Re: Ebay SINTRON Kossel Mini full kit February 02, 2016 11:43AM |
I like the design and I've printed mine instance.Quote
Levon
Yesterday night I printed this fish, all is done pretty well, I was even able to separate the links with not much of force applied.
Re: Ebay SINTRON Kossel Mini full kit February 02, 2016 11:54PM |
dc42
DRTak
I have used the roofing tape on the bottom. I also put a layer of kapton tape on the bottom. An additional layer of black electrical tape. This helped. But Im almost thinking I need to use ?cork as well. Im afraid of cardboard. I already had my fire issue with the ramps electronics (thus my upgarde to duet). I dont want to add paper to the bottom of a heatbed.
With the Duet, you can safely increase the power supply voltage to increase the heating power. If you are using a Chinese LED power supply, there will be a potentiometer at one end of the terminal block to adjust the voltage. Try 13V, and if you want more heat then 14V. Don't go above 14V without putting some silicon diodes in series with the fans to drop the voltage back to about 12V. For safety, disconnect the Duet before adjusting the pot.
Re: Ebay SINTRON Kossel Mini full kit February 03, 2016 03:41AM |
Re: Ebay SINTRON Kossel Mini full kit February 03, 2016 05:24AM |
GrAndAG
Levon
[attachment 71496 20160202_191449_crop.jpg]
It's moving absolutely freely (as on video) just after I removed it from the bed. No need cleaning or any force.
Re: Ebay SINTRON Kossel Mini full kit February 04, 2016 03:39PM |
dc42
Btw if you have the electronics under the bed, then you must have cork or similar insulation between them anyway, to prevent the bed heater cooking the electronics.
Re: Ebay SINTRON Kossel Mini full kit February 04, 2016 03:47PM |
DRTak
I have included pictures.
Re: Ebay SINTRON Kossel Mini full kit February 05, 2016 06:19PM |
DRTak
dc42
After my RAMPS fire incident. I no longer put my electronics below. I have it on top now. Rarely do I see people do this. I have included pictures. I like it on top because its easy to fix the wiring and see what is going on. Before, I had to turn the unit upside down and check. Now I dont have that issue. I also like it because all the wiring goes to the top in one location. I also have a particle board "enclosure." This was the easiest idea for me. Before I had a 2' wide x 2' deep x 3' high box. But it was too big and I couldnt fit it in the space I made for the Kossel in the corner of my room. So I made this 1/2 enclosure. It works for warming up the heatbed. And the electronics on top get enough air.
Re: Ebay SINTRON Kossel Mini full kit February 06, 2016 04:37AM |
Levon
Sir_Death
Hi Levon,
I had very similar Problems, when my belts were not tensioned enough.
After some weeks in tensioned condition, they got little bit loose. I gave them more tension and included springs like theese Thingiverse
Position of the springs - directly underneath the carriages
Hehe funny idea, I'll give it a try. And yes I guess they got loose a little bit, might be exactly the reason.
Will let you know that improves the quality.
Thank you!
Re: Ebay SINTRON Kossel Mini full kit February 06, 2016 07:15AM |
hacker
…these z-artefacts, do you know where they come from? Is that the ripples because of the belts (mine aren't twisted) you were talking about, or should I look elsewhere?
Re: Ebay SINTRON Kossel Mini full kit February 06, 2016 09:08AM |
Re: Ebay SINTRON Kossel Mini full kit February 06, 2016 10:03AM |
Re: Ebay SINTRON Kossel Mini full kit February 06, 2016 12:50PM |
hacker
DRTak
The black bed is beautiful!
I also want to include pictures…
[attachment 71740 IMG_0854.jpg]
and
[attachment 71741 IMG_0855.jpg]
Re: Ebay SINTRON Kossel Mini full kit February 06, 2016 12:52PM |
DRTak
hacker
DRTak
and
Im no pro but that looks good to me. I would accept those marks. LOL. At least its all even and smooth.
Re: Ebay SINTRON Kossel Mini full kit February 06, 2016 12:55PM |
Re: Ebay SINTRON Kossel Mini full kit February 08, 2016 03:09PM |
hacker
DRTak
hacker
DRTak
and
I do accept them. ;-) Also transparent PETG is not the most forgiving material, but I just thought it's interesting to find out the cause.
Re: Ebay SINTRON Kossel Mini full kit February 08, 2016 03:16PM |
DRTak
hacker
DRTak
hacker
DRTak
and
Thanks hacker re: the black bed.
I have a question. I just used the last spool of ABS. I am no longer going to use abs. I have a good idea now of how to use PLA. I have a large spool of PETG. I want to go along your route of only using PETG. Currently my hotened is set for 218deg C, The hotbed is set at 100. Im going to try maybe 85 or 90. What are your settings for PETG.
I'm using PLA as well. My settings for PETG are bed at 80 and hotend at 250 (I have e3dv6 hotend). You can go lower, just pick appropriate speed. My PETG spool is marked 230-250. (This is my first spool of PETG, but I definitely will buy more).
Re: Ebay SINTRON Kossel Mini full kit February 08, 2016 06:52PM |
hacker
DRTak
hacker
DRTak
hacker
DRTak
and
I didn't go the route of only using PETGI'm using PLA as well. My settings for PETG are bed at 80 and hotend at 250 (I have e3dv6 hotend). You can go lower, just pick appropriate speed. My PETG spool is marked 230-250. (This is my first spool of PETG, but I definitely will buy more).
Re: Ebay SINTRON Kossel Mini full kit February 09, 2016 02:29AM |
Re: Ebay SINTRON Kossel Mini full kit February 09, 2016 03:34AM |
hacker
DRTak
I also have the sintron E3D hotend and/or clone. Whatever SIntron includes in their kit.
What I meant to say is that I have e3d e3d. And I mention that because I don't know what's the temperature limit for sintron's hotend and if it's allowed to go as far as 250.
Re: Ebay SINTRON Kossel Mini full kit February 09, 2016 03:43AM |
nebbian
hacker
DRTak
It's all-metal, I've had mine up to 255 before now.
Re: Ebay SINTRON Kossel Mini full kit February 09, 2016 05:41AM |
Re: Ebay SINTRON Kossel Mini full kit February 09, 2016 07:14AM |
nebbian
The PTFE tube butts up against the top of the heatbreak. So it goes down as far as the bottom of the heatsink in the cold part.
I've had my hotend apart before, there was no evidence of melting/burning/discolouration on the tube. So I think it's pretty safe, as long as your hotend fan keeps going.
Re: Ebay SINTRON Kossel Mini full kit February 09, 2016 09:40AM |
Re: Ebay SINTRON Kossel Mini full kit February 09, 2016 09:44AM |
nebbian
hacker
Sounds like it can go close to 300 then, right?
I wouldn't go that high, most I'd go would be 265. But then again I scare easily
Re: Ebay SINTRON Kossel Mini full kit February 09, 2016 04:20PM |
Re: Ebay SINTRON Kossel Mini full kit February 09, 2016 04:21PM |
Re: Ebay SINTRON Kossel Mini full kit February 12, 2016 04:39AM |
Re: Ebay SINTRON Kossel Mini full kit February 14, 2016 03:49PM |
hacker
nebbian
hacker
Theoretically, I mean ;-) I think I only heated it up to 290 or even 295 for hot-tightening, but I did try printing PETG at 270 for the speed sake and it worked ;-) Of course it also depends on heatsink cooling (as I said I used original e3d with the original fan shroud).
At any rate, there's no good reason to go that high with materials I have tried so far.
Re: Ebay SINTRON Kossel Mini full kit February 14, 2016 03:55PM |
DRTak
hacker
nebbian
hacker
I checked the ebay listing that I used to buy the sintron printer and it says 260 max temp for the hotend. When I had ramps, it mistakenly went beyond that when the heatsink fan went off. It melted the internal PTFE tubing. So I guess that is the limit (the ptfe tubing) as stated in this thread a little bit above.
Re: Ebay SINTRON Kossel Mini full kit February 14, 2016 08:52PM |
