Re: Uneven surface problem September 24, 2016 04:48AM |
Paul Wanamaker
Doesn't look to me like Z is the problem.
MosfetN
Yesterday i have changed the whole hotend assembly from genuine E3D V6 to old one peek J-head with 0.5mm nozzle.
Results are surprising the surface is now much smoother.
I'd like to focus on the X/Y movement. Doing a circular object was good to test this.
Looking at the Jhead test, the improved smoothness may just be due to slight differences in temperature or nozzle geometry.
What sticks out (or in) is that big grove near the bottom, and smaller ones near the top.
- Is that a single wall item?
- Is the perimeter pushed towards the inside at those locations? If so then that is very telling.
- What speeds, layer height, temp did you use?
- Is there any play at the hot-end tip?
- With belts disconnected - is the X/Y movement completely smooth or are there any slight hangups or binding?
- Is there more displacement in X or Y direction?
- What exact drivers are you using?
Re: Uneven surface problem September 24, 2016 07:58AM |
Re: Uneven surface problem September 24, 2016 08:18AM |
Re: Uneven surface problem September 24, 2016 11:22AM |
Re: Uneven surface problem September 24, 2016 03:36PM |
Re: Uneven surface problem September 25, 2016 07:30AM |
Re: Uneven surface problem September 25, 2016 07:38AM |
Re: Uneven surface problem September 25, 2016 08:34AM |
Re: Uneven surface problem September 25, 2016 10:33AM |
This is something you may need to consider further. The reason I mentioned it is I have seen a case here where bundled cables caused the extruder to be slightly uneven in just this way.Quote
MosfetN
Stepper wires are near other wires for eg. in cable carriage
Re: Uneven surface problem September 25, 2016 05:28PM |
Is your 20 mm test cube really coming out "11.99/12/12.05 (XYZ)"? If so then you need to adjust your steps per mm so it comes out near 20/20/20 before anything else.
Re: Uneven surface problem September 26, 2016 12:16PM |
Re: Uneven surface problem September 26, 2016 01:55PM |
Re: Uneven surface problem September 26, 2016 02:45PM |
Re: Uneven surface problem September 27, 2016 04:40AM |
Re: Uneven surface problem September 30, 2016 02:53AM |
Re: Uneven surface problem September 30, 2016 08:57AM |
Re: Uneven surface problem October 01, 2016 09:54AM |
Re: Uneven surface problem October 05, 2016 05:56AM |
Re: Uneven surface problem October 05, 2016 06:02AM |
Re: Uneven surface problem October 05, 2016 06:30AM |
Re: Uneven surface problem October 05, 2016 06:55AM |
Re: Uneven surface problem November 05, 2016 12:46PM |
Re: Uneven surface problem April 03, 2017 06:44PM |
Re: Uneven surface problem April 10, 2017 12:25PM |
Re: Uneven surface problem April 29, 2017 08:03PM |
Re: Uneven surface problem May 05, 2017 11:56AM |
Re: Uneven surface problem June 25, 2017 04:42AM |
Re: Uneven surface problem June 25, 2017 08:17AM |
Re: Uneven surface problem June 25, 2017 08:56AM |
DD
The assumption is that by using full step multiples, at each layer position the Z motor will be sitting in one of the full step detents and not relying on the microstepping for position control which could result in variations in the bed's position.
Re: Uneven surface problem June 25, 2017 09:54AM |
