Re: Smartrap evolution, improvements... May 03, 2014 04:36AM |
Re: Smartrap evolution, improvements... May 03, 2014 05:49AM |
Re: Smartrap evolution, improvements... May 11, 2014 10:37AM |
Re: Smartrap evolution, improvements... May 11, 2014 10:43AM |
Re: Smartrap evolution, improvements... May 11, 2014 06:09PM |
Re: Smartrap evolution, improvements... May 11, 2014 06:25PM |
markstephen
Here's a question - How thick is the glass you all are using for your plate? I am using 3/32" (~2.4 mm) and the Glass Support parts, (the new ones) are way too tall to hold that thickness of glass. It's easy enough to make these fit, just wondering if there is a standard or preferred thickness for the plate?
Mark
Re: Smartrap evolution, improvements... May 21, 2014 05:33PM |
Re: Smartrap evolution, improvements... June 03, 2014 04:32AM |
Re: Smartrap evolution, improvements... June 03, 2014 04:55AM |
Re: Smartrap evolution, improvements... June 03, 2014 07:40AM |
Re: Smartrap evolution, improvements... June 03, 2014 10:12AM |
Re: Smartrap evolution, improvements... June 03, 2014 11:07AM |
Re: Smartrap evolution, improvements... June 03, 2014 12:33PM |
Re: Smartrap evolution, improvements... June 03, 2014 04:38PM |
MelT
Of course there's no harm in trying especially if you already have a working 3D printer, but if I had a working servo motor, I would probably stick with it compared to the servo-less version. The reason being that my j-head is more sturdy when it is mounted directly on the X end that connects to the rods. I'm currently using the servo-less version and if I move the ptfe tube, the nozzle tip wiggles considerably. This could explain why my walls are not completely flat and ridges are visible. Maybe my tube is too short or I don't know what else. Just sharing before you try it.
Again, no harm in trying. Hope it works well for you.
Re: Smartrap evolution, improvements... June 03, 2014 07:08PM |
Re: Smartrap evolution, improvements... June 03, 2014 10:15PM |
MelT
Oh yeah, that looks like it can resist wiggle better since the arm has a wider contact with the x end.
It looks a little advanced though and but I should be able to modify it to keep my current Z plate. Then I can probably use a spring from a pen so I can try it out.
Is your design open and posted somewhere?
Re: Smartrap evolution, improvements... June 03, 2014 10:27PM |
regpye
MelT
I will post a URL for you.
Re: Smartrap evolution, improvements... June 03, 2014 10:56PM |
MelT
Re: Smartrap evolution, improvements... June 04, 2014 05:44AM |
Re: Smartrap evolution, improvements... June 04, 2014 01:03PM |
Re: Smartrap evolution, improvements... June 04, 2014 05:58PM |
Re: Smartrap evolution, improvements... June 08, 2014 01:34AM |
Re: Smartrap evolution, improvements... June 08, 2014 02:04AM |
CellJeffe
I gave a shot at designing a J-head mount for the newest servoless x-ends from Smartfriendz. I also used Regpye's idea of the PTFE tube near the switch and a longer radius between the pivot and the PTFE tube so that the PTFE tube does not shift much perpendicular to its axis. I'm going to give the whole thing a try this week during a teardown/rebuild switch to 0.4.8.
Re: Smartrap evolution, improvements... June 08, 2014 09:42AM |
Re: Smartrap evolution, improvements... June 08, 2014 11:44AM |
Re: Smartrap evolution, improvements... June 08, 2014 12:34PM |
Re: Smartrap evolution, improvements... June 08, 2014 02:09PM |
Re: Smartrap evolution, improvements... June 08, 2014 02:30PM |
regpye
No, mine is 2.75" or 65mm from tip of nozzle to the end of the cold end, so it is not too different from the standard J-head.
Mine also has a few more parts than the J-head, those are to stop the heat travel.
Source files will be available when I get time to put them up on my website.
Re: Smartrap evolution, improvements... June 08, 2014 02:59PM |
Re: Smartrap evolution, improvements... June 08, 2014 06:02PM |
