Re: Laser cut Aluminium X-Arm & Rib kits.... August 09, 2015 10:21AM |
Darathy
would it be posible to get a kit to make ormerod like Eriks(if he wants to put his designs out here) and make it for Ormerod 2 aswell?
Re: Laser cut Aluminium X-Arm & Rib kits.... August 10, 2015 01:05PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 10, 2015 01:06PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 10, 2015 02:08PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 10, 2015 02:32PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 10, 2015 02:43PM |
Fpex
Then i have to hope my start-ups works out so that i can afford one!
Re: Laser cut Aluminium X-Arm & Rib kits.... August 10, 2015 02:48PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 19, 2015 05:00PM |
Davek0974
Thanks
Yes I can make that part easily if wanted.
The dimensions in Ormerod168's post are most helpful,
What would the thickness be, 3mm??
If wanted I can work out a price but it won't be much, less than £10 anyway.
Dave
Re: Laser cut Aluminium X-Arm & Rib kits.... August 20, 2015 02:29AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 20, 2015 03:59AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 20, 2015 02:38PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 20, 2015 05:14PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 20, 2015 05:23PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 22, 2015 04:17AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 22, 2015 01:10PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 25, 2015 07:26AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 25, 2015 05:07PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... August 26, 2015 02:24AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... September 16, 2015 03:42AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... September 25, 2015 02:32PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... October 01, 2015 05:25AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... October 01, 2015 06:39AM |
Davek0974
I have been advised that the Mk2 runner runs on the underside of the arm instead of the back face??
In that case i will clean all future kits on that face using a surface plate to get a decent surface there.
I currently have plenty of stock
Re: Laser cut Aluminium X-Arm & Rib kits.... October 01, 2015 08:13AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... October 01, 2015 12:04PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... October 01, 2015 01:27PM |
BriComp
Does that mean that the X-Plates and ribs that I bought for my Ormerod 2 are of little use?
Re: Laser cut Aluminium X-Arm & Rib kits.... October 01, 2015 05:19PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... October 01, 2015 08:53PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... October 02, 2015 02:09AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... October 02, 2015 05:52AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... October 02, 2015 06:25AM |
BriComp
If it's "Pretty Good as it Comes" then why are you modifying the stock that you have for the latest Ormerod 2?
