Re: Foldable, portable CoreXY (Fusebox derivative) April 28, 2016 09:15PM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 29, 2016 06:44PM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 29, 2016 06:48PM |
FA-MAS
For your bearings binding up, check to see if the rubber seals at the end are dragging. I found that to be a problem when I got cheap bearings. I ended up trimming the lip off of them.
Re: Foldable, portable CoreXY (Fusebox derivative) May 03, 2016 01:12PM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 03, 2016 06:51PM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 04, 2016 08:57AM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 05, 2016 12:22PM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 06, 2016 05:33AM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 06, 2016 06:14PM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 07, 2016 01:15PM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 07, 2016 04:28PM |
Anonymous User
Re: Foldable, portable CoreXY (Fusebox derivative) May 08, 2016 03:32AM |
cozmicray
I understand that you will be printing on a bus or train while moving from location to location
and watched your video of design mistakes
What will happen to your current printer used to print parts for your design
Maybe an RV with storage space for 3D printers and machine shop?
Re: Foldable, portable CoreXY (Fusebox derivative) May 08, 2016 06:09AM |
cozmicray
Not to pee in your cheerios
but wouldn't a design like this "Backpack printer"
be mo better?
Re: Foldable, portable CoreXY (Fusebox derivative) May 08, 2016 04:43PM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 09, 2016 07:24AM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 11, 2016 07:49AM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 11, 2016 02:58PM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 11, 2016 03:14PM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 11, 2016 03:22PM |
cozmicray
Use a proper hinge at the bottom.
If you use one with large high lobes (where rotation pins go thru)
you could slide a pin in (off the rotational axis) to lock in place
Re: Foldable, portable CoreXY (Fusebox derivative) May 11, 2016 03:52PM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 11, 2016 04:16PM |
cozmicray
Hey
This is not a tractor truck!
if you printed a hinge like I showed, very wide, many lobes
it would take the load.
Two 20 cm hinges on each end --- if you must piano hinge in middle
(hard to match up rotation axis)
Pin -- piece of piano wire -- you could make 20 of them
make a slot to stow them while running thru airport with printer.
(good luck explaining it to security guys)
Gopro mount hinges like this take a real beating and still work.
Put some nylon in your printer
I really think beefy PLA would do it?
Re: Foldable, portable CoreXY (Fusebox derivative) May 11, 2016 06:27PM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 12, 2016 05:16AM |
cozmicray
Well if your out and about
Find some GoPro fittings
the tripod or attachment hinges --- play with them
But you could always use your special kitchen mount Haas CNC machine
to crank out some aerospace spec titanium hinges
Hey look no fasteners -- won't have to bugger up screw head with kitchen knife?
Re: Foldable, portable CoreXY (Fusebox derivative) May 12, 2016 05:21AM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 12, 2016 11:55AM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 12, 2016 12:25PM |
cozmicray
From your video
It's NOT foldable, it is collapsible
I thought it folded along the bottom split
Where are electronics stowed?
How about a time lapse of the 6 hour long assembly
from packed configuration to ready to use.
You should really remove your doll / action figure from your workbench or is that for scale?
FWIW
I would think something like a Mendalmax 2 or Aluminatus
with folding gantry would be much better and faster to snap up gantry and print.
hmmm trinitylabs went belly-up, oh well. anyway, yes, looks like the same as the mendelmax2 - minimum 450mm probably 500mm depth even with a 200x200 bed, then extra on the outside for a packing box.... naah.Quote
3D printing >> Foldable Printer >>> Frustration >>> foldable coreXY >>> insanity >>> lkcl
i'd add a few extra steps in there, one being "bang head against brick wall" oh wait that's covered by "frustration"....|
Re: Foldable, portable CoreXY (Fusebox derivative) May 12, 2016 12:48PM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 12, 2016 12:53PM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 12, 2016 07:41PM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 12, 2016 08:00PM |
cozmicray
Is there a spec that it has to be able to fit in overhead bin on plane?
You can print stuff for flight attendants or parts to McGiver the aircraft?
