Re: My coreXY design is progressing to the build stage February 16, 2018 04:07PM |
the_digital_dentist
Yup, keyed shaft. I didn't have the tooling to do it, so I contacted a guy on ebay who sells short keyed shafts for Rinos and paid him about $20 (IRIC) to make a long one. The keyed shaft can still slide out of the gearbox, so I used lock rings on either side of it, though placement of the pulleys and pillow blocks at the ends of the shaft could also keep the shaft from sliding out. In my build there is space between the pillow blocks and the pulleys, so the lock rings help. There aren't any forces along the length of the shaft, so it probably wouldn't move anyway, but why take the chance? You can either print lock rings to fit at the gearbox or spacers to fit between the pulleys and pillow block bearings. Either way does the job.
When I made the heater for the enclosure I thought I might just move the gearbox toward the left side of the shaft, but then I realized the shaft key is centered so I can't move the gearbox more than about 1 cm.
Re: My coreXY design is progressing to the build stage February 23, 2018 08:56AM |
Re: My coreXY design is progressing to the build stage February 23, 2018 10:27AM |
Re: My coreXY design is progressing to the build stage February 23, 2018 12:26PM |
the_digital_dentist
They aren't that hard to get: [www.amazon.com]
Amazon has a lot of ball stud listings, too, but you need to be able to adjust them by getting a wrench on them from under the bed plate, so be sure to leave room. The threads are pretty coarse, too, but manageable.
I don't think there are a lot of people copying the design, but maybe there will be a few more once I get the printed gear box finished and tested. That $100+ part is about half of a lot of people's printer budget.
Re: My coreXY design is progressing to the build stage February 23, 2018 12:50PM |
Re: My coreXY design is progressing to the build stage February 23, 2018 02:04PM |
Re: My coreXY design is progressing to the build stage February 23, 2018 03:48PM |
Re: My coreXY design is progressing to the build stage February 23, 2018 04:21PM |
Re: My coreXY design is progressing to the build stage February 23, 2018 05:34PM |
Re: My coreXY design is progressing to the build stage February 23, 2018 08:32PM |
Re: My coreXY design is progressing to the build stage February 23, 2018 10:40PM |
Re: My coreXY design is progressing to the build stage February 24, 2018 12:29AM |
ampapa
Ouch! $28 + shipping for a drive shaft with a 2mm keyway..
ampapa,
Re: My coreXY design is progressing to the build stage February 24, 2018 07:58AM |
Re: My coreXY design is progressing to the build stage March 08, 2018 08:23AM |
Re: My coreXY design is progressing to the build stage March 08, 2018 09:41AM |
Re: My coreXY design is progressing to the build stage March 24, 2018 09:45PM |
Re: My coreXY design is progressing to the build stage March 25, 2018 08:26AM |
Re: My coreXY design is progressing to the build stage March 25, 2018 05:06PM |
Re: My coreXY design is progressing to the build stage March 26, 2018 07:41PM |
Re: My coreXY design is progressing to the build stage March 29, 2018 10:39AM |
Re: My coreXY design is progressing to the build stage March 29, 2018 02:30PM |
Re: My coreXY design is progressing to the build stage March 29, 2018 02:49PM |
Re: My coreXY design is progressing to the build stage March 29, 2018 04:48PM |
Re: My coreXY design is progressing to the build stage March 29, 2018 06:00PM |
Re: My coreXY design is progressing to the build stage March 29, 2018 06:07PM |
Re: My coreXY design is progressing to the build stage March 30, 2018 10:16AM |
Re: My coreXY design is progressing to the build stage April 02, 2018 06:22AM |
Re: My coreXY design is progressing to the build stage April 04, 2018 07:16AM |
Re: My coreXY design is progressing to the build stage April 05, 2018 09:41AM |
Re: My coreXY design is progressing to the build stage April 05, 2018 10:49AM |
