Re: New to 3d printing with smartrap need some help June 07, 2014 12:13AM |
Re: New to 3d printing with smartrap need some help June 07, 2014 02:32AM |
duranza
I can feed it by hand, but it takes way too much force in my opinion. This might be why the stepper is strugling. Are you using a .4mm or a .5mm tip? I got a .4mm tip. I might try switching the side the extruder comes out so that the z axis rod is not in the way. This way I can make a straighter equal bend of the tube.
You guys are awsome. I was feeling really dissaponited with all this problems, but now I can see some light at the end of the tunnel.
Re: New to 3d printing with smartrap need some help June 07, 2014 03:42AM |
Re: New to 3d printing with smartrap need some help June 07, 2014 12:50PM |
duranza
Ok. I have confirmed the steps per mm to be good. It is set in marlin at 91.23 steps per mm and it is right on. I did try to run at 20% feed rate and got some progress. It extruded some steady strands for about a minute then it started clicking/skipping steps again. I have verified that the temperature is within 1 degree of what it displays on the screen. I did also free up the bowden tube to let it be by itself.
Re: New to 3d printing with smartrap need some help June 07, 2014 07:53PM |
Re: New to 3d printing with smartrap need some help June 09, 2014 04:13PM |
Re: New to 3d printing with smartrap need some help June 10, 2014 03:50AM |
Re: New to 3d printing with smartrap need some help June 10, 2014 07:41AM |
Re: New to 3d printing with smartrap need some help June 10, 2014 10:26AM |
duranza
I do have a fan, but I suspect that the heat is traveling up too far. I have tried to enable auto fan, but it doesn't keep the heatsink cool enough. I have to keep it on all the time full blast. I will try the heating up high without the filament before printing until I get the J head.
Thanks,
Re: New to 3d printing with smartrap need some help June 10, 2014 01:48PM |
Re: New to 3d printing with smartrap need some help June 11, 2014 07:15AM |
heyzeus
The j-head lite doesn't need a fan, so I wouldn't worry about it.
Re: New to 3d printing with smartrap need some help June 11, 2014 12:54PM |
Re: New to 3d printing with smartrap need some help June 11, 2014 01:24PM |
Re: New to 3d printing with smartrap need some help June 13, 2014 03:46PM |
Re: New to 3d printing with smartrap need some help June 13, 2014 03:51PM |
Re: New to 3d printing with smartrap need some help June 13, 2014 08:32PM |
Re: New to 3d printing with smartrap need some help June 13, 2014 08:37PM |
Re: New to 3d printing with smartrap need some help June 13, 2014 10:13PM |
Anonymous User
Re: New to 3d printing with smartrap need some help June 13, 2014 10:45PM |
Re: New to 3d printing with smartrap need some help June 13, 2014 10:48PM |
Re: New to 3d printing with smartrap need some help June 13, 2014 10:50PM |
Re: New to 3d printing with smartrap need some help June 13, 2014 11:31PM |
Re: New to 3d printing with smartrap need some help June 13, 2014 11:44PM |
Re: New to 3d printing with smartrap need some help June 14, 2014 12:03AM |
Re: New to 3d printing with smartrap need some help June 14, 2014 12:12AM |
Anonymous User
Re: New to 3d printing with smartrap need some help June 14, 2014 12:17AM |
Re: New to 3d printing with smartrap need some help June 14, 2014 12:42AM |
Re: New to 3d printing with smartrap need some help June 14, 2014 11:56AM |
duranza
{snip} I see what I'm missing.. The end plate that I have doesn't have that fork to stop the nut. I'll have to see what I can do to make it work and print a replacement. Man I wish I had someone around my area that could hook me up to get started.
Re: New to 3d printing with smartrap need some help June 14, 2014 12:05PM |
Re: New to 3d printing with smartrap need some help June 14, 2014 01:25PM |
