Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 07:09PM |
Captain_Tim
paul_delta
Captain_Tim
vRef is all good, and acceleration is only 100mm. Could it have to do with the arms? As it only happens on at the Z tower, when I'm testing the tower point. It would also appear that when the effector is at X0 Y0, it's not centered and is 6mm closer to the Z Tower.
May be your bed is off-center. Did you perform G131,G132 to get the real center before calibration?
I did not do that. I was unaware I needed to. Will do that now
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 07:12PM |
paul_delta
So, X or Y motor looses steps at extreme position. Try to rise the vRef for them. I have no experience with long diagonal rods, probably stock motors are too weak in this case...
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 07:19PM |
Captain_Tim
paul_delta
It only occurs when I test my Z Tower point which is [X5 Y80]. X Tower [X-69 Y-40] and Y Tower [X69 Y-40] is fine. Also, doing G131 then G132 didn't seem to help. I'll double check my vRefs though.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 07:45PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 09:59PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 10:09PM |
Captain_Tim
Upon testing the vRef, I found that they were low, so I set them up properly again. The problem still persists though. Also, setting up the Z Probe offset, if it's behind the hotend and lined up with the Y tower, what would be put for the offset? So the probe is on the opposite side of the effector than the Y tower
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 01:02AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 01:05AM |
Sven.L
the instruction PDF calls for three jumpers to be put on the RAMPS board. But ... where can I find those three jumpers? Inside which bag were they when you got your printers, people? Any photo available of the package they were in?
In case they are missing of what I got, what kind of jumpers are these (so I can hopefully purchase them somewhere)? Thanks.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 05:27AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 09:35AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 09:56AM |
Sven.L
Thanks, Paul Delta. Is this the case with everyone: that the jumpers were already mounted on the RAMP board when receiving the printer set? Can that be confirmed?
Or are there people who had to mount the jumpers on their own? In this case, where were the jumpers when you received your printer set?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 10:07AM |
Sven.L
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 10:11AM |
spiffcow
So it looks like my problem was the effector arm width. After putting in the new effector and a few iterations for the Escher 3D delta wizard I have 0.2 mm difference across the print bed before Z correction, a near perfect height map, and much cleaner movement. And as an added bonus, I can swap between a probe and a print head in the exact same location, meaning my offset issues are largely mitigated. Unfortunately I also lost ~10mm on my print radius with the smaller effector.. But it's worth it if I actually get good prints.
Now, to actually print something...
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 10:45AM |
paul_delta
Just for information, here is my measurement of standard FT effector and carriage using provided STL files.
The mount with must be 40mm for both - the effector and carriage.
[attachment 71488 FT-Kossel-effector-carriage.jpg]
spiffcow
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 02:18PM |
paul_delta
I've just tested it with 0.92.6 - G28 and then G32 works OK and it takes care about my z-probe
I'll check it later with 92.8.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 02:36PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 02:46PM |
Sven.L
I think, there are really some jumpers missing on my RAMP board, please have a look at my photos and verify that, if I am correct. My apologies for the poor quality of these photos, my mobile phone camera just cannot do better photos at close distance.
While most jumpers are in place, one of the jumpers at the bottom seems to be missing (green circle), and a triple jumper in the callout on the top right connecting the 5V and VCC pins (this is for the auto level servo) seems to be missing, too. Can you verify this?
I purchased these silver-golden interconnected hollow "needles" that I can use as jumper, so the shop keeper (an electronic shop) told me. Is that correct? I mounted a connected pair already where one jumper seems to be missing. Could that work? And should I go ahead and mount a connected triple of them to that "auto level servo" triple jumper slot, too? Or a double (which of the three pins then in that case)?
I need this advise, because I don't want to do anything wrong due unknowledgement. Thanks again.
[attachment 71513 Photo7456.jpg]
[attachment 71514 Photo7457.jpg]
[attachment 71515 Photo7458.jpg]
[attachment 71516 Photo7459.jpg]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 02:50PM |
Sven.L
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 03:50PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 03:54PM |
Sven.L
But the instructions (page 23 of the PDF: the "note") also tell me to mount a jumper for the triple slot of the auto level servo.
[attachment 71524 Photo7460.jpg]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 04:05PM |
Sven.L
Okay, thanks for the good advises and explanations.
As you can see, I now moved the jumper from unnecessary extruder E1 to the missing slot of extruder E0. that should be correct now, right?
But the instructions (page 23 of the PDF: the "note") also tell me to mount a jumper for the triple slot of the auto level servo. Am I correct? The board does not have any jumper installed, nor seems to be there a triple jumper that connects to the pins 1, 2, and 3.
Or must I use a double jumper like for the extruder E0? If so, which of the three pins are to be connected: 1 and 2, or 2 and 3?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 04:20PM |
paul_delta
I've just installed 0.92.8 and yes - it has problems with G32. G30 works perfect - after homing it goes to z-probe height + z-probe bed distance and initiates measurement procedure. But with G32 my probe hits the bed. Going to investigate this issue.
paul_delta
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 04:24PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 04:34PM |
spiffcow
Thanks for checking on it! I'd say hopefully they fix it soon, but honestly I almost hope they don't, as it gives me a reason to start digging into the firmware at a really accessible level..
paul_delta
paul_delta
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 04:37PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 04:59PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 05:30PM |
paul_delta
Yes, it is. I've just changed it to 120 and now it works
#define ZHOME_HEAT_HEIGHT 120
Here is my post on repetier forum regarding this issue:
[forum.repetier.com]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 05:36PM |
spiffcow
Ah.. I guess that makes sense? Honestly I don't see why you would heat the hot end before measuring. Heating the bed would make a lot more since, considering that it's a.) something you can measure with G32, and b.) something likely to expand significantly.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 05:44PM |
paul_delta
spiffcow
It makes sense for hot end nozzle as a probe - for FSR bed leveling.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 02, 2016 05:49PM |
spiffcow
Just now looked FSR probing.. That's pretty cool! Certainly looks like it would solve the probe offset issue and also let you use a different bed surface.
