Repetier Host 1.5.0 notes?
July 08, 2015 08:51PM
Are there any release notes with 1.5.0? Something that says what new functionality is there, and which bugs have been fixed?
Thanks,
Re: Repetier Host 1.5.0 notes?
July 09, 2015 06:39AM
You see it always in the update message. Here for completeness:
Version 1.5.1
* Fixed print problems when exceeding line 65535
* Fixed slic3r issue with non ascii user names.
Version 1.5.0
* Connector for Repetier-Server.
* Support of repetier binary protocol V3.
* New CuraEngine version.
* Slic3r 1.2.9a included.
* New EEPROM handler for Repetier-Firmware.
* Better support for high DPI displays.
* Support for slic3r 1.2.2 and newer.
* Improved communication stack.
* Bug fixes.
July 09, 2015 09:23AM
Thanks, Roland. Which version of the Cura engine?
July 09, 2015 10:17AM
Last before they made everything incompatible with a completely new configuration and communication setup. So end april was the last commit included.
July 09, 2015 10:19AM
Before you ask - I guess we will upgrade to new CuraEngine once we find a way to make it work with our configuration and understand all the changes.
July 09, 2015 10:50AM
I understand completely. Thanks for getting what you could out.
Where is this? I could not find it on the website anywhere.
I see that the flowrate slider on the manual control tab is gone, and that a heated bed slider is now there.
How do I tell the printer settings that I don't have a heated bed? I have the temps at 0 for this, except the minimum, whoich does not allow me to set it to zero.
July 09, 2015 10:57AM
Changes are shown when you click "Check updates" in host and there is a new version. It will then show which and what is new so you can decide how urgent update is.
Flow slider is hidden in easy mode.
Bed slider only appears if firmware reports temperatures for bed. If not it will disappear after connect.
July 09, 2015 12:56PM
Ah, yes. Thanks.
Is this a change? I never saw it in 1.0.6, and I don't have a heated bed. It stays after I connect. My firmware
configuration file has HAVE_HEATED_BED set to 0. Is there something else I need to do to make it go away?
July 10, 2015 09:18AM
the last version is 1.0.6, why is it 1.5.0 suddenly? anyone knows?
I wanna know more details too.
July 10, 2015 03:46PM
frankleng
Had the same question. My assumption was that there were numerous versions between 1.06 and 1.5 that weren't stable enough to be pushed out.
July 11, 2015 02:39AM
Other software increment in steps of 1 and no one questions. Version umber is just a decision and we wanted to show that the new server inclusion is a big step, so we wanted to show it also in a version number. That's why we called it 1.5.
