Re: PiBot Optical Reflection Endstop October 22, 2015 11:45AM |
Re: PiBot Optical Reflection Endstop October 24, 2015 01:54PM |
Re: PiBot Optical Reflection Endstop October 25, 2015 01:52AM |
Re: PiBot Optical Reflection Endstop October 25, 2015 10:01AM |
17:36:45.388 : echo: M48 Z-Probe Repeatability test 17:36:48.964 : echo: deploy_z_probe > current_position: (178.01, 178.00, 19.46) 17:36:48.968 : echo: setup_for_endstop_move > enable_endstops(true) 17:36:59.785 : echo: run_z_probe > current_position: (178.01, 178.00, -0.51) 17:37:03.397 : echo: do_blocking_move_to: (178.01, 178.00, 9.49) 17:37:03.401 : echo: setup_for_endstop_move > enable_endstops(true) 17:37:10.520 : echo: run_z_probe > current_position: (178.01, 178.00, -0.53) 17:37:14.198 : echo: do_blocking_move_to: (178.01, 178.00, 9.49) 17:37:14.202 : echo: setup_for_endstop_move > enable_endstops(true) 17:37:21.321 : echo: run_z_probe > current_position: (178.01, 178.00, -0.53) 17:37:24.983 : echo: do_blocking_move_to: (178.01, 178.00, 9.49) 17:37:24.987 : echo: setup_for_endstop_move > enable_endstops(true) 17:37:32.105 : echo: run_z_probe > current_position: (178.01, 178.00, -0.52) 17:37:35.681 : echo: do_blocking_move_to: (178.01, 178.00, 9.49) 17:37:35.689 : echo: setup_for_endstop_move > enable_endstops(true) 17:37:42.906 : echo: run_z_probe > current_position: (178.01, 178.00, -0.52) 17:37:46.486 : echo: do_blocking_move_to: (178.01, 178.00, 9.49) 17:37:46.490 : echo: setup_for_endstop_move > enable_endstops(true) 17:37:53.690 : echo: run_z_probe > current_position: (178.01, 178.00, -0.52) 17:37:57.266 : echo: do_blocking_move_to: (178.01, 178.00, 9.49) 17:37:57.274 : echo: setup_for_endstop_move > enable_endstops(true) 17:38:04.471 : echo: run_z_probe > current_position: (178.01, 178.00, -0.53) 17:38:08.050 : echo: do_blocking_move_to: (178.01, 178.00, 9.49) 17:38:08.054 : echo: setup_for_endstop_move > enable_endstops(true) 17:38:15.173 : echo: run_z_probe > current_position: (178.01, 178.00, -0.53) 17:38:18.851 : echo: do_blocking_move_to: (178.01, 178.00, 9.49) 17:38:18.855 : echo: setup_for_endstop_move > enable_endstops(true) 17:38:25.974 : echo: run_z_probe > current_position: (178.01, 178.00, -0.52) 17:38:29.553 : echo: do_blocking_move_to: (178.01, 178.00, 9.49) 17:38:29.557 : echo: setup_for_endstop_move > enable_endstops(true) 17:38:36.775 : echo: run_z_probe > current_position: (178.01, 178.00, -0.52) 17:38:40.354 : echo: do_blocking_move_to: (178.01, 178.00, 9.49) 17:38:40.358 : echo: setup_for_endstop_move > enable_endstops(true) 17:38:47.558 : echo: run_z_probe > current_position: (178.01, 178.00, -0.53) 17:38:51.139 : echo: stow_z_probe > current_position: (178.01, 178.00, -0.53) 17:38:52.143 : echo: setup_for_endstop_move > enable_endstops(false) 17:38:52.147 : Mean: -0.526750 17:38:52.147 : Standard Deviation: 0.004548
Re: PiBot Optical Reflection Endstop October 25, 2015 02:07PM |
Re: PiBot Optical Reflection Endstop October 25, 2015 03:55PM |
Scusate confermo non so cosa sia sucesso si deve essere incartato il mio arduinoQuote
MagoKimbra
Primo nessuna modifica sulla SD è rimasto tutto com'era...
Credevo che alla fine si alzava fino a perdere il contatto come fa con lo Z che lo prende lo perde lo riprende e poi appena lo riperde e si fermaQuote
MagoKimbra
Si dopo aver fatto i test rimane sul'ultimo punto perché non dovrebbe??
E si mi sono confuso con quello per la Kossel allora be allora posso dire che funziona tutto a primo colo eccezzionaleQuote
MagoKimbra
M48 repeteability test fa una serie di test su un punto per verificare se la sonda funziona a dovere, dove hai letto che ci mette ore??? Semmai quello è G30 A per la Kossel!!!
Re: PiBot Optical Reflection Endstop October 26, 2015 02:41AM |
Re: PiBot Optical Reflection Endstop October 26, 2015 02:50AM |
A ecco dove ho sbagliato ho cercato di tarare tutto con il trimer e forse ho abbassato troppo la sensibilitaQuote
MagoKimbra
Il pibot è più preciso a distanze tra i 7 e 10 mm quindi aumenta un po con il trimmer la distanza a cui rileva...
Con l'offset regoli poi di quanto deve scendere per far si che il nozzle sia sul piatto: M666 L leggi il valore attuale, M666 P cambi il valore. Ricordati che deve essere negativo.
Re: PiBot Optical Reflection Endstop October 26, 2015 03:04AM |
Re: PiBot Optical Reflection Endstop October 26, 2015 01:01PM |
; Default start code M80 ; Accendi alimentatore {IF_EXT0}M104 T0 S{TEMP0} {IF_EXT1}M104 T1 S{TEMP1} {IF_EXT2}M104 T2 S{TEMP2} {IF_EXT3}M104 T3 S{TEMP3} G28 ; Home G29 ; Autobed level G0 X0 Y0 Z5 F8000 ; Out plane {IF_BED}M190 S{BED} M107 ; Turn off fan G90 ; Absolute positioning M82 ; Extruder in absolute mode G92 E0 ; Reset extruder position ; Wait for all used extruders to reach temperature {IF_EXT0}M109 T0 S{TEMP0} {IF_EXT1}M109 T1 S{TEMP1} {IF_EXT2}M109 T2 S{TEMP2} {IF_EXT3}M109 T3 S{TEMP3}
Domanda ma devo settarlo questo aprametro che avevo letto in un altor topic ?Quote
MagoKimbra
No con m666 setti solo l'offset, per vedere i valori di Z dai m114 V.
18:00:24.851 : N473 M114 V *113 18:00:24.857 : echo: N473 M114 V *113 18:00:24.865 : ok X:178.00 Y:178.01 Z:1.00 E:0.00 Count X: 178.00 Y:178.01 Z:1.00 18:00:24.869 : echo: X:178.00 Y:178.01 Z:1.00 E:0.00 Count X: 178.00 Y:178.01 Z:1.00 18:00:24.869 : ok
17:50:50.781 : N185 G28 *63 17:50:50.825 : echo: N185 G28 *63 17:50:50.829 : echo: gcode_G28 >>> 17:50:50.834 : echo: setup_for_endstop_move > enable_endstops(true) 17:50:50.837 : echo: >>> homeaxis(0) 17:50:52.644 : echo: setup_for_endstop_move > enable_endstops(false) 17:50:52.734 : echo: setup_for_endstop_move > enable_endstops(true) 17:50:52.988 : echo: > TRIGGER ENDSTOP > current_position: (0.00, 0.00, 0.00) 17:50:52.996 : echo: set_axis_is_at_home 0 > (home_offset[axis]==0.00) > current_position: (0.00, 0.00, 0.00) 17:50:53.004 : echo: > AFTER set_axis_is_at_home > current_position: (0.00, 0.00, 0.00) 17:50:53.004 : echo: <<< homeaxis(0) 17:50:53.008 : echo: > homeX: (0.00, 0.00, 0.00) 17:50:53.012 : echo: >>> homeaxis(1) 17:50:55.044 : echo: setup_for_endstop_move > enable_endstops(false) 17:50:55.134 : echo: setup_for_endstop_move > enable_endstops(true) 17:50:55.392 : echo: > TRIGGER ENDSTOP > current_position: (0.00, 0.00, 0.00) 17:50:55.400 : echo: set_axis_is_at_home 1 > (home_offset[axis]==0.00) > current_position: (0.00, -22.00, 0.00) 17:50:55.404 : echo: > AFTER set_axis_is_at_home > current_position: (0.00, -22.00, 0.00) 17:50:55.408 : echo: <<< homeaxis(1) 17:50:55.412 : echo: > homeY: (0.00, -22.00, 0.00) 17:50:55.412 : echo: > Z_SAFE_HOMING >>> 17:50:55.425 : echo: Raise Z (before homing) by 10.00 > home_all_axis > current_position: (0.00, -22.00, 0.00) > home_all_axis > destination: (115.00, 144.00, 10.00) 17:50:58.091 : echo: >>> homeaxis(2) 17:50:59.819 : echo: setup_for_endstop_move > enable_endstops(false) 17:51:00.540 : echo: setup_for_endstop_move > enable_endstops(true) 17:51:01.888 : echo: > TRIGGER ENDSTOP > current_position: (115.00, 144.00, 0.00) 17:51:01.900 : echo: set_axis_is_at_home 2 > (home_offset[axis]==0.00) > current_position: (115.00, 144.00, 1.00) 17:51:01.904 : echo: > AFTER set_axis_is_at_home > current_position: (115.00, 144.00, 1.00) 17:51:01.908 : echo: <<< homeaxis(2) 17:51:01.908 : echo: <<< Z_SAFE_HOMING 17:51:01.912 : echo: setup_for_endstop_move > enable_endstops(false) 17:51:01.916 : echo: <<< gcode_G28 17:51:01.920 : ok X:115.00 Y:144.00 Z:1.00 E:0.00 Count X: 115.00 Y:144.00 Z:1.00 17:51:01.920 : ok
17:51:48.870 : N230 G29 *51 17:51:48.875 : echo: N230 G29 *51 17:51:48.875 : echo: gcode_G29 >>> 17:51:48.879 : echo: G29 Auto Bed Leveling 17:51:48.883 : echo: setup_for_endstop_move > enable_endstops(true) 17:51:48.888 : echo: z_before = (before) 10.00 17:51:48.888 : echo: probe_pt >>> 17:51:48.896 : echo: > ProbeAction:1 > current_position: (115.00, 144.00, 1.00) 17:51:48.900 : echo: Z Raise to z_before 10.00 > do_blocking_move_to_z 10.00 17:51:48.904 : echo: do_blocking_move_to: (115.00, 144.00, 10.00) 17:51:51.963 : echo: > do_blocking_move_to_xy 178.00, 40.00 17:51:51.968 : echo: do_blocking_move_to: (178.00, 40.00, 10.00) 17:51:52.754 : echo: > ProbeDeploy 17:51:52.758 : echo: deploy_z_probe > current_position: (178.00, 40.00, 10.00) 17:51:59.476 : echo: run_z_probe > current_position: (178.00, 40.00, -3.73) 17:51:59.476 : echo: <<< probe_pt 17:51:59.480 : echo: z_before = (between) 6.27 17:51:59.480 : echo: probe_pt >>> 17:51:59.488 : echo: > ProbeAction:0 > current_position: (178.00, 40.00, -3.73) 17:51:59.492 : echo: Z Raise to z_before 6.27 > do_blocking_move_to_z 6.27 17:51:59.496 : echo: do_blocking_move_to: (178.00, 40.00, 6.27) 17:52:02.891 : echo: > do_blocking_move_to_xy 132.00, 40.00 17:52:02.895 : echo: do_blocking_move_to: (132.00, 40.00, 6.27) 17:52:08.654 : echo: run_z_probe > current_position: (132.00, 40.00, -3.69) 17:52:08.654 : echo: <<< probe_pt 17:52:08.658 : echo: z_before = (between) 6.31 17:52:08.658 : echo: probe_pt >>> 17:52:08.666 : echo: > ProbeAction:0 > current_position: (132.00, 40.00, -3.69) 17:52:08.670 : echo: Z Raise to z_before 6.31 > do_blocking_move_to_z 6.31 17:52:08.674 : echo: do_blocking_move_to: (132.00, 40.00, 6.31) 17:52:12.066 : echo: > do_blocking_move_to_xy 86.00, 40.00 17:52:12.070 : echo: do_blocking_move_to: (86.00, 40.00, 6.31) 17:52:17.817 : echo: run_z_probe > current_position: (86.00, 40.00, -3.62) 17:52:17.817 : echo: <<< probe_pt 17:52:17.821 : echo: z_before = (between) 6.38 17:52:17.821 : echo: probe_pt >>> 17:52:17.829 : echo: > ProbeAction:0 > current_position: (86.00, 40.00, -3.62) 17:52:17.833 : echo: Z Raise to z_before 6.38 > do_blocking_move_to_z 6.38 17:52:17.837 : echo: do_blocking_move_to: (86.00, 40.00, 6.38) 17:52:21.232 : echo: > do_blocking_move_to_xy 40.00, 40.00 17:52:21.236 : echo: do_blocking_move_to: (40.00, 40.00, 6.38) 17:52:27.155 : echo: run_z_probe > current_position: (40.00, 40.00, -3.91) 17:52:27.155 : echo: <<< probe_pt 17:52:27.159 : echo: z_before = (between) 6.09 17:52:27.159 : echo: probe_pt >>> 17:52:27.163 : echo: > ProbeAction:0 > current_position: (40.00, 40.00, -3.91) 17:52:27.171 : echo: Z Raise to z_before 6.09 > do_blocking_move_to_z 6.09 17:52:27.175 : echo: do_blocking_move_to: (40.00, 40.00, 6.09) 17:52:30.566 : echo: > do_blocking_move_to_xy 40.00, 86.00 17:52:30.570 : echo: do_blocking_move_to: (40.00, 86.00, 6.09) 17:52:36.453 : echo: run_z_probe > current_position: (40.00, 86.00, -4.26) 17:52:36.457 : echo: <<< probe_pt 17:52:36.457 : echo: z_before = (between) 5.74 17:52:36.461 : echo: probe_pt >>> 17:52:36.465 : echo: > ProbeAction:0 > current_position: (40.00, 86.00, -4.26) 17:52:36.469 : echo: Z Raise to z_before 5.74 > do_blocking_move_to_z 5.74 17:52:36.473 : echo: do_blocking_move_to: (40.00, 86.00, 5.74) 17:52:39.868 : echo: > do_blocking_move_to_xy 86.00, 86.00 17:52:39.872 : echo: do_blocking_move_to: (86.00, 86.00, 5.74) 17:52:44.955 : echo: run_z_probe > current_position: (86.00, 86.00, -2.14) 17:52:44.955 : echo: <<< probe_pt 17:52:44.959 : echo: z_before = (between) 7.86 17:52:44.959 : echo: probe_pt >>> 17:52:44.967 : echo: > ProbeAction:0 > current_position: (86.00, 86.00, -2.14) 17:52:44.972 : echo: Z Raise to z_before 7.86 > do_blocking_move_to_z 7.86 17:52:44.975 : echo: do_blocking_move_to: (86.00, 86.00, 7.86) 17:52:48.367 : echo: > do_blocking_move_to_xy 132.00, 86.00 17:52:48.371 : echo: do_blocking_move_to: (132.00, 86.00, 7.86) 17:52:54.368 : echo: run_z_probe > current_position: (132.00, 86.00, -2.80) 17:52:54.368 : echo: <<< probe_pt 17:52:54.372 : echo: z_before = (between) 7.20 17:52:54.372 : echo: probe_pt >>> 17:52:54.376 : echo: > ProbeAction:0 > current_position: (132.00, 86.00, -2.80) 17:52:54.384 : echo: Z Raise to z_before 7.20 > do_blocking_move_to_z 7.20 17:52:54.388 : echo: do_blocking_move_to: (132.00, 86.00, 7.20) 17:52:57.779 : echo: > do_blocking_move_to_xy 178.00, 86.00 17:52:57.783 : echo: do_blocking_move_to: (178.00, 86.00, 7.20) 17:53:03.870 : echo: run_z_probe > current_position: (178.00, 86.00, -3.54) 17:53:03.870 : echo: <<< probe_pt 17:53:03.874 : echo: z_before = (between) 6.46 17:53:03.878 : echo: probe_pt >>> 17:53:03.882 : echo: > ProbeAction:0 > current_position: (178.00, 86.00, -3.54) 17:53:03.886 : echo: Z Raise to z_before 6.46 > do_blocking_move_to_z 6.46 17:53:03.890 : echo: do_blocking_move_to: (178.00, 86.00, 6.46) 17:53:06.606 : echo: Now fresh file: INFO.CFG 17:53:06.623 : echo: Writing to file: INFO.CFG 17:53:07.328 : echo: > do_blocking_move_to_xy 178.00, 132.00 17:53:07.331 : echo: do_blocking_move_to: (178.00, 132.00, 6.46) 17:53:13.446 : echo: run_z_probe > current_position: (178.00, 132.00, -4.56) 17:53:13.446 : echo: <<< probe_pt 17:53:13.450 : echo: z_before = (between) 5.44 17:53:13.454 : echo: probe_pt >>> 17:53:13.458 : echo: > ProbeAction:0 > current_position: (178.00, 132.00, -4.56) 17:53:13.463 : echo: Z Raise to z_before 5.44 > do_blocking_move_to_z 5.44 17:53:13.467 : echo: do_blocking_move_to: (178.00, 132.00, 5.44) 17:53:16.862 : echo: > do_blocking_move_to_xy 132.00, 132.00 17:53:16.866 : echo: do_blocking_move_to: (132.00, 132.00, 5.44) 17:53:22.186 : echo: run_z_probe > current_position: (132.00, 132.00, -3.22) 17:53:22.190 : echo: <<< probe_pt 17:53:22.190 : echo: z_before = (between) 6.78 17:53:22.194 : echo: probe_pt >>> 17:53:22.198 : echo: > ProbeAction:0 > current_position: (132.00, 132.00, -3.22) 17:53:22.207 : echo: Z Raise to z_before 6.78 > do_blocking_move_to_z 6.78 17:53:22.210 : echo: do_blocking_move_to: (132.00, 132.00, 6.78) 17:53:25.603 : echo: > do_blocking_move_to_xy 86.00, 132.00 17:53:25.607 : echo: do_blocking_move_to: (86.00, 132.00, 6.78) 17:53:31.488 : echo: run_z_probe > current_position: (86.00, 132.00, -3.53) 17:53:31.488 : echo: <<< probe_pt 17:53:31.492 : echo: z_before = (between) 6.48 17:53:31.492 : echo: probe_pt >>> 17:53:31.501 : echo: > ProbeAction:0 > current_position: (86.00, 132.00, -3.53) 17:53:31.505 : echo: Z Raise to z_before 6.48 > do_blocking_move_to_z 6.48 17:53:31.509 : echo: do_blocking_move_to: (86.00, 132.00, 6.48) 17:53:34.900 : echo: > do_blocking_move_to_xy 40.00, 132.00 17:53:34.904 : echo: do_blocking_move_to: (40.00, 132.00, 6.48) 17:53:41.044 : echo: run_z_probe > current_position: (40.00, 132.00, -4.39) 17:53:41.044 : echo: <<< probe_pt 17:53:41.048 : echo: z_before = (between) 5.61 17:53:41.049 : echo: probe_pt >>> 17:53:41.057 : echo: > ProbeAction:0 > current_position: (40.00, 132.00, -4.39) 17:53:41.061 : echo: Z Raise to z_before 5.61 > do_blocking_move_to_z 5.61 17:53:41.065 : echo: do_blocking_move_to: (40.00, 132.00, 5.61) 17:53:44.460 : echo: > do_blocking_move_to_xy 40.00, 178.00 17:53:44.464 : echo: do_blocking_move_to: (40.00, 178.00, 5.61) 17:53:50.264 : echo: run_z_probe > current_position: (40.00, 178.00, -4.47) 17:53:50.264 : echo: <<< probe_pt 17:53:50.268 : echo: z_before = (between) 5.53 17:53:50.268 : echo: probe_pt >>> 17:53:50.276 : echo: > ProbeAction:0 > current_position: (40.00, 178.00, -4.47) 17:53:50.280 : echo: Z Raise to z_before 5.53 > do_blocking_move_to_z 5.53 17:53:50.284 : echo: do_blocking_move_to: (40.00, 178.00, 5.53) 17:53:53.679 : echo: > do_blocking_move_to_xy 86.00, 178.00 17:53:53.683 : echo: do_blocking_move_to: (86.00, 178.00, 5.53) 17:53:59.308 : echo: run_z_probe > current_position: (86.00, 178.00, -4.03) 17:53:59.312 : echo: <<< probe_pt 17:53:59.312 : echo: z_before = (between) 5.97 17:53:59.316 : echo: probe_pt >>> 17:53:59.320 : echo: > ProbeAction:0 > current_position: (86.00, 178.00, -4.03) 17:53:59.328 : echo: Z Raise to z_before 5.97 > do_blocking_move_to_z 5.97 17:53:59.332 : echo: do_blocking_move_to: (86.00, 178.00, 5.97) 17:54:02.723 : echo: > do_blocking_move_to_xy 132.00, 178.00 17:54:02.727 : echo: do_blocking_move_to: (132.00, 178.00, 5.97) 17:54:08.363 : echo: run_z_probe > current_position: (132.00, 178.00, -3.47) 17:54:08.363 : echo: <<< probe_pt 17:54:08.367 : echo: z_before = (between) 6.53 17:54:08.367 : echo: probe_pt >>> 17:54:08.375 : echo: > ProbeAction:2 > current_position: (132.00, 178.00, -3.47) 17:54:08.379 : echo: Z Raise to z_before 6.53 > do_blocking_move_to_z 6.53 17:54:08.383 : echo: do_blocking_move_to: (132.00, 178.00, 6.53) 17:54:11.779 : echo: > do_blocking_move_to_xy 178.00, 178.00 17:54:11.782 : echo: do_blocking_move_to: (178.00, 178.00, 6.53) 17:54:17.743 : echo: run_z_probe > current_position: (178.00, 178.00, -3.94) 17:54:17.747 : echo: > ProbeStow (stow_z_probe will do Z Raise) 17:54:17.751 : echo: stow_z_probe > current_position: (178.00, 178.00, -3.94) 17:54:17.751 : echo: <<< probe_pt 17:54:17.759 : echo: > probing complete > current_position: (178.00, 178.00, -3.94) 17:54:17.763 : echo: setup_for_endstop_move > enable_endstops(false) 17:54:17.784 : echo: Eqn coefficients: a: 0.00212431 b: -0.00314742 d: -3.59402823 17:54:17.788 : echo: planeNormal x: -0.002124 y: 0.003147 z: 1.000000 17:54:17.796 : echo: set_bed_level_equation_lsq > current_position: (177.99, 178.01, -3.75) 17:54:17.804 : echo: Bed Level Correction Matrix: 17:54:17.804 : echo: +0.999998 +0.000000 +0.002124 17:54:17.808 : echo: +0.000007 +0.999995 -0.003147 17:54:17.812 : echo: -0.002124 +0.003147 +0.999993 17:54:17.821 : echo: > AFTER apply_rotation_xyz > current_position[Z_AXIS]= -0.70586 17:54:17.821 : echo: <<< gcode_G29 17:54:17.829 : ok X:177.99 Y:178.01 Z:-0.71 E:0.00 Count X: 178.00 Y:178.01 Z:-0.89 17:54:17.829 : ok
17:54:56.853 : N268 M48 *51 17:54:56.858 : echo: N268 M48 *51 17:54:56.862 : echo: M48 Z-Probe Repeatability test 17:55:00.257 : echo: deploy_z_probe > current_position: (178.00, 178.01, 9.11) 17:55:00.261 : echo: setup_for_endstop_move > enable_endstops(true) 17:55:05.749 : echo: run_z_probe > current_position: (178.00, 178.01, -0.90) 17:55:08.321 : echo: do_blocking_move_to: (178.00, 178.01, 9.10) 17:55:08.329 : echo: setup_for_endstop_move > enable_endstops(true) 17:55:13.761 : echo: run_z_probe > current_position: (178.00, 178.01, -0.90) 17:55:17.152 : echo: do_blocking_move_to: (178.00, 178.01, 9.10) 17:55:17.160 : echo: setup_for_endstop_move > enable_endstops(true) 17:55:22.591 : echo: run_z_probe > current_position: (178.00, 178.01, -0.90) 17:55:25.984 : echo: do_blocking_move_to: (178.00, 178.01, 9.10) 17:55:25.991 : echo: setup_for_endstop_move > enable_endstops(true) 17:55:31.419 : echo: run_z_probe > current_position: (178.00, 178.01, -0.89) 17:55:34.810 : echo: do_blocking_move_to: (178.00, 178.01, 9.10) 17:55:34.818 : echo: setup_for_endstop_move > enable_endstops(true) 17:55:36.923 : Communication timeout - reset send buffer block 17:55:40.257 : echo: run_z_probe > current_position: (178.00, 178.01, -0.90) 17:55:43.649 : echo: do_blocking_move_to: (178.00, 178.01, 9.10) 17:55:43.653 : echo: setup_for_endstop_move > enable_endstops(true) 17:55:49.104 : echo: run_z_probe > current_position: (178.00, 178.01, -0.90) 17:55:52.495 : echo: do_blocking_move_to: (178.00, 178.01, 9.10) 17:55:52.503 : echo: setup_for_endstop_move > enable_endstops(true) 17:55:57.979 : echo: run_z_probe > current_position: (178.00, 178.01, -0.89) 17:56:01.372 : echo: do_blocking_move_to: (178.00, 178.01, 9.10) 17:56:01.376 : echo: setup_for_endstop_move > enable_endstops(true) 17:56:06.876 : echo: run_z_probe > current_position: (178.00, 178.01, -0.90) 17:56:10.271 : echo: do_blocking_move_to: (178.00, 178.01, 9.10) 17:56:10.275 : echo: setup_for_endstop_move > enable_endstops(true) 17:56:15.760 : echo: run_z_probe > current_position: (178.00, 178.01, -0.90) 17:56:16.997 : Communication timeout - reset send buffer block 17:56:19.156 : echo: do_blocking_move_to: (178.00, 178.01, 9.10) 17:56:19.160 : echo: setup_for_endstop_move > enable_endstops(true) 17:56:24.652 : echo: run_z_probe > current_position: (178.00, 178.01, -0.91) 17:56:28.051 : echo: do_blocking_move_to: (178.00, 178.01, 9.10) 17:56:28.055 : echo: setup_for_endstop_move > enable_endstops(true) 17:56:33.543 : echo: run_z_probe > current_position: (178.00, 178.01, -0.91) 17:56:36.944 : echo: stow_z_probe > current_position: (178.00, 178.01, -0.91) 17:56:37.947 : echo: setup_for_endstop_move > enable_endstops(false) 17:56:37.947 : Mean: -0.898562 17:56:37.951 : Standard Deviation: 0.005870 17:56:37.951 : ok
Re: PiBot Optical Reflection Endstop October 26, 2015 03:59PM |
Re: PiBot Optical Reflection Endstop October 27, 2015 04:36PM |
// Define this to set a custom name for your generic Mendel, // Displayed in the LCD "Ready" message #define CUSTOM_MACHINE_NAME "albo" //=========================================================================== //=============================Mechanical Settings=========================== //=========================================================================== // coarse Endstop Settings //#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors #ifndef ENDSTOPPULLUPS // fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined //#define ENDSTOPPULLUP_XMIN //#define ENDSTOPPULLUP_YMIN //#define ENDSTOPPULLUP_ZMIN #define ENDSTOPPULLUP_Z2MIN #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_Z2MAX #define ENDSTOPPULLUP_ZPROBE #define ENDSTOPPULLUP_EMIN #endif // Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup). #define X_MIN_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define Y_MIN_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define Z_MIN_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define Z2_MIN_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define X_MAX_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define Y_MAX_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define Z_MAX_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define Z2_MAX_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define Z_PROBE_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define E_MIN_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. // ENDSTOP SETTINGS: // Sets direction of endstop when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 #define E_HOME_DIR -1 #define min_software_endstops false // If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops false // If true, axis won't move to coordinates greater than the defined lengths below. // For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1 #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 // For all extruder // Disables axis when it's not being used. #define DISABLE_X false #define DISABLE_Y false #define DISABLE_Z false #define DISABLE_E false // For all extruder #define DISABLE_INACTIVE_EXTRUDER false //disable only inactive extruder and keep active extruder enabled // Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way. #define INVERT_X_DIR true #define INVERT_Y_DIR false #define INVERT_Z_DIR true #define INVERT_E0_DIR false #define INVERT_E1_DIR false #define INVERT_E2_DIR false #define INVERT_E3_DIR false // Travel limits after homing (units are in mm) #define X_MAX_POS 150 #define X_MIN_POS 0 #define Y_MAX_POS 150 #define Y_MIN_POS 0 #define Z_MAX_POS 105 #define Z_MIN_POS 0 #define E_MIN_POS 0 //===================================================================================== //============================= Bed Manual or Auto Leveling =========================== //===================================================================================== // set the rectangle in which to probe in manual or automatic #define LEFT_PROBE_BED_POSITION 20 #define RIGHT_PROBE_BED_POSITION 130 #define FRONT_PROBE_BED_POSITION 20 #define BACK_PROBE_BED_POSITION 130 #define XY_TRAVEL_SPEED 10000 // X and Y axis travel speed between probes, in mm/min //If you have enabled the Auto Bed Levelling and are using the same Z Probe for Z Homing, //it is highly recommended you let this Z SAFE HOMING enabled!!! #define Z_SAFE_HOMING #ifdef Z_SAFE_HOMING #define Z_SAFE_HOMING_X_POINT 75 // X point for Z homing when homing all axis (G28) or homing Z #define Z_SAFE_HOMING_Y_POINT 75 // Y point for Z homing when homing all axis (G28) or homing Z #endif #define ENABLE_AUTO_BED_LEVELING // Delete the comment to enable (ABL) #define Z_PROBE_REPEATABILITY_TEST // Delete the comment to enable #ifdef ENABLE_AUTO_BED_LEVELING // There are 2 different ways to specify probing locations // // - "grid" mode // Probe several points in a rectangular grid. // You specify the rectangle and the density of sample points. // This mode is preferred because there are more measurements. // // - "3-point" mode // Probe 3 arbitrary points on the bed (that aren't colinear) // You specify the XY coordinates of all 3 points. // Enable this to sample the bed in a grid (least squares solution) // Note: this feature generates 10KB extra code size #define AUTO_BED_LEVELING_GRID #ifdef AUTO_BED_LEVELING_GRID #define MIN_PROBE_EDGE 10 // The probe square sides can be no smaller than this // Set the number of grid points per dimension // You probably don't need more than 3 (squared=9) #define AUTO_BED_LEVELING_GRID_POINTS 4 #else // not AUTO_BED_LEVELING_GRID // Arbitrary points to probe. A simple cross-product // is used to estimate the plane of the bed. #define ABL_PROBE_PT_1_X 15 #define ABL_PROBE_PT_1_Y 180 #define ABL_PROBE_PT_2_X 15 #define ABL_PROBE_PT_2_Y 15 #define ABL_PROBE_PT_3_X 180 #define ABL_PROBE_PT_3_Y 15 #endif // AUTO_BED_LEVELING_GRID // Offsets to the probe relative to the extruder tip (Hotend - Probe) // X and Y offsets MUST be INTEGERS #define X_PROBE_OFFSET_FROM_EXTRUDER 0 // Probe on: -left +right #define Y_PROBE_OFFSET_FROM_EXTRUDER 0 // Probe on: -front +behind #define Z_PROBE_OFFSET_FROM_EXTRUDER -7.95 // -below (always!) #define Z_RAISE_BEFORE_HOMING 5 // (in mm) Raise Z before homing (G28) for Probe Clearance. // Be sure you have this distance over your Z_MAX_POS in case #define Z_RAISE_BEFORE_PROBING 5 // much the extruder will be raised before travelling to the first probing point. #define Z_RAISE_BETWEEN_PROBINGS 5 // much the extruder will be raised when travelling from between next probing points #define Z_RAISE_AFTER_PROBING 5 //How much the extruder will be raised after the last probing point. //#define Z_PROBE_SLED // turn on if you have a z-probe mounted on a sled like those designed by Charles Bell //#define SLED_DOCKING_OFFSET 5 // the extra distance the X axis must travel to pick up the sled. 0 should be fine but you can push it further if you'd like. //If defined, the Probe servo will be turned on only during movement and then turned off to avoid jerk //The value is the delay to turn the servo off after powered on - depends on the servo speed; 300ms is good value, but you can try lower it. //You MUST HAVE the SERVO ENDSTOPS defined to use here a value higher than zero otherwise your code will not compile. #define PROBE_SERVO_DEACTIVATION_DELAY 300 // Support for a dedicated Z PROBE endstop separate from the Z MIN endstop. // If you would like to use both a Z PROBE and a Z MIN endstop together or just a Z PROBE with a custom pin, uncomment #define Z PROBE ENDSTOP and read the instructions below. // If you want to still use the Z min endstop for homing, disable Z_SAFE_HOMING above. Eg; to park the head outside the bed area when homing with G28. // WARNING: The Z MIN endstop will need to set properly as it would without a Z PROBE to prevent head crashes and premature stopping during a print. // To use a separte Z PROBE endstop, you must have a Z_PROBE_PIN defined in the pins.h file for your control board. // If you are using a servo based Z PROBE, you will need to enable NUM_SERVOS, SERVO_ENDSTOPS and SERVO_ENDSTOPS_ANGLES in the R/C Servo below. // WARNING: Setting the wrong pin may have unexpected and potentially disastrous outcomes. Use with caution and do your homework. #define Z_PROBE_ENDSTOP #endif // ENABLE_AUTO_BED_LEVELING // The position of the homing switches //#define MANUAL_HOME_POSITIONS // If defined, MANUAL_*_HOME_POS below will be used //#define BED_CENTER_AT_0_0 // If defined, the center of the bed is at (X=0, Y=0) //Manual homing switch locations: #ifdef MANUAL_HOME_POSITIONS #define MANUAL_X_HOME_POS 0 #define MANUAL_Y_HOME_POS 0 #define MANUAL_Z_HOME_POS 0 #endif // MOVEMENT SETTINGS #define HOMING_FEEDRATE {50*60,50*60,6*60,0} // set the homing speeds (mm/min) // default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {160,160,3200,160,625,625,625} // X, Y, Z, E0, E1, E2, E3 default steps per unit #define DEFAULT_MAX_FEEDRATE {100,100,6,100,100,100,100} // X, Y, Z, E0, E1, E2, E3 (mm/sec) #define DEFAULT_RETRACTION_MAX_FEEDRATE {150,100,100,100} // E0, E1, E2, E3 (mm/sec) #define DEFAULT_MAX_ACCELERATION {1500,1500,50,1000,3000,3000,3000} // X, Y, Z, E0, E1, E2, E3 maximum start speed for accelerated moves. #define DEFAULT_ACCELERATION 1500 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 5000 // E max acceleration in mm/s^2 for retracts #define DEFAULT_TRAVEL_ACCELERATION 2000 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves // Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing). // The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder). // For the other hotends it is their distance from the extruder 0 hotend. //#define HOTEND_OFFSET_X {0.0, 5.00, 0.0, 0.0} // (in mm) for each extruder, offset of the hotend on the X axis //#define HOTEND_OFFSET_Y {0.0, 5.00, 0.0, 0.0} // (in mm) for each extruder, offset of the hotend on the Y axis // The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously) #define DEFAULT_XYJERK 10 // (mm/sec) #define DEFAULT_ZJERK 0.4 // (mm/sec) #define DEFAULT_EJERK 5 // (mm/sec) //=========================================================================== //=============================Additional Features=========================== //=========================================================================== // Custom M code points //#define CUSTOM_M_CODES #ifdef CUSTOM_M_CODES #define CUSTOM_M_CODE_SET_Z_PROBE_OFFSET 851 #define Z_PROBE_OFFSET_RANGE_MIN -20 #define Z_PROBE_OFFSET_RANGE_MAX 20 #endif
Re: PiBot Optical Reflection Endstop October 28, 2015 02:58AM |
Questo è strano ma che elettronica usi hai abilitato la EEprom ?Quote
almada
L'offset l'ho settato direttamente dal configuratore del firmware online ma se invio il comando M666 L mi ritorna sempre 0.00..
Dov'è che sbaglio? scusate se insisto, non voglio la pappa pronta, ma ci sto su da quasi 5 giorni e non ne vengo a capo...
Re: PiBot Optical Reflection Endstop October 28, 2015 03:42AM |
Re: PiBot Optical Reflection Endstop October 28, 2015 04:51AM |
Re: PiBot Optical Reflection Endstop October 28, 2015 06:58AM |
Re: PiBot Optical Reflection Endstop October 28, 2015 07:18AM |
Re: PiBot Optical Reflection Endstop October 28, 2015 07:36AM |
Re: PiBot Optical Reflection Endstop October 28, 2015 08:33AM |
Re: PiBot Optical Reflection Endstop October 28, 2015 11:56AM |
Re: PiBot Optical Reflection Endstop October 28, 2015 12:16PM |
Re: PiBot Optical Reflection Endstop October 28, 2015 01:02PM |
Re: PiBot Optical Reflection Endstop October 28, 2015 01:41PM |
appunto.. il disegno su thingiverse è di un mio amico, io ho preso spunto prendendo le parti che mi interessavano e le ho inglobate nell'immagine che ho allegato prima..Quote
Labieno
Forse mi sbaglio, ma quelo su thingiverse sembra diverso dal disegno allegato.
almada
se è per questo ne esiste anche un altro nell'universo delle cose, a mio avviso migliore visto che include una copertura per i sensori, io ho preso spunto proprio da quello per inglobarlo in maniera screwless sulla piastra del carrello della mia stampante..
Re: PiBot Optical Reflection Endstop October 28, 2015 02:28PM |
Re: PiBot Optical Reflection Endstop October 28, 2015 02:58PM |
Re: PiBot Optical Reflection Endstop October 28, 2015 04:50PM |
Re: PiBot Optical Reflection Endstop October 28, 2015 05:03PM |
Intanto un GRAZIE per la risposta..Quote
MagoKimbra
L'hai raccontata perfettamente e poi ti sei perso in un bicchiere d'acqua..
Gli end stop vengono attivati solo durante la home e non durante i movimenti normali quindi anche se si attiva l'ottico durante le fasi di movimento normale non viene rilevato dal fw. Durante la fase di home il pibot interviene 7/10 mm prima quindi sei apposto. Se succede per qualche motivo che il pibot non funzioni ecco che il sensore ottico su zmin ti salva il nozzle....
Re: PiBot Optical Reflection Endstop October 28, 2015 06:43PM |
Questo anche è simpatico e credo che la stasca per chiudere i led sia utile riesci a modificarlo realizando una L come quello da me allegato ovvero da 35mm e un foro a 15mm dalla fine ?Quote
almada
Re: PiBot Optical Reflection Endstop October 28, 2015 07:49PM |
Re: PiBot Optical Reflection Endstop October 28, 2015 07:51PM |
saviothecnic
almada
Grazie
