Rugged CoreXY May 29, 2016 04:20AM |
Re: Rugged CoreXY May 29, 2016 05:38AM |
i haven't covered everything, as i am learning as i go along, so have not commented on things i don't know about (or have said "i don't know" if i have). you'll like the Duet. it has ethernet and a built-in web interface, and you can get an LCD for it as well.
Re: Rugged CoreXY May 29, 2016 07:26AM |
Re: Rugged CoreXY May 29, 2016 09:05AM |
lkcl
hiya hobbymods, welcome to the forum. some links to analysis that may help,
- look at what the_digital_dentist did, with son-of-megamax, his printer design is extremely comprehensive and accuracy is extremely good.
- [forums.reprap.org] for an analysis as to why you should use dual rails/rods and triple lead screws. dual screws is not enough. multiplying up the number of rails does not "fix" the problem of bed rotation about [only 2] screws, it just minimises it. triple lead screws is GUARANTEED to stop rotation, the rails (only 2 needed) stop lateral movement. anti-backlash nuts on all 3 lead screws and you're laughing.
- [forums.reprap.org] you're using rails but is there any rotation in the rail carriage part (about the x y *or* z axes) i.e is the linear carriage *perfect*? if not, take a look at rods instead, set up as described in the thread there. experimental idea so YMMV, other people may have better advice here.
- [forums.reprap.org] follow the belt layout outlined here. keep the entirety of each belt in the same plane, offset them slightly (staggered heights). make sure that the belt goes *exactly* through right-angle turns, do *NOT* be tempted to do 89.5 or anything like that. use 2 bolts in the x-ends and stagger the bearings so that the belts come in on *exactly* the same centre line which should be along the centre of gravity of the carriage... and the hotend should be exactly on that centre of gravity.
- above a 300mm span don't use 8mm rods. anywhere. they bend too much.
- i got a meanwell LRS-350-24 prices are very good, they're also quite thin which is nice. but that was for a 200x200 printbed, you may want to get a mains-operated bed heater then the LRS-350-24 would do you fine... yep that's what you're planning. don't bother with 12V any more. make sure the fan from the PSU points *away* from the printbed...
- make sure you use 0.9 degree per step NEMAs, dc42 is extremely knowledgeable about this, you get far better accuracy and can do up to 1000mm/sec with them on a corexy.
- go for a Duet NG, again, dc42 knows what he's on about, REALLY don't bother with RAMPS or anything that uses arduinos.
- put fans pointing at the Duet's stepper ICs.
- consider a Flex3Drive, they are a combination of the best of both the bowden and direct extruder worlds *and then improve on that even more*. mutley3d is an extremely knowledgeable engineer.
- [forums.reprap.org] don't for god's sake bother with a bowden, they're basically shit. i know people say "oh i have no problems at all" - these people have never had a Flex3Drive. the reality is that bowden tubes are not robust, there's far too much to go wrong, they waste filament, and every single one of the problems i listed on that post was something i encountered MULTIPLE times over an extremely intense and very annoying period of 3 weeks. but, it boils down to this: as an engineer, retract of *five* millimetres as compared to 1.5mm for a flex3drive or direct drive extruder really should tell you everything you need to know.
- based on the same analysis as for the z bed i came up with a trick to use 3 springs and 2 fixed screws for bed-levelling. just as in the z-bed analysis the 2 fixed bolts stop rotation and lateral movement, and the 3 springs allow bed-levelling. if you used smooth rods (or part-threaded M3 bolts) and got the drill holes to good tolerances you could ensure that the printbed really really does not move laterally, i have a tiny amount of potential lateral movement because the 2 fixed bolts sit in slightly oversized holes. something for me to fix later.
- enclosed you will not be able to use PLA for parts, they will melt. find a material that has a high enough temperature or just go all-aluminium.... i think you said that's what you planned
- E3Dv6 i recommend going immediately to a volcano upgrade, unless you really really have a need to use 0.3mm nozzles or below.
- i use mechanical endstops and find them to be fine, but i have no experience with anything else yet so cannot make a comparison.
errr that's alli haven't covered everything, as i am learning as i go along, so have not commented on things i don't know about (or have said "i don't know" if i have). you'll like the Duet. it has ethernet and a built-in web interface, and you can get an LCD for it as well.
there's plenty of great people here who are knowledgeable. there's some angry ones, stressed-out ones (including me) and some inexperienced ones too, but that's okay, we're all learning. enjoy
Re: Rugged CoreXY May 29, 2016 09:11AM |
the_digital_dentist
Here's what I made to get high quality prints. I'm working on a core xy design now.
[www.instructables.com]
Like you, I don't care about high print speed, quality is the goal.
I'm not a fan of glass beds, but people seem to like them. I prefer cast tooling plate with a layer of Kapton tape. I used two linear guides on the y axis with ball screw drive, and a single guide rail for the x axis. A single motor in the z axis is definitely the best way to go.
It's refreshing to see someone on this forum who isn't focused only on making the cheapest possible printer. Welcome!
Re: Rugged CoreXY May 29, 2016 10:48AM |
Re: Rugged CoreXY May 29, 2016 12:39PM |
Re: Rugged CoreXY May 29, 2016 02:58PM |
the_digital_dentist
I think switches are fine for X and Y endstops as they don't generally require high precision. The Z axis stop should be very precise. I used an optical switch pulled from an ink jet printer for that one. There's no hysteresis in the optical switch (unless your adjustment mechanism creates it).
NEMA-17 motors can deliver up to about 100 oz-in of torque. That should be enough depending on how hard you intend to push the printer and the requirements for starting/stopping precision. See Oriental Motor's motor sizing calculators.
Re: Rugged CoreXY May 29, 2016 03:28PM |
hobbymods
Mate that's some awesome info to go through, cheers for that.
Some of it I don't understand, but I do understand Bowden's being shit....my one dabble in them made me hate them.
I will get some further explanation of the pulley alignment as I get into it and have read all the info I can find here.
I've absolutely never heard of the 3 ball screw thing ever, I'll look into it. That's the expensive bit.
Re: Rugged CoreXY May 29, 2016 05:24PM |
Re: Rugged CoreXY May 29, 2016 05:37PM |
the_digital_dentist
Autoleveling assumes that settings made at the start of the print will be maintained throughout the print. How many i3 people have problems keeping two motors synchronized?
Adding a third motor is asking for trouble. Autoleveling is a self-fulfilling concept- if you include it in the machine, you will need it because you included it. The only reason for using multiple motors is to save a few $ on pulleys, bearings, and a closed loop belt.
Re: Rugged CoreXY May 29, 2016 05:41PM |
Re: Rugged CoreXY May 29, 2016 05:46PM |
Koko76
Holes are not what align linear rails (installed according to the specs you mentioned). Hiwin (as well as THK, IKO, SKF and several others) describe proper technique which is a machined lip for the bearings to rest against. It's not just the location of the holes, but the flatness of the surface you need to be concerned about. This is also specified in installation instructions, you can find these documents on all of the websites of the manufacturers I listed earlier.
As to your comments about 2 carriages per rail, if you are serious about "doing it right" work out the loads seen by your printer and make reasonable determinations as to what you need. You don't always need two per rail if you keep the moment load within specs. In the machine I'm currently building I am using 9mm rails for X and Y, with two rails for Y and a single rail and carriage for X. Z is a single 15W sized rail which is 30mm wide, and it is cantilevered and well within moment load spec. Your print area and other machine sizes will be different than mine, so you have to work out what works best in your situation but do a little math, it can save you a lot of cash.
Re: Rugged CoreXY May 29, 2016 05:49PM |
cozmicray
Ikcl is building a Rube Goldberg foldable printer
using mainly kitchen utensils as tools,
because he has to move every week.
Exactly opposite of your build.
Don't get screwed by him -- if he doesn't know the capability / precision of a ballscrew
He's a rod man --- averse to proper linear guides.
Re: Rugged CoreXY May 29, 2016 05:55PM |
cozmicray
Z drive --- 3 points determine a plane -- with two ballscrews, what keeps bed from tilting
stiff tooling plate on good frame could be made to work
but if you have three ballscrews driven / syncronized by a belt drive --- would be best
With water jet available -- no plastic printed parts for you.
Digital Dentist the sage of well built printer
Re: Rugged CoreXY May 29, 2016 06:32PM |
Re: Rugged CoreXY May 29, 2016 09:10PM |
the_digital_dentist
The point of leveling the bed, either auto or manual, is to get prints to stick to the bed. If they don't stick they fail, so the goal of leveling is to improve reliability of the printer.
The designer has a choice- build the machine solidly so that it can maintain bed level, or build it less solidly and require frequent manual leveling or autoleveling. There is no reason to add autoleveling to a solid machine that maintains the level setting. If you choose the less solid construction approach, usually to reduce cost of the printer's frame and mechanism, you add the complications and potential failure points of autoleveling while compromising print quality.
Ultimately, money spent on autoleveling buys you consistent first layer quality with reduced overall reliability. Money spent on solid construction buys you quality for every layer of the print without reducing (and maybe increasing) reliability.
Adjusting the X axis in my printer is as simple as loosening the grub screw on one pulley and turning the lead screw without turning that pulley. When the X axis is in correct position, tighten the grub screw. You would do the same with a three screw mechanism.
Re: Rugged CoreXY May 29, 2016 09:45PM |
I do that too. The thing I don't like about it is that it means I can't put flats on the lead screws for the set screws to tighten against. It hasn't bit me yet, but I'd be happier with flats, I just can't think of a good way of being able to adjust the relative heights if I do that. Perhaps some sort of adjuster on one of the Z carriages...Quote
DD
Re: Rugged CoreXY May 29, 2016 11:11PM |
Re: Rugged CoreXY May 30, 2016 02:33AM |
the_digital_dentist
Autoleveling assumes that settings made at the start of the print will be maintained throughout the print. How many i3 people have problems keeping two motors synchronized? Adding a third motor is asking for trouble.
Re: Rugged CoreXY May 30, 2016 05:08AM |
the_digital_dentist
Re: Rugged CoreXY May 30, 2016 05:52AM |
JamesK
and we're back to screws and stuff which we were endeavouring to eliminate because the assumption is that they're redundant!|
Re: Rugged CoreXY May 30, 2016 06:32AM |
cozmicray
and that we're all learning.as a community from the insights that we have to share with each other - not just technical. but... can we keep it technical? i'd much prefer that.
Re: Rugged CoreXY May 30, 2016 07:21AM |
Re: Rugged CoreXY May 30, 2016 08:17AM |
Re: Rugged CoreXY May 30, 2016 08:42AM |
Re: Rugged CoreXY May 30, 2016 08:44AM |
nebbian
Regarding bed screws and springs: Unless you do a better job of engineering the spring arrangement than I did, you risk the bed moving horizontally when the head hits a plastic blob. This results in shifted layers.
I had springs on my bed, but due to the slightly shifted layers issue (only occasional, and usually less than 0.1mm), I changed to a solidly mounted bed system. This is still adjustable for levelling, but is locked in position once adjusted.
You all sound like much better engineers than me, so feel free to ignore my findings. But I am quite fussy with my prints, and found spring loaded mechanisms too hard to keep locked in the x-y plane.
Re: Rugged CoreXY May 30, 2016 08:53AM |
Re: Rugged CoreXY May 30, 2016 08:58AM |
Re: Rugged CoreXY May 30, 2016 09:02AM |
JamesK
Awesome. You're making me very jealous for your contacts. It costs me a fortune to get tooling plate. After a year and a half of working around cheap components I do find myself wishing I could just drop the cash on the good stuffDD is usually right about these things.
