Re: FA-MAS mostly metal delta build - AKA Metal Gear November 27, 2017 11:42AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 27, 2017 01:14PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 28, 2017 12:13PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 28, 2017 12:35PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 28, 2017 12:39PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear December 03, 2017 11:11AM |
M558 P1 X0 Y0 Z0 H5 F900 T3600 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds G31 P500 X20.5 Y-12.5 Z3.376 ; Set Z probe trigger value, offset and trigger height M557 R75 S20 ; Define mesh grid
; bed.g ; called to perform automatic delta calibration via G32 ; ; generated by RepRapFirmware Configuration Tool on Fri Nov 10 2017 13:27:35 GMT-0800 (PST) ; Clear any bed transform M561 ; Probe the bed at 6 peripheral and 3 halfway points, and perform 6-factor auto compensation ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g. G30 P0 X0 Y74.9 H0 Z-99999 G30 P1 X64.87 Y37.45 H0 Z-99999 G30 P2 X64.87 Y-37.45 H0 Z-99999 G30 P3 X0 Y-74.9 H0 Z-99999 G30 P4 X-64.87 Y-37.45 H0 Z-99999 G30 P5 X-64.87 Y37.45 H0 Z-99999 G30 P6 X0 Y37.4 H0 Z-99999 G30 P7 X32.39 Y-18.7 H0 Z-99999 G30 P8 X-32.39 Y-18.7 H0 Z-99999 G30 P9 X0 Y0 H0 Z-99999 S6
Re: FA-MAS mostly metal delta build - AKA Metal Gear December 03, 2017 11:43AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear December 03, 2017 11:45AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear December 03, 2017 11:56AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear December 03, 2017 12:00PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear December 03, 2017 01:51PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear December 03, 2017 02:07PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear December 03, 2017 02:51PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear December 04, 2017 12:15PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear December 10, 2017 06:28PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear May 01, 2018 09:07PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear May 01, 2018 09:18PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear August 12, 2018 06:20PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear August 13, 2018 04:40PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear August 26, 2018 10:07AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear September 01, 2018 12:11PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear September 04, 2018 01:27PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear September 25, 2018 12:02PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear February 07, 2019 10:52AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear February 07, 2019 11:16AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear February 20, 2019 06:20PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear February 27, 2019 10:53AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear February 27, 2019 07:17PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear March 16, 2019 04:25PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear March 17, 2019 11:00AM |
