Re: FuseBox ~$300 CoreXY Printer May 24, 2016 11:37AM |
Re: FuseBox ~$300 CoreXY Printer May 24, 2016 01:14PM |
Re: FuseBox ~$300 CoreXY Printer May 24, 2016 02:02PM |
Re: FuseBox ~$300 CoreXY Printer May 24, 2016 03:32PM |
widespreaddeadhead
Someone posted a remix on thingiverse for a blower fan attachment, might work well.Quote
godefroi
The other thing the carriage could desperately use is improved print cooling. Half of the 40mm fan is not really enough.
Re: FuseBox ~$300 CoreXY Printer May 24, 2016 04:33PM |
realthor
You might be referring to this one, just stumbled on it earlier today: [www.thingiverse.com]
I thought a link/image could help.
Re: FuseBox ~$300 CoreXY Printer May 24, 2016 06:13PM |
lkcl
bottom line: if you use this blower-fan design you are pretty much guaranteed to run into difficulties, affecting the quality of parts as well as risk destroying expensive parts of your printer.
Re: FuseBox ~$300 CoreXY Printer May 24, 2016 06:24PM |
pretty nice analysis...|
Re: FuseBox ~$300 CoreXY Printer May 24, 2016 06:52PM |
phord
lkcl
[www.desiquintans.com]
Re: FuseBox ~$300 CoreXY Printer June 07, 2016 09:45AM |
Re: FuseBox ~$300 CoreXY Printer June 07, 2016 10:57AM |
Re: FuseBox ~$300 CoreXY Printer June 07, 2016 11:48AM |
Re: FuseBox ~$300 CoreXY Printer June 07, 2016 12:13PM |
Re: FuseBox ~$300 CoreXY Printer June 07, 2016 02:02PM |
Re: FuseBox ~$300 CoreXY Printer June 07, 2016 02:07PM |
Re: FuseBox ~$300 CoreXY Printer June 08, 2016 08:36AM |
Re: FuseBox ~$300 CoreXY Printer June 10, 2016 09:13PM |
godefroi
Re: FuseBox ~$300 CoreXY Printer June 10, 2016 09:35PM |
Re: FuseBox ~$300 CoreXY Printer June 12, 2016 07:45PM |
Re: FuseBox ~$300 CoreXY Printer June 12, 2016 07:53PM |
godefroi
Stranded is a must for the bed, as it's always moving. For the PSU, solid is better.
Re: FuseBox ~$300 CoreXY Printer June 13, 2016 09:53AM |
Re: FuseBox ~$300 CoreXY Printer June 13, 2016 12:49PM |
Re: FuseBox ~$300 CoreXY Printer June 13, 2016 12:52PM |
Ax
As a note, it may be a bit more printing than you want to do, but if you reprint the carriers, carriage and layer fan assembly from the FB2020, it will all just drop into the Fusebox.
Re: FuseBox ~$300 CoreXY Printer July 19, 2016 11:43AM |
Re: FuseBox ~$300 CoreXY Printer July 19, 2016 12:10PM |
Re: FuseBox ~$300 CoreXY Printer July 19, 2016 01:11PM |
stephenrc
Use [www.repetier.com] to make the configuration.h. It makes it easy to setup Repetier.
Re: FuseBox ~$300 CoreXY Printer July 19, 2016 03:26PM |
widespreaddeadhead
stephenrc
Great tool, thanks!
Should I enable watchdog?
Re: FuseBox ~$300 CoreXY Printer July 20, 2016 08:52AM |
Re: FuseBox ~$300 CoreXY Printer July 20, 2016 02:16PM |
widespreaddeadhead
Uploaded my modified firmware, but nothing moves. The full graphics controller doesn't light up, so I connected through repetier-host and when I home the motors they just hum, the hotend and heat bed are off but say they are at printing temps, and when I do turn them on they don't heat up. Any clues?
I still need to adjust the pots for the motors, but having none of them move worried me a bit. I'll double check I have the right thermistor selected in the firmware again. No idea about the graphics controller.
Thanks!
Re: FuseBox ~$300 CoreXY Printer July 21, 2016 09:35PM |
os3dp
It sounds like you may be missing one of your voltages. 12 volts or even 5 volts, though I'd guess first at 5 volts is missing. I believe there are some jumpers on RAMPS for the 5 volt section.
-os3dp
Re: FuseBox ~$300 CoreXY Printer July 21, 2016 10:39PM |
rinter set into dry run mode until restart!
