Re: Smartrap evolution, improvements... June 20, 2014 01:27PM |
Re: Smartrap evolution, improvements... June 20, 2014 02:47PM |
Re: Smartrap evolution, improvements... June 20, 2014 02:54PM |
madmike8
Looks cool... So when you going to try it? You probably have a dual holder for the Smartrap already designed up and your head and your fingers are twitching over your mouse waiting to put those ideas in to FreeCAD... I'll mail you a spare Jhead-Lite thanks to Regpye. Come on... You know you want too... I think I have some spare PTFE tube too...
Re: Smartrap evolution, improvements... June 20, 2014 04:47PM |
Re: Smartrap evolution, improvements... June 21, 2014 05:20PM |
Re: Smartrap evolution, improvements... June 21, 2014 07:39PM |
Re: Smartrap evolution, improvements... June 21, 2014 08:06PM |
madmike8
Don't think I've seen a front to back arrangement before. Is the weight going to effect the swing arm any?
Re: Smartrap evolution, improvements... June 21, 2014 10:56PM |
Re: Smartrap evolution, improvements... June 21, 2014 10:58PM |
markstephen
I don't think the weight would make a difference one way or the other. There are two of them no matter which way you mount it. But like Reg says - "We will see, wont we"
I think it will work just fine.
Mark
Re: Smartrap evolution, improvements... June 21, 2014 11:06PM |
Re: Smartrap evolution, improvements... June 22, 2014 04:43AM |
Re: Smartrap evolution, improvements... June 22, 2014 05:25AM |
smartfriendz
wonderful mark ! I'm so curious to see that in place
I'm thinking about where to put those 2 extruder steppers already
and what if we put 4 ? thinking hard here ..
Re: Smartrap evolution, improvements... June 22, 2014 07:51AM |
Re: Smartrap evolution, improvements... June 22, 2014 10:50PM |
Re: Smartrap evolution, improvements... June 23, 2014 10:22PM |
Re: Smartrap evolution, improvements... June 23, 2014 10:59PM |
markstephen
Think I have about all the printed parts made. Center section and outer retainer for the second Hotend, the dual extruder extension and idler, and Bowden tube looms - 4 "dog bone" and 3 "C" type, for Bowden tube management.
Mark
Image error
Connection to server failed (php_network_getaddresses: getaddrinfo failed: Name or service not known)
open image URL
Re: Smartrap evolution, improvements... June 23, 2014 11:24PM |
Re: Smartrap evolution, improvements... July 16, 2014 07:12PM |
BackEMF
Hmm, for some reason the Z axis is screeming especially during bedleveling. The small adjustments during a print are quiet.
Re: Smartrap evolution, improvements... July 16, 2014 07:43PM |
Re: Smartrap evolution, improvements... July 16, 2014 09:55PM |
BackEMF
Re: Smartrap evolution, improvements... August 07, 2014 05:47PM |
Re: Smartrap evolution, improvements... August 07, 2014 05:50PM |
Re: Smartrap evolution, improvements... August 07, 2014 06:17PM |
Re: Smartrap evolution, improvements... August 08, 2014 11:01PM |
RTurnock
Kits for the students to build, test, calibrate, print parts for another printer and then take the printer apart so that the next semester students can do the same thing all over again.
RTurnock
Don't want to use Spectra fishing line,
Re: Smartrap evolution, improvements... August 08, 2014 11:54PM |
BackEMF
I have a few suggestions:
RTurnock
Why not let the kids keep the printer and also teach them to work with the printer and CAD stuff etc.
The printers keep evolving too, so just print new parts with the existing printers and this gives you a more recent model fort the next group.
BackEMF
RTurnock
To teach about tuning the printer Spectra line is actually great to teach about calculating to tune the printer. GT2 and R&P are simpler to set up, though in my opinion you would me missing an opportunity to teach a few valuable things.
You could also make a simple breadboard with RAMPS and a few motors just to teach about the firmware without doing harm to the hardware if there are adventurers who like to experiment a bit.
BackEMF
For the BOM.
You should be able to save some money on the PCB's
Also consider Regpyes Genie hotend and also his geared extruder.
I don't know if it is practical, but you can also build several types of extruders and again do some teaching on the tuning side of things.
you could also include a bit of bearing grease or use printed LM8UU bearing replacements
Re: Smartrap evolution, improvements... August 20, 2014 07:20PM |
Re: Smartrap evolution, improvements... August 20, 2014 07:40PM |
mikefiatx19
I assume the Ramps board included is pre-programmed to accept the new auto levelling setup but again I am unsure.
mikefiatx19
2) Do i need to put heat sinks on the pololus on the Ramps board? There were none attached to mine and none in the box that I got.
The reason I ask is because I can see heatsinks on the units that are shown on the Smartfrienz website but I would think that they would be part of the kit if I needed them.
mikefiatx19
3) What would you recommend to coat the glass bed to print PLA? I think blue tape ruins the finish of the printed parts and I know hairspray can clog up the nozzle.
Any help would be really appreciated.
Thanks
Mike
Re: Smartrap evolution, improvements... August 20, 2014 07:58PM |
mikefiatx19
Hi Guys,
Maybe someone can help me with a few Smartrap issues.
1) Does anyone have any info about fitting the new J-head lite?
I just got my Smartrap through the post from Smartfrienz and there are no documents advising on how to put it together or adjust it. I assume the Ramps board included is pre-programmed to accept the new auto levelling setup but again I am unsure.
Thanks
Mike
Re: Smartrap evolution, improvements... August 20, 2014 11:26PM |
mikefiatx19
Hi Guys,
Thanks
Mike
Re: Smartrap evolution, improvements... August 20, 2014 11:37PM |
BackEMF
mikefiatx19
Hi Guys,
Thanks
Mike
1. I think you have to flash the firmware yourself. you need to install Arduino for this.
2. I'm not sure if the heatsinks are really needed. With the 40mm motors i think you can do without.
3. dilute some PVA glue (woodglue) 1 part PVA 3 parts water and brush it evenly on the glass with a paintbrush. (Initially i had a woodglue that didn't stick at all) Now i have Bison D2 and that works fine. I also tried sugar, and that worked reasonable too. Hairspray didn't work for me Though i see MarkStephen has very nice results with Aquanet hairspray. (Unfortunately that stuff is not available where i live)
