Re: Ebay SINTRON Kossel Mini full kit October 03, 2015 10:37AM |
DRTak
Tha_Reaper
How did everyone fix/clip/screw his printbed to the structure?
EDIT: And i'm a little confused by the printhead assembly and how its supposed to fit onto the effector. the manual just seems to skip that whole part.
Well I learned a lesson on this topic. I emailed Sintron and they sent me a pic and it is not what everyone else is showing.
[www.dropbox.com]
[www.dropbox.com]
[www.dropbox.com]
I first listened to what they said and I put it in as pictured. And the z probe works. Well I noticed that if you did it the way they said the plate that holds the hotend does not sit flush with the effector plate. So I did what everyone else did and dremel ou the U shaped part. BAD idea. Now the z probe when retracted does not go up high enough and still hits the heat bed. So I reversed the work I did and put it on as the pictures show above even though the surfaces DO not mate very well.
Re: Ebay SINTRON Kossel Mini full kit October 03, 2015 11:03AM |
Re: Ebay SINTRON Kossel Mini full kit October 03, 2015 11:26AM |
Tha_Reaper
found that picture, but mine looks like this: [www.dropbox.com]Quote
nebbian
The hotend just slides into the effector... but you do need to remove some material with a dremel. I think I posted a picture on page 3 or thereabouts.
Its kind of snug without the dremel work. would this also work, or does it needs to sit below that ridge?
And after that? i just use 6 screws to scre it to the effector, attach the fan, and the z-probe?
your bed leveling system sounds nice, but i have trouble picturing where the loctite comes into place... do you have pictures or a schematic?
Re: Ebay SINTRON Kossel Mini full kit October 03, 2015 11:41AM |
DRTak
Thats exactly what I did. I was wondering why Sintron gave us 3 springs. So I made a bed which you can level and it has helped me a lot. I actually had to go to hardware store and buy bigger bolts and bigger springs. Now I can adjust the bed angle to match my hotend. Yes it is a bit tilted and its not related to concave or convex surface. For some reason my hotend likes to slide up the X axis at a 2deg angle evenly? SO I just adjusted my bed to NOT be level to the earth but level to the hotend.
Re: Ebay SINTRON Kossel Mini full kit October 03, 2015 12:00PM |
DRTak
Still calibrating. I changed my DEFAULT_AXIS_STEPS_PER_UNIT back to 80 for x y and z. Re calibrated. Then used the info on that delta printer calibration site and changed my DELTA_DIAGONAL_ROD_LENGTH. So I increased this value of diagn rod which is supposed to decrease the size of the object.
Results. Now my cube is exactly 10mm in height. But the x and y are still 10.5mm in size? So I made a rectangle. Any ideas how to fix this?
Re: Ebay SINTRON Kossel Mini full kit October 03, 2015 03:48PM |
nebbian
DRTak
Sounds to me like your end stops aren't at the same distance from the bed when it's level.
The way to adjust this is:
1) Add a screw to each carriage so that you can adjust the endstop trigger position easily
2) Set your bed to be exactly 90 degrees to all the towers
3) Do the paper test at a position near each tower, and adjust the carriage screws until the Z value of the M114 command is exactly the same when you do the paper test near each tower.
[attachment 63460 2015-10-03_carriage.jpg]
If you continue with your printer set up with a tilted bed, then your parts will also have a 2 degree tilt.
Re: Ebay SINTRON Kossel Mini full kit October 03, 2015 03:49PM |
Koenig
DRTak
Yes, more corrections to the diagonal rods, see this: "Measured Length / Expected Length * DIAGONAL_ROD_LENGTH"
But it is better to print a bigger object to get the correct dimensions, I suggest this object that way you can also see if your towers are at the correct angles.
Re: Ebay SINTRON Kossel Mini full kit October 07, 2015 09:14AM |
o_lampe
@nebbian Sorry for OT, but could you put the sloppy Traxxas joints in cooking water for 10mins. and let them cool down in it?
We used to do that with all plastic parts back in RC-Car days...
I´d like to know, if the slop is gone by the treatment..
THX
-Olaf
Re: Ebay SINTRON Kossel Mini full kit October 08, 2015 03:54AM |
hacker
o_lampe
THX
-Olaf
I ordered two sets and some 5-6 turned out sloppy. Treatment fixed approximately half them.Three are still sloppy.
Re: Ebay SINTRON Kossel Mini full kit October 08, 2015 05:52AM |
o_lampe
hacker
o_lampe
THX
-Olaf
Thanks for the feedback
I must've been lucky, all my Traxxas joints are perfect. But time will tell...
-Olaf
Re: Ebay SINTRON Kossel Mini full kit October 10, 2015 12:04PM |
Re: Ebay SINTRON Kossel Mini full kit October 10, 2015 12:12PM |
Tha_Reaper
I'm having trouble with the z-probe. the probe is so close to the heatsink, that the plastic block that keeps the spring in place is rubbing against the heatsink, blocking movement of the probe.
[www.dropbox.com]
There is another place where i can place the probe, further from the nozzle... seems more inaccurate if i place it there...?
[www.dropbox.com]
Re: Ebay SINTRON Kossel Mini full kit October 10, 2015 12:35PM |
Re: Ebay SINTRON Kossel Mini full kit October 10, 2015 04:40PM |
Tha_Reaper
Just found nebbiqns post on page 3. i'll try that for sure. Thanks!
And i can print. i have a second (crappy) printer. its just not accurate...
Re: Ebay SINTRON Kossel Mini full kit October 11, 2015 05:50PM |
nebbian
It turns out that the heated bed draws more current than the polyfuse can handle. There is an easy fix, just reduce the duty cycle of the bed in the software:
#define MAX_BED_POWER 128 // limits duty cycle to bed; 255=full current
Setting it to half power seems to work just fine, and it easily got to 60 degrees which is perfect for PLA. I'm now printing a part with no lifted corners, whereas the same model yesterday had badly lifted corners with no bed heating.
I'm happy with this solution. Much better than an underpowered bed
Re: Ebay SINTRON Kossel Mini full kit October 12, 2015 05:23PM |
Re: Ebay SINTRON Kossel Mini full kit October 12, 2015 09:45PM |
Re: Ebay SINTRON Kossel Mini full kit October 13, 2015 10:13AM |
Re: Ebay SINTRON Kossel Mini full kit October 15, 2015 08:35PM |
Re: Ebay SINTRON Kossel Mini full kit October 15, 2015 09:06PM |
kingoddball
Does anyone have the arm length and radius for sintron metal + traxxas ends?
Trying to configure a firmware but not at home right now.
arm_length 196.8 # this is the length of an arm from hinge to hinge
arm_radius 101.9 # this is the horizontal distance from hinge to hinge
// Center-to-center distance of the holes in the diagonal push rods. #define DELTA_DIAGONAL_ROD 217.2 // mm (215.0) // Horizontal offset from middle of printer to smooth rod center. #define DELTA_SMOOTH_ROD_OFFSET 161.5 // mm (136.5) // Horizontal offset of the universal joints on the end effector. #define DELTA_EFFECTOR_OFFSET 20 // mm (19.9) // Horizontal offset of the universal joints on the carriages. #define DELTA_CARRIAGE_OFFSET 22.0 // mm (19.5) // Effective horizontal distance bridged by diagonal push rods. #define DELTA_RADIUS (DELTA_SMOOTH_ROD_OFFSET-DELTA_EFFECTOR_OFFSET-DELTA_CARRIAGE_OFFSET)
Re: Ebay SINTRON Kossel Mini full kit October 15, 2015 09:23PM |
Re: Ebay SINTRON Kossel Mini full kit October 15, 2015 09:40PM |
Re: Ebay SINTRON Kossel Mini full kit October 15, 2015 10:49PM |
Re: Ebay SINTRON Kossel Mini full kit October 16, 2015 04:21AM |
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit October 16, 2015 04:23AM |
Re: Ebay SINTRON Kossel Mini full kit October 16, 2015 05:03AM |
Re: Ebay SINTRON Kossel Mini full kit October 16, 2015 07:15AM |
o_lampe
I disagree with nebbians rubberband theory.
When the rubbers tension is unequal, the carriers will be dragged in one direction. As the tension changes, the carriers will be dragged the other way...
You'd get "forced wobble".
What if you use one string/fishing line and a spring instead of three rubbers?
The string would run through rollers and the tension would always be equal for all three carriers.
Just my 2cent
-Olaf
Re: Ebay SINTRON Kossel Mini full kit October 16, 2015 07:31AM |
Re: Ebay SINTRON Kossel Mini full kit October 16, 2015 11:10PM |
Re: Ebay SINTRON Kossel Mini full kit October 17, 2015 04:45AM |
