.
- Tim
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 30, 2015 06:05PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 30, 2015 06:13PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 30, 2015 06:37PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 30, 2015 09:18PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 01, 2015 12:57AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 01, 2015 01:17AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 01, 2015 02:19AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 01, 2015 03:36AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 01, 2015 08:36AM |
coshtor
Djkingsleyn what are you using for wire management on your extrusions, that looks very clean.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 01, 2015 07:39PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 01, 2015 07:57PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 02, 2015 03:09AM |
bluesmike
stops printing?! Im trying to print a small file. I had one successful print today. After that I tried one job from the SD card and it started but the LCD dimmed out, the fan slowed and it hung never to print the job. The bed and hotend did get up to temp. I thought maybe it was the LCD/SD causing the issue so I disconnected it. So I plugged the USB back in and tried again. Three jobs got to various points and just hung. I double checked all my connections and tried again. The next job went to 96% and stopped. I just tried again and it got to 54% and stopped. It just stops (never in the same spot) and the USB drops the connection from the laptop. I have to shutdown the printer, disconnect the USB and fire it backup before it will allow the laptop to reconnect. Thoughts?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 02, 2015 09:08AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 02, 2015 01:48PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 03, 2015 02:11AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 04, 2015 10:11AM |
