Re: My coreXY design is progressing to the build stage June 20, 2017 09:10AM |
Re: My coreXY design is progressing to the build stage June 22, 2017 07:47AM |
Re: My coreXY design is progressing to the build stage June 22, 2017 09:14AM |
Re: My coreXY design is progressing to the build stage June 22, 2017 10:09AM |
Re: My coreXY design is progressing to the build stage June 22, 2017 11:33AM |
Re: My coreXY design is progressing to the build stage June 24, 2017 10:05AM |
Re: My coreXY design is progressing to the build stage June 29, 2017 06:56PM |
Re: My coreXY design is progressing to the build stage June 29, 2017 09:51PM |
Re: My coreXY design is progressing to the build stage June 29, 2017 10:26PM |
Re: My coreXY design is progressing to the build stage July 03, 2017 04:27PM |
Re: My coreXY design is progressing to the build stage July 03, 2017 04:44PM |
Re: My coreXY design is progressing to the build stage July 03, 2017 06:46PM |
Re: My coreXY design is progressing to the build stage July 04, 2017 04:03PM |
Re: My coreXY design is progressing to the build stage July 04, 2017 04:29PM |
Re: My coreXY design is progressing to the build stage July 04, 2017 06:48PM |
Re: My coreXY design is progressing to the build stage July 05, 2017 08:16AM |
Qdeathstar
I am building this with a drill press. It's still a work in progress. I use higher quality digital calipers and a starret center punch to lay everything out, then I drill the holes. You need high quality drill bits and taps. When I made my measurements I made them from an uncut side so they would be the most accurate. I spent $60 on some taps and $90 on some drill bits for this project and they have been worth it. You need a vice. A higher quality x-y vice would be a good choice... You can cut the aluminum on a wood table saw with a blade for cutting aluminum. Just keep in mind this might shorten the life of table saw because the motor isn't protected from aluminum shavings... also, there is a fire hazard if your saw is full of saw dust....
Overall I am happy with the direction my printer is going. Buy extra metal
"Poor mans digital dentist build" on the forums here if you want to take a look.
Re: My coreXY design is progressing to the build stage July 05, 2017 09:44AM |
Re: My coreXY design is progressing to the build stage July 05, 2017 01:04PM |
Re: My coreXY design is progressing to the build stage July 05, 2017 01:09PM |
Re: My coreXY design is progressing to the build stage July 07, 2017 11:03AM |
Re: My coreXY design is progressing to the build stage July 07, 2017 11:29AM |
Re: My coreXY design is progressing to the build stage July 07, 2017 12:45PM |
Re: My coreXY design is progressing to the build stage July 07, 2017 01:33PM |
Re: My coreXY design is progressing to the build stage July 09, 2017 10:50AM |
Re: My coreXY design is progressing to the build stage July 12, 2017 04:46AM |
Re: My coreXY design is progressing to the build stage July 12, 2017 07:36AM |
Re: My coreXY design is progressing to the build stage July 12, 2017 09:31AM |
Re: My coreXY design is progressing to the build stage July 12, 2017 10:42AM |
Re: My coreXY design is progressing to the build stage July 12, 2017 11:45AM |
Re: My coreXY design is progressing to the build stage July 12, 2017 11:56AM |
