Re: New to 3d printing with smartrap need some help June 29, 2014 08:19PM |
duranza
Hey RegPye, do you have the small extruder gear in freecad or another editable format? I need to make the ID to 4mm for my stepper shaft. I was using a makeshift sleeve and it just broke.
Re: New to 3d printing with smartrap need some help June 29, 2014 08:34PM |
Re: New to 3d printing with smartrap need some help June 29, 2014 08:41PM |
duranza
I'm using your extruder. I think it is 11 teeth straight. Yes the steppers I have came with a 5mm shaft turned down to 4mm for some reason. A straight hole is what I was going to use.
Re: New to 3d printing with smartrap need some help July 02, 2014 08:47AM |
Re: New to 3d printing with smartrap need some help July 02, 2014 07:16PM |
Re: New to 3d printing with smartrap need some help July 02, 2014 08:11PM |
duranza
I'm still trying out the auto leveling and almost got it going, but when I set the z height between probing it doesn't change anything and the nozzle scrapes when going from one location to the other.
#define Z_RAISE_BEFORE_PROBING 5 //How much the extruder will be raised before traveling to the first probing point. #define Z_RAISE_BETWEEN_PROBINGS 5 //How much the extruder will be raised when traveling from between next probing points
Re: New to 3d printing with smartrap need some help July 02, 2014 08:32PM |
Re: New to 3d printing with smartrap need some help July 02, 2014 08:41PM |
Re: New to 3d printing with smartrap need some help July 02, 2014 08:46PM |
MelT
Ah. If it always says triggered, that could be it.
And please check that you have placed the wires to the RAMPS board correctly or that you have wired the right terminals on the micro switch. It should be in the NC (normaly closed) pin.
Re: New to 3d printing with smartrap need some help July 02, 2014 08:53PM |
Re: New to 3d printing with smartrap need some help July 02, 2014 09:30PM |
Re: New to 3d printing with smartrap need some help July 02, 2014 09:34PM |
Re: New to 3d printing with smartrap need some help July 02, 2014 09:47PM |
duranza
It has always been like this. I could never get the auto level to work, but the regular 28 works fine. The Z min shows open, but the z max is triggered.
Re: New to 3d printing with smartrap need some help July 02, 2014 09:56PM |
regpye
duranza
I had a faulty RAMPS board once, it was triggered when not even connected. Worth to take the plug off and check the actual board, you may have one like that too.
Re: New to 3d printing with smartrap need some help July 03, 2014 08:33AM |
Re: New to 3d printing with smartrap need some help July 04, 2014 11:41AM |
Re: New to 3d printing with smartrap need some help July 07, 2014 07:00PM |
Re: New to 3d printing with smartrap need some help July 07, 2014 09:00PM |
Re: New to 3d printing with smartrap need some help July 07, 2014 09:48PM |
RTurnock
New to Smartrap and plan to build one.
I have a Printrbot Simple V2 and built a Mini Kossel that I upgraded to 350mm horizontals.
I build a 3DR Simple as designed by JohnSL but took it apart to upgrade my Kossel and just this weekend finished taking other parts off to use on the Smartrap build.
Questions
1. I downloaded the Github Smartrap Master folder. There is blender and openscad and lots of other files and folders. I am confused about what version is the current release, what version is still in development. I can't tell which STL files I should print.
2. I have a Printrboard and plan on using that on the Smartrap...I have experience uploading firmware to it from using it with the 3DR Simple. Anyone have problems with using Printrboard?
3. I have a Ubis hot end. Can I use that on the Smartrap?
4. Where is the latest parts list with sources? I have a parts list for Smartrap but it is the original list with fishing line and I have GT2 belts and pulleys to use.
Well, I have more questions....that's enough for now.
Looking forward to sharing and hearing what others have done.
Take Care
Richard
Re: New to 3d printing with smartrap need some help July 07, 2014 10:29PM |
MelT
I believe 4.9 is the most recent released version
I looked what ubis hot end looks like and it seems a little too long. You probably need to customize your mount so as not to lose too much Z movement because of the extra length.
Re: New to 3d printing with smartrap need some help July 07, 2014 10:35PM |
Re: New to 3d printing with smartrap need some help July 07, 2014 10:42PM |
Re: New to 3d printing with smartrap need some help July 10, 2014 06:29AM |
Re: New to 3d printing with smartrap need some help July 15, 2014 12:04AM |
Re: New to 3d printing with smartrap need some help July 15, 2014 12:11AM |
RTurnock
What alternatives are there to the Z axis M5 threaded rod?
I can order one from McMaster Carr or ?
What are people doing to drive the Z axis?
Thank you.
Re: New to 3d printing with smartrap need some help July 15, 2014 10:34AM |
Re: New to 3d printing with smartrap need some help July 15, 2014 11:42AM |
thx for the compliments .
Re: New to 3d printing with smartrap need some help July 15, 2014 06:57PM |
Re: New to 3d printing with smartrap need some help July 15, 2014 07:05PM |
RTurnock
Ordered plastic parts from MakerCoast.
Will order threaded rod and then I already have all the other parts, motors, etc.
I hope to make one before September to show at the local high school.
Re: New to 3d printing with smartrap need some help July 16, 2014 07:07PM |
