Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 01, 2015 11:58AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 01, 2015 01:07PM |
Koenig
cman8
For those that replaced your steppers, do you have to reconfigure the fw and recompile? Or is it just plug n play? I bought these as suggested. Will they work better?
[www.ebay.com]
Since they are 1.8 degree they should be just "plug'n play", you will have to change the vref on the drivers though.
And from experience I can say that you might have to change the cabling over, manufacturers seems to have no real standard to this even if they use the same connector on the motors.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 01, 2015 02:24PM |
cman8
Koenig
cman8
[www.ebay.com]
Vref higher or lower?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 01, 2015 06:48PM |
Koenig
cman8
Koenig
cman8
[www.ebay.com]
Higher, but how high depends on the rating of the motors and the drivers.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 01, 2015 09:42PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 02, 2015 01:02AM |
KDan
I wasn't reviewing your part, my comment was directed towards that style of brace. Sorry you took it personal.
The fact is, that style has been around for a long time, but is usually one solid piece for each vertex. (not two mirrored, unconnected parts at each vertex)
Your comments about the design implied that it was untested - "should add some rigidity to the machine".
I was offering my direct experience with something very similar which didn't substantially improve the ridigity of the machine - at least not to the level I was hoping for.
The design was never uploaded to thingiverse or anywhere else that I know of.
[attachment 61314 EarlyBraces.jpg]
If your smaller brace stiffens up the frame better than these do, then I offer you a congratulations.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 02, 2015 02:07AM |
cman8
Koenig
cman8
Koenig
cman8
[www.ebay.com]
Total newb on this here so if possible can anyone lecture me. How high do i know I can go on the motors? Also how high can the stock steppers can go for the kossel?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 02, 2015 02:18AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 02, 2015 02:45AM |
Check the "#define DEFAULT_AXIS_STEPS_PER_UNIT" in configuration.h + did you properly install all the jumpers beneath the driver for the Z-axis?Quote
djtrance2
I've now finished most of the building stage. I'm looking for more information on the next steps as my testing doesn't feel right, I've set the potentiometers to give the right Voltage as described in the manual (0.35, 0.35, 0.35, 0.55):
1- when I do prepare--> move axis-->x and move by 1mm, it seems the x-motor moves by 1mm. However, when I move the z-motor by 1mm, it moves by about 10cm. Also, which direction is +1mm, should the rail go up or down?
Autohome brings all the carriages to the top touching the limitswitch, that is the homeposition for deltas, at max height.Quote
djtrance2
2- I'm not sure how the auto-home is supposed to work. What is position 0 on each axis? is it when the rail is at the top position, touching the limit switch? or is it when the extruder is at the bottom, and the distance sensor shows 0?
Now I don't have have an inductive sensor, but isn't there three wires?Quote
djtrance2
3- also, the inductive sensor seems to be giving 3.33V between the red and black wires no matter how close the sensor is to the board.
I suppose you already have installed the arduino IDE, to be able to flash the firmware, so you should have the necessary drivers.Quote
djtrance2
4- when I insert the SD Card with an STL file, I don't see the STL file in on the LCD screen. How would I print using my computer instead?
djtrance2
Is there a guide for troubleshooting?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 02, 2015 10:54AM |
Koenig
One for +
One for - (ground)
And one for the signal.
Meaning that between two wires you will always have same readings
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 02, 2015 02:45PM |
Koenig
cman8
Koenig
cman8
Koenig
cman8
[www.ebay.com]
That page you linked to doesn't say anything on how much current the motors can take, what they are rated for, so I cannot give you any help on that.
Regarding the original motors and drivers tadawson made a post earlier in this thread about a suitable vref.
This is a good page to read regarding the matter: [reprap.org]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 02, 2015 07:43PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 02, 2015 07:53PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 02, 2015 07:56PM |
cman8
Whats your setting n pronterface? is the Baud rate set high enough? Do you have the right com port? Also can you read the board on audrino when loading the FW files?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 02, 2015 08:31PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 02, 2015 08:35PM |
cman8
Im assuming you could upload the marlin Config files to the board
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 02, 2015 09:12PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 02, 2015 09:38PM |
nebbian
Did you put the stepper motor drivers in the correct orientation? Have you measured the adjustable current sense voltage on them?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 02, 2015 10:08PM |
fattmann
If the correct orientation is with the potentiometer facing towards the AUX4 pins, that is, away from the power block, then yes.
As per the screenshot of the spreadsheet I posted, I have dialed in 0.35v for the X, Y, and Z stepper drivers, and 0.60v for the Extruder stepper driver. Is that what you mean by the "adjustable current sense voltage"?
fattmann
nebbian
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 02, 2015 10:28PM |
nebbian
fattmann
Ah fair enough. Yep that's what I mean.
It's a strange problem that you've got. The normal culprit is a mismatched baud rate, but it seems as if you have communication with your arduino board becuase the heater is heating up and you can see the end stops trigger. So what's left is power to your motors.
Things I'd check:
1) Do you have power to BOTH sets of 12V leads on the RAMPS board? From memory there is one set for heaters, and one set for motors.
2) Can your carriages move up and down by hand, which is turning the motors?
3) Have you selected "Delta" in the marlin firmware?
4) Have you put jumpers on the x-min and y-min end stop pins so that in normal operation, every signal pin is connected to ground?
5) Do your motors buzz or make any sound when you try to drive them?
6) How are you trying to drive your motors? Have you pressed the "Home" button in pronterface after connecting?
7) When you connect pronterface to your delta, does it come up with some text in the console?
I'm not sure what your problem is but this might help to narrow it down.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 02, 2015 10:34PM |
thevisad
fattmann
nebbian
That is the correct voltage, what you are describing indicates that voltage is not getting to the motors. This could be an issue with the stepper drivers, the arduino, the RAMPS, the wiring or the power supply. The picture below shows the position of the stepper driver for an 4988, an 8825 is reversed and the adjustable pot is in the opposite direction, pay attention to where the reset button is. I am going to assume that it is not your RAMPS or Mega since you have multiple of those. The second picture shows you the orientation of the wiring and the color code it should follow, check that your wiring is properly connected and in the correct order.
In the last picture, with the power on the printer use a voltmeter to test the spots. Yellow is your ground connection, red is your 3.3-5v connection and the green is your 12v power. You should have these voltages at these locations while the printer is on. Also check to make sure that your jumpers are on and in the right place for the stepper motors to be in 16 step mode. There is a set of 3 of these under each stepper motor driver.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 02, 2015 10:55PM |
fattmann
I am looking for help.
After a month, three Arduino boards and two RAMPS, I still cannot get the printer to fire any of the motors. I made this troubleshooting sheet to try and track down issues. It just HAS to be something simple at this point, I know the hardware is good, but it just won't do anything.
The only thing not filled out on that sheet is the heat bed and hotend voltages, I currently have them unhooked but they were working just fine a few days ago.
When sending either G28 or G29, nothing happens. It will say "SENDING:G##" then hang indefinitely until you do something else.
The GUI controls in Pronterface don't do anything when pressed. Nothing in the console, nothing on the GUI.
Any suggestion is appreciated. I'm freaking out at this point.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 02, 2015 11:18PM |
fattmann
thevisad
fattmann
nebbian
I certainly agree with the hypothesis that the motors are not getting voltages. I tested the leads going to the extruder motor, while having a helper press to extrude 5mm of filament- no voltage, no movement.
My stepper drivers are oriented as you have shown. My voltages at the Yellow/Red is 4.76v, and at the Green/Red is 12.29v. All of the jumpers are in the correct place matching the build manual, and the picture you provided. This includes the jumper near the reset button.
I should also add that trying to manually control it with the LCD screen and knob will show echo lines on the console, but still doesn't activate anything.
Thanks again.
fattmann
4) I have seen the the use of "Zmin" but not "Xmin or Ymin." I was under the impression that there is only the endstops at the top of the rails? Sorry I'm not sure on that question.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 03, 2015 01:22AM |
fattmann
thevisad
fattmann
nebbian
Thanks again.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 03, 2015 10:52AM |
Koenig
Could yo perhaps post a photo of your ramps with everything connected?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 03, 2015 01:29PM |
fattmann
Koenig
Not the best picture, took them real quick on the way out of the house to work this morning.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 03, 2015 01:33PM |
Koenig
fattmann
Koenig
Yeah, a bit hard to see, but from what I can see you have not connected power to all four connections on the green block in the lower right corner of the picture.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 03, 2015 02:36PM |
fattmann
Koenig
fattmann
Koenig
I guess it does look like that, sorry I'll get better pictures tonight. Both 12v lines are in the green terminal. I took the voltage readings off the screws in the terminals.
