Laser cut Aluminium X-Arm & Rib kits.... July 21, 2014 09:13AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... July 21, 2014 03:49PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... July 21, 2014 04:17PM |
x4FF3
i am interested set me on the list!
Re: Laser cut Aluminium X-Arm & Rib kits.... July 21, 2014 04:40PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... July 26, 2014 04:06PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... July 28, 2014 04:06PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... July 28, 2014 04:14PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... July 28, 2014 04:15PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 01, 2014 05:18AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 02, 2014 11:18AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 06, 2014 12:17PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 10, 2014 12:24PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 14, 2014 02:07PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 15, 2014 08:04AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 15, 2014 03:17PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 16, 2014 12:04PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 18, 2014 07:29AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 18, 2014 01:14PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 18, 2014 03:17PM |
Davek0974
It's the first hole for the rib, it sits behind the z axis column.
Dave
Re: Laser cut Aluminium X-Arm & Rib kits.... August 18, 2014 03:38PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 19, 2014 10:18AM |
Davek0974
The remaining screw is the one currently holding the z axis runner bearing block
Electric blue sounds good
Re: Laser cut Aluminium X-Arm & Rib kits.... August 19, 2014 01:24PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 19, 2014 01:28PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 19, 2014 02:43PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 20, 2014 04:05AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 20, 2014 02:24PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 22, 2014 05:18PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 23, 2014 03:24AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 23, 2014 07:20AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 23, 2014 07:50AM |
