Re: My coreXY design is progressing to the build stage July 22, 2017 07:33PM |
Re: My coreXY design is progressing to the build stage July 25, 2017 03:56PM |
Re: My coreXY design is progressing to the build stage July 27, 2017 05:59PM |
Re: My coreXY design is progressing to the build stage July 28, 2017 12:21PM |
Re: My coreXY design is progressing to the build stage July 30, 2017 01:14AM |
Re: My coreXY design is progressing to the build stage July 30, 2017 01:22AM |
xyze
... I am using the same 750W Keenovo heat mat you are using and found that it can take nearly 5 minutes longer for the aluminium plate (305X305X6.35mm on my machine) to reach the target temperature when using the thermistor that is mounted under the mat. So unless you have a pause in your startup gcode, you are probably printing the first layer at a lower temperature than intended.
Josef
Re: My coreXY design is progressing to the build stage July 30, 2017 01:44PM |
Re: My coreXY design is progressing to the build stage July 30, 2017 02:57PM |
Re: My coreXY design is progressing to the build stage July 30, 2017 07:54PM |
Re: My coreXY design is progressing to the build stage July 31, 2017 12:08AM |
Re: My coreXY design is progressing to the build stage July 31, 2017 12:21PM |
Re: My coreXY design is progressing to the build stage August 05, 2017 03:32PM |
Re: My coreXY design is progressing to the build stage August 13, 2017 08:01PM |
Re: My coreXY design is progressing to the build stage August 14, 2017 03:30AM |
Re: My coreXY design is progressing to the build stage August 14, 2017 07:14AM |
Re: My coreXY design is progressing to the build stage August 14, 2017 07:52AM |
Re: My coreXY design is progressing to the build stage August 15, 2017 03:11AM |
Re: My coreXY design is progressing to the build stage August 15, 2017 07:27AM |
Re: My coreXY design is progressing to the build stage August 15, 2017 10:55PM |
Re: My coreXY design is progressing to the build stage August 18, 2017 06:14PM |
Re: My coreXY design is progressing to the build stage August 18, 2017 07:15PM |
Re: My coreXY design is progressing to the build stage August 20, 2017 04:03AM |
Re: My coreXY design is progressing to the build stage August 20, 2017 07:35AM |
Re: My coreXY design is progressing to the build stage August 20, 2017 12:40PM |
Re: My coreXY design is progressing to the build stage August 20, 2017 06:21PM |
Re: My coreXY design is progressing to the build stage August 25, 2017 04:32AM |
Re: My coreXY design is progressing to the build stage August 25, 2017 12:52PM |
Re: My coreXY design is progressing to the build stage August 28, 2017 11:03AM |
Re: My coreXY design is progressing to the build stage August 30, 2017 03:47AM |
Re: My coreXY design is progressing to the build stage August 30, 2017 07:26AM |
