Re: Generation 7 Electronics Development October 13, 2012 05:35PM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Generation 7 Electronics Development October 14, 2012 08:19AM |
Re: Generation 7 Electronics Development October 20, 2012 05:06PM |
Re: Generation 7 Electronics Development October 22, 2012 11:15AM |
Re: Generation 7 Electronics Development October 23, 2012 03:43PM |
Re: Generation 7 Electronics Development October 24, 2012 06:52AM |
Re: Generation 7 Electronics Development October 25, 2012 08:32AM |
- use the brown out detector instead of the reset pin for low voltage programming
Re: Generation 7 Electronics Development October 31, 2012 06:32AM |
Re: Generation 7 Electronics Development November 02, 2012 11:50PM |
Re: Generation 7 Electronics Development November 04, 2012 05:32AM |
Re: Generation 7 Electronics Development November 05, 2012 07:04PM |
Re: Generation 7 Electronics Development November 05, 2012 07:07PM |
Re: Generation 7 Electronics Development November 05, 2012 07:11PM |
Re: Generation 7 Electronics Development November 06, 2012 06:26AM |
Annirak
For the cost of two resistors, an LED and a transistor, you can have 100% resolution across the measurable range. All you need is a current source to feed the thermistor.
By limiting ourselves based on what is appealing to the beginner, are we doing the best job that we can in promoting Reprap?
Would the project and its community be better served by developing more complex control strategies? If so, then we likely need more complex controllers, which likely cannot be implemented in DIP.
Would the project and the community be better served by the approach that cost is king? If that were the case, then mass manufacture would be the only option.
What about expandability? How do we ensure that users can make their 3x Extruder repraps work, while not unduly increasing the cost of the 1x Extruder repraps?
Please don't take them too seriously.
Re: Generation 7 Electronics Development November 06, 2012 07:43AM |
Admin Registered: 16 years ago Posts: 13,902 |
Re: Generation 7 Electronics Development November 06, 2012 10:28AM |
Traumflug
Could you elaborate what you mean here?Quote
Annirak
Re: Generation 7 Electronics Development November 07, 2012 08:04AM |
Re: Generation 7 Electronics Development November 07, 2012 12:04PM |
Re: Generation 7 Electronics Development November 10, 2012 10:57AM |
Re: Generation 7 Electronics Development November 10, 2012 09:46PM |
Re: Generation 7 Electronics Development November 12, 2012 05:32PM |
Re: Generation 7 Electronics Development November 20, 2012 09:57AM |
Re: Generation 7 Electronics Development November 28, 2012 06:44AM |
Re: Generation 7 Electronics Development November 29, 2012 06:00AM |
Re: Generation 7 Electronics Development November 29, 2012 10:41AM |
Re: Generation 7 Electronics Development November 30, 2012 08:18AM |
So, it would make a lot of sense to add another connector on the pcb
There are two ways to solve the problem, both of them require the CPU pin to work in the opposite sense
I'm not convinced the schematic posted above on Nov20 would work ok
Re: Generation 7 Electronics Development November 30, 2012 11:28AM |
Re: Generation 7 Electronics Development December 02, 2012 01:40PM |
Re: Generation 7 Electronics Development December 12, 2012 06:16AM |
Re: Generation 7 Electronics Development December 26, 2012 06:35PM |
