Re: Foldable, portable CoreXY (Fusebox derivative) May 13, 2016 06:14AM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 13, 2016 05:43PM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 14, 2016 07:41AM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 14, 2016 09:22AM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 14, 2016 10:18AM |
Koko76
What is your acceleration set to?
they've been in an original reprap, and absolutely hammered. the original reprap, if you recall, uses bits of plastic around non-precision-machined plain steel rods (!) so the motors were pretty much maxed out, poor things. anyway they're doing fine at 1.5A.|
Re: Foldable, portable CoreXY (Fusebox derivative) May 14, 2016 11:10AM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 14, 2016 11:58AM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 14, 2016 12:25PM |
Koko76
Mm/sec^2 is the unit you are looking for.
To each their own, but I consider none of that to be acceptable print quality.
Re: Foldable, portable CoreXY (Fusebox derivative) May 14, 2016 01:10PM |
Koko76
Re: Foldable, portable CoreXY (Fusebox derivative) May 14, 2016 01:41PM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 14, 2016 03:24PM |
Koko76
I have no desire to do work for you in order for you to perform a "comparative engineering quality control analysis". I don't print at those sizes or layer heights. If parts that my printer made looked like that, I would not be claiming that those speeds were valid. Makes zero difference to me what your design is, I just look at the output. Your opinion is different, it's your machine and you make the output to whatever standards you want, do whatever you like.
Re: Foldable, portable CoreXY (Fusebox derivative) May 14, 2016 06:18PM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 15, 2016 04:56AM |
cozmicray
Why not just do a search for Voronoi LED Egg tealight shade images
and use those for comparison.
Is the Voronoi LED Egg tealight shade a good test?
I don't know what is a good test for 0.6mm nozzle and 5000 mm/sec speed?
Re: Foldable, portable CoreXY (Fusebox derivative) May 15, 2016 05:58AM |
Koko76
Mm/sec^2 is the unit you are looking for. To each their own, but I consider none of that to be acceptable print quality.
Re: Foldable, portable CoreXY (Fusebox derivative) May 15, 2016 06:50AM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 17, 2016 03:51PM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 19, 2016 12:32PM |
pen25
looks good. congrats on getting this to work. how well does it maintain print calibration when you fold it move it and set it back up to print?
i did however get a "fluke" where i only had to make a tiny adjustment to only one of the 3-point levelling points. however in the v2, the front z-axis lead screws are separate assemblies that have to be removed and stowed, and the belt is loose and must be reattached. so, apologies: it's something that i can live with, but some people may not. ehhh can't have everything.
Re: Foldable, portable CoreXY (Fusebox derivative) May 19, 2016 12:46PM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 19, 2016 12:58PM |
lkcl
here's a photo of the proof-of-concept (1-in-2 scale) which took only a couple of hours to mock up, and, importantly, allowed things to be "moved" so that they could be verified as having the right amount of travel and clearance:
Re: Foldable, portable CoreXY (Fusebox derivative) May 19, 2016 02:47PM |
dc42
lkcl
A concern I have with that photo is that the belts are only going round the motor pulleys for about 90 degrees. Is that really enough, especially if you will be using 16-tooth pulleys? I would have aimed for 180 degrees by moving the idler pulleys.
Re: Foldable, portable CoreXY (Fusebox derivative) May 19, 2016 03:12PM |
deckingman
Or add a few more idlers - there's only 19 plus 2 motor pulleys.
amazingly it's actually not as many as are in the current sandwich200 v1, because i had 6 in the printbed cantilevered arms, and the corexy motors are inboard so required 4 more idlers than most people would have in a CoreXY. a trade-off between compactness and number-of-idlers that i was happy to make a decision on. oh, and four LM8UUs.|
Re: Foldable, portable CoreXY (Fusebox derivative) May 19, 2016 03:18PM |
dc42
lkcl
Re: Foldable, portable CoreXY (Fusebox derivative) May 20, 2016 07:23AM |
dc42
lkcl
i'll work something out.|
Re: Foldable, portable CoreXY (Fusebox derivative) May 20, 2016 11:02PM |
I am crazy for continuing this insanity!!!!!|
Re: Foldable, portable CoreXY (Fusebox derivative) May 21, 2016 04:14AM |
cozmicray
I have lost track of pre-existing constraints
Maybe like this --- motors at corners
motors up, shafts pointing down
Use of a spring tension idler near motor,
gives you good contact arc on drive pulley
[attachment 78428 Plotter_Belt_2_j.jpg]
Re: Foldable, portable CoreXY (Fusebox derivative) May 21, 2016 07:04AM |
cozmicray
Re: Foldable, portable CoreXY (Fusebox derivative) May 21, 2016 12:06PM |
Re: Foldable, portable CoreXY (Fusebox derivative) May 21, 2016 12:18PM |
cozmicray
My sketch was not to scale at all, and the size of all components
is arbitrary.
Your requirements / constraints way beyond insanity or practicality.
Are you building 10 -15 coreXY mechanisms to swap out on top?
7 days to finish? I think it has been 7 months
Beyond insanity
i am reaaallly looking forward to a nice calm time when i don't have to focus on this quite so hard...|
Re: Foldable, portable CoreXY (Fusebox derivative) May 22, 2016 01:07PM |
cozmicray
I believe these requirements will be used for just ONE printer
Re: Foldable, portable CoreXY (Fusebox derivative) May 24, 2016 04:24PM |
