Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 19, 2016 10:48PM |
xile6
Wait a min
You turn your heatsink fan off?
Thats a no no it should be on when the printer is on. Ran to 12 volts at all times
Next the fan should blow on the fins. You want to push air through them.
Thats probably half of your filament problem.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 19, 2016 10:51PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 19, 2016 10:52PM |
EvilBetty
Without re-wiring it, can I set it to be always on in Arduino / Repetier?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 19, 2016 11:12PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 19, 2016 11:13PM |
paul_delta
If you connected the fan to Pin9 (between hot end and bed wires) - Repetier may turn it on/off depending on hot end temperature.
Check my firmware configuration [forums.reprap.org]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 20, 2016 12:35AM |
dc42
Getting the nozzle height above the bed at z=0 right is critical for first layer adhesion. If in doubt, heat up the bed, put the nozzle at x=100 y=100, then lower the nozzle until it grips a piece of standard 80gsm paper against the bed not too loosely. Then do G92 Z0, then print.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 20, 2016 03:26AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 20, 2016 03:35AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 22, 2016 01:06PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 22, 2016 01:23PM |
tovrin
Hi, my first post here, I am about to purchase this Kossel from Folgers and the original posts on this thread from 2014 make it clear shipping times were beyond necessary. is this still the case? part of the appeal is an American vendor so i don't have to wait for China delivery times. any other reviews or websites of American vendors for a Kossel?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 22, 2016 02:48PM |
tovrin
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 23, 2016 12:12AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 25, 2016 02:08PM |
EvilBetty
Still having some problems with filament leaking in strands during preheat, usually curling up into the side of the nozzle. Any suggestions for dealing with that? Was happening even at 205c,
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 25, 2016 04:16PM |
09zx-6r
has any one had issues with the nozzle temp not stabilizing... ill set it to 210 and it floats from 203 to 215... iv done the auto PID tune about 12 times and made no difference...
also, with the effector homed (top), nozzle ON, bed ON, it says endstops hit Y.... thoughts???
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 25, 2016 07:19PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 25, 2016 08:46PM |
MarkM92
I'm trying the Z-Leveling video (https://www.youtube.com/watch?v=L9URtv2LqKc) but my printer will not accept the M99 commands. Any suggestions?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 26, 2016 01:19AM |
paul_delta
Use Repetier firmware. This video explains Repetier-related procedures....
MarkM92
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 26, 2016 02:42AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 26, 2016 04:58AM |
EvilBetty
I lied. Actually still using Marlin.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 26, 2016 05:04AM |
faithblinded
paul_delta
Try to load this Repetier firmware [forums.reprap.org]
It's pre-configured for FT Kossel.
I tried using that one yesterday, and again just now. It won't compile for me. Here is the error I get in arduino when I try to verify it:
sketch\libraries\twi.c:1:17: fatal error: twi.c: No such file or directory
#include
compilation terminated.
exit status 1
Error compiling.
Sorry if I'm missing something simple. It's been a while since I've been so humbled by a piece of equipment. It's maddening.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 26, 2016 08:27AM |
EvilBetty
Paul, have you updated your firmware to 92.8? I just downloaded your 92.6 and am going to try it now.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 26, 2016 08:30AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 27, 2016 11:25PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 28, 2016 09:38AM |
09zx-6r
paul... what do you make of an extruder motor going in reverse for a second and then forward in normal direction for the target length ?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 28, 2016 04:14PM |
09zx-6r
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 28, 2016 09:39PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 29, 2016 06:15AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 29, 2016 07:15AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 29, 2016 08:09AM |
Legrand
I work in a machine shop and just checked it against a gauge. It has an M6 X 1.0 thread.
capacitor
Does anyone know what the thread size is for the push in fitting on the Folgertech stock hotend.
Thanks
Gingerbreadman
Did you proceed with your purchase, and if so how was your experience.?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 29, 2016 08:56AM |
Captain_Tim
Legrand
capacitor
Thanks
By any chance do you know what the push fit thread size is for the fitting for the extruder is? Or are they the same size? I need to replace mine.
Gingerbreadman
