Re: My coreXY design is progressing to the build stage May 20, 2016 08:10AM |
Re: My coreXY design is progressing to the build stage May 20, 2016 10:08PM |
Re: My coreXY design is progressing to the build stage May 30, 2016 06:51AM |
DD
GT2 belt is 1.38 mm thick. When you interdigitate the teeth by folding the belt, the thickness becomes 2.2 mm. The clamp has 2.2 mm slots that don't allow the belt teeth any room to slide over each other.
Re: My coreXY design is progressing to the build stage May 30, 2016 09:32AM |
JamesK
DD
Hi Mark, I used your approach, complete with measurements, to make cable clamps for my new Y axis carrier. Works a treat - many thanks!
Re: My coreXY design is progressing to the build stage May 30, 2016 09:34AM |
the_digital_dentist
JamesK
DD
Like that guy on the interwebs said, "pictures or it didn't happen!"
Re: My coreXY design is progressing to the build stage May 30, 2016 07:39PM |
Re: My coreXY design is progressing to the build stage May 31, 2016 12:16AM |
Re: My coreXY design is progressing to the build stage May 31, 2016 04:06AM |
Re: My coreXY design is progressing to the build stage May 31, 2016 06:56AM |
the_digital_dentist
I previously avoided trying to adjust belt tension at the clamps because of the difficulty of getting a tool in to make the adjustment because the tool has to be parallel and close to the belt. But, since the tension isn't something that has to be adjusted more than a few times in the life of the machine, why not?
Re: My coreXY design is progressing to the build stage May 31, 2016 09:02AM |
New belt clamp design June 23, 2016 12:27PM |
Re: My coreXY design is progressing to the build stage June 23, 2016 03:05PM |
Re: My coreXY design is progressing to the build stage June 23, 2016 08:12PM |
Re: My coreXY design is progressing to the build stage June 23, 2016 10:14PM |
Re: My coreXY design is progressing to the build stage June 25, 2016 07:52AM |
Re: My coreXY design is progressing to the build stage June 25, 2016 03:39PM |
Re: My coreXY design is progressing to the build stage July 07, 2016 12:44AM |
Re: My coreXY design is progressing to the build stage July 07, 2016 01:36AM |
Re: My coreXY design is progressing to the build stage July 07, 2016 04:35AM |
Re: My coreXY design is progressing to the build stage July 07, 2016 08:21AM |
hobbymods
Why did you use T slot extrusion when you're mounting the linears on flat plate?
RodF
Moving mass low, stationary mass high. That will work. Naturally I am interested in the level of accuracy you can achieve on the XY plane.
Re: My coreXY design is progressing to the build stage July 15, 2016 06:14AM |
Re: My coreXY design is progressing to the build stage July 15, 2016 07:14AM |
the_digital_dentist
Moving mass isn't particularly low- I estimate about 1.5 kg all-in but I think I'll be able to push it around with NEMA-17 motors and keep the noise level down. My other machine is a bit noisy and my wife complained about it so much that I took it to the makerspace and left it there about 4 months ago (to the delight of the members at the makerspace). I want this one to be quiet enough to keep and use at home.
the_digital_dentist
I am using 400 step/rev motors which gives a calculated step size of 6.5 um/ustep at 16:1 microstepping. I'm trying to keep everything rigid so that I have some hope of actually achieving that resolution, but I'm not 100% sure the motor torque will be adequate to print at at least 50 mm/sec. The 400 step/rev NEMA-17 motors have limited torque compared to the 200 step/rev motors that are available, and I was not able to locate a torque vs speed curve, so I picked motors that were similarly spec'd to one where I did find a speed vs torque curve. The calculations I did on the Oriental Motor site involved a lot of assumptions, and I tried to stay conservative, but we'll see once the motors arrive and I get everything set up. If I have to I can switch over to 200 step/rev NEMA-17 motors or 400 step/rev NEMA-23 motors and get higher torque.
Re: My coreXY design is progressing to the build stage July 15, 2016 07:30AM |
Re: My coreXY design is progressing to the build stage July 15, 2016 08:26AM |
Re: My coreXY design is progressing to the build stage July 16, 2016 08:59AM |
Re: My coreXY design is progressing to the build stage July 17, 2016 09:56AM |
Re: My coreXY design is progressing to the build stage July 17, 2016 07:39PM |
Re: My coreXY design is progressing to the build stage July 17, 2016 11:15PM |
the_digital_dentist
The extra bearing block on the X axis is there because the machine will be heated to print ABS. That heat causes the Y axis rails to move farther apart which, without the extra bearing block on the X axis, will put a very large side load on the Y axis bearing blocks, possibly causing the mechanism to bind.
That said, the belt tension is already putting some side load on the Y axis bearing blocks. I am looking into a design change to eliminate that.
Re: My coreXY design is progressing to the build stage July 18, 2016 06:56AM |
Re: My coreXY design is progressing to the build stage July 18, 2016 10:33AM |
