Design nearly done - construction started... April 12, 2013 09:26PM |
There are 2 30 amp PSUs. All electronics draw outside air for cooling. I do not have a definitive count on the number of fans in this thing, there is 1 on each motor, one on the hotends, one on the fresh work, 2 per PSU, and 2 (3?) at the electronics, as well as one or two others for air handling, to keep even temps for curing. |
Re: Design nearly done - construction started... April 14, 2013 02:13PM |
Re: Design nearly done - construction started... April 15, 2013 09:48PM |
Re: Design nearly done - construction started... April 16, 2013 05:31AM |
Re: Design nearly done - construction started... April 16, 2013 09:13AM |
Re: Design nearly done - construction started... April 17, 2013 01:18AM |
Re: Design nearly done - construction started... April 17, 2013 02:10AM |
Admin Registered: 18 years ago Posts: 14,168 |
Re: Design nearly done - construction started... April 17, 2013 04:12PM |
Re: Design nearly done - construction started... April 19, 2013 01:14AM |
Re: Design nearly done - construction started... April 19, 2013 05:58AM |
, the heat and the dry dust blowing around outside just overwhelms everything with dirt argh
Re: Design nearly done - construction started... April 20, 2013 12:46PM |
Re: Design nearly done - construction started... April 20, 2013 03:19PM |
Re: Design nearly done - construction started... April 20, 2013 03:49PM |
) I've got to reread some stuff - welding, powder coating, because it's been awhile. So that's tonight. The good news is as soon as the frame is done, this should go together pretty quick. The bad news is I haven't designed the X axis yet. At least not on paper. I may get everything else innitially assembled first and then do some mockups to determine the optimum geometry given the dimensions I am working with. My concern / objective is to get an 18" wide X carriage to traverse the Y direction at maximum speed without any resistance(as little as possible ) I am using my belts to make a rack and pinnion setup, to avoid having almost 10 feet of belts flapping around. So the way I work, I need to see everything up to that point to end up with an optimal design.
Re: Design nearly done - construction started... April 20, 2013 08:01PM |
Re: Design nearly done - construction started... April 20, 2013 08:20PM |
Re: Design nearly done - construction started... April 20, 2013 08:22PM |
Re: Design nearly done - construction started... April 20, 2013 11:15PM |
Re: Design nearly done - construction started... April 20, 2013 11:20PM |
Re: Design nearly done - construction started... April 21, 2013 02:56AM |
Re: Design nearly done - construction started... April 21, 2013 02:33PM |
Re: Design nearly done - construction started... April 23, 2013 10:29AM |
Re: Design nearly done - construction started... April 25, 2013 06:51PM |
Re: Design nearly done - construction started... April 26, 2013 02:17AM |
Re: Design nearly done - construction started... April 26, 2013 03:53PM |
The geometry of the tube setup is the most demanding engineering challenge on this machine, and the desired number of colors is a key factor in its overall design. The trick is to minimize at all times the angles of the tubes, and it is imperative that they in no time are allowed to straighten out. Even though the tubes are somewhat soft, if they go straight, then they will cause ripples as they pass the bending moment. At the same time, it is important to keep the angles minimal to avoid binding. As to the electronic means to control 7 extruders, I am looking at a couple of options, either encoding/decoding each extruder pair, or running the hotends as cool as will print a given filiment reliably, and then just make before break switching the individual pololus, or doing something similar. Either way, it will require I build my own ramps extension board. I don't mind running a bunch of wires to my motors which will be stationary, but I need to minimize wire runs to the carriage.
Re: Design nearly done - construction started... April 26, 2013 05:51PM |
Re: Design nearly done - construction started... April 26, 2013 06:30PM |
Re: Design nearly done - construction started... April 26, 2013 06:40PM |
Re: Design nearly done - construction started... April 26, 2013 08:17PM |
Re: Design nearly done - construction started... April 26, 2013 10:10PM |
