Re: Presentazione Alligator Board tutta italiana & Open June 23, 2015 10:44AM |
Re: Presentazione Alligator Board tutta italiana & Open June 23, 2015 10:57AM |
Re: Presentazione Alligator Board tutta italiana & Open June 25, 2015 02:18PM |
Re: Presentazione Alligator Board tutta italiana & Open June 26, 2015 04:52AM |
Re: Presentazione Alligator Board tutta italiana & Open June 26, 2015 05:21AM |
Re: Presentazione Alligator Board tutta italiana & Open June 26, 2015 06:00AM |
Re: Presentazione Alligator Board tutta italiana & Open July 03, 2015 11:21AM |
Re: Presentazione Alligator Board tutta italiana & Open July 03, 2015 11:24AM |
Re: Presentazione Alligator Board tutta italiana & Open July 04, 2015 03:58PM |
Re: Presentazione Alligator Board tutta italiana & Open July 07, 2015 09:55AM |
Re: Presentazione Alligator Board tutta italiana & Open July 07, 2015 12:41PM |
Re: Presentazione Alligator Board tutta italiana & Open July 07, 2015 05:06PM |
Re: Presentazione Alligator Board tutta italiana & Open July 07, 2015 05:20PM |
Re: Presentazione Alligator Board tutta italiana & Open July 10, 2015 01:32PM |
Re: Presentazione Alligator Board tutta italiana & Open July 13, 2015 05:22AM |
Re: Presentazione Alligator Board tutta italiana & Open July 13, 2015 12:00PM |
Re: Presentazione Alligator Board tutta italiana & Open July 13, 2015 04:47PM |
Re: Presentazione Alligator Board tutta italiana & Open July 14, 2015 01:59PM |
Help stepper motor!!!!! July 23, 2015 03:29PM |
Re: Help stepper motor!!!!! July 26, 2015 04:37AM |
yogurt
Non riesco a configurare i motori.
I motori sono questi:
Modello (Model) : Wantai 42byghw811
Coppia statica (Holding Torque) : 4.8 Kg/cm (47 N/cm)
Albero (Shaft) : 5 mm
Tensione nominale (Rated Voltage) : 3.1 V
Angolo di Passo (Stepping Angle) : 1.8°
Corrente nominale (Rated Current) : 2.5 A
Numero dei Fili (Number of Leads) : 4
Lunghezza Fili (Lead Length) : 30 cm
Peso (Weight) : 370 g
Sono a 2.5A quindi dovrei mettere 100% ma qunado li faccio muovere fanno solo un piccolo passo poi sifermano!!
Cosa sto sbagliando??
Update, enstop ok wiring ok testato anche stepper da 1.7 amp a 68
i motori non si muovono, sono fermi in posizione.
firmware repetiere v0.92
(con ramps tutto funziona OK)
Grazie!!
Re: Help stepper motor!!!!! July 26, 2015 05:12AM |
Re: Help stepper motor!!!!! July 26, 2015 03:22PM |
ManuHC
yogurt
Grazie!!
Nella stringa di codice CURRENT MOTOR che valori hai? Per quanto riguarda questa board il valore massimo è 255 che sta a rappresentare l'erogazione di 2,5A. Il fatto che il motore sia da 2.5 non significa che tu debba necessariamente dargli il massimo della potenza possibile.
Io ad esempio ho 110, 110, 110, 100, 100 che attraverso la proporzione se non ricordo male gli do circa 1,20A. e questo(unito ad un buon flusso d'aria) manda avanti i motori e non li fa scaldare eccessivamente
Re: Help stepper motor!!!!! July 26, 2015 03:24PM |
Re: Help stepper motor!!!!! July 26, 2015 03:25PM |
Re: Help stepper motor!!!!! July 27, 2015 06:10AM |
Re: Help stepper motor!!!!! July 27, 2015 06:17AM |
Re: Help stepper motor!!!!! July 27, 2015 07:05AM |
maralb
la versione originale presa dal Github di Repetier devi cambiarli a mano nel confi anche se usi il configuratore Online e va in Pecentuale
se usate la pappa pronta scaricabile dal Github di alligator/marcoantonini dovete metterla in voltaggio
in ogni caso penso che il problema di Yougurt non sia legato al settagio degli Amper
vedrete che pian piano si allineranno le cose
Re: Help stepper motor!!!!! July 27, 2015 07:42AM |
maralb
allega il configutation.h che gli diamo uno sguardo
Re: Help stepper motor!!!!! July 27, 2015 08:48AM |
Re: Presentazione Alligator Board tutta italiana & Open July 27, 2015 12:13PM |
