Re: Folger Prusa i3 Kit from ebay May 10, 2015 08:05PM |
dbrewski
Let's see how these work out for everyone. I printed them tonight and everything seems to fit OK with very little extra work. I haven't tested the fit of the E3D in the extruder but that shouldn't be too hard to make fit with a little sandpaper. I have attached all the files you will need. Please provide feedback if anyone decides to use this.
Re: Folger Prusa i3 Kit from ebay May 10, 2015 10:48PM |
Ecky
Chrome:
What is that clack clack noise ????
I built mine with the Y endstop at the other end as per the Folger FAQ. My X is where your's is. My enstop connectors are as the build manual. X in the lowest position(1), skip one(2), Y is next in 3 and Z is in 5. My configuration.h is posted for your use if you like. It works but it may be mirror imaged. Still testing.[/quote
The motors are still trying to move even when they hit the end stop, I think they're skipping on the belt. The configuration would work if it's a hardware issue?
Re: Folger Prusa i3 Kit from ebay May 11, 2015 02:36AM |
Re: Folger Prusa i3 Kit from ebay May 11, 2015 06:35AM |
Re: Folger Prusa i3 Kit from ebay May 11, 2015 03:10PM |
Tardisrepair
Hardware list for dbrewski's E3D v6 direct drive extruder remix
This is what I used, I had a lot of this already but bought fresh hardware just in case
1x M4x50 screws (idler tension)
4x M4x30 screws (a little short, might want to try 35-40)
5x M4 nuts
a spring for the idler
a few M4 washers (optional, use to increase tension on the idler if your spring is to weak, or try to use a shorter screw)
1x M3x16 screw
1x M3x20 screw
1x M3 nut
2x M3 washers
3x M3x10 screws
Bearing extender fits a 5x10x4 bearing
I used the 2 screws that held the stepper to the carriage in the folger configuration to attach the dbrewski's 'carriage mount' to folger x carriage
dbrewski
Re: Folger Prusa i3 Kit from ebay May 11, 2015 07:02PM |
Re: Folger Prusa i3 Kit from ebay May 11, 2015 09:03PM |
Re: Folger Prusa i3 Kit from ebay May 11, 2015 10:27PM |
chromecarz00
Do you mean reverse them? They are plugged in where they were said to in the manual
Re: Folger Prusa i3 Kit from ebay May 12, 2015 03:43AM |
Vanbot
chromecarz00
The slots for end stops on the RAMPS are arranged like this:
Z MAX
Z MIN
YMAX
Y MIN
X MAX
X MIN
So the very bottom slot on RAMPS is for the X end stop if the actual end stop is in a Min position on the printer. Ditto for Y and Z. To get my printer to work right I had to plug my X end stop into the X MAX slot, not the X MIN slot that the manual says to use.
Re: Folger Prusa i3 Kit from ebay May 12, 2015 10:50AM |
Re: Folger Prusa i3 Kit from ebay May 12, 2015 11:45AM |
Re: Folger Prusa i3 Kit from ebay May 12, 2015 11:55AM |
// uncomment one of the following lines for RAMPS v1.3 or v1.0, comment both for v1.2 or 1.1 // #define RAMPS_V_1_3 // #define RAMPS_V_1_0
Re: Folger Prusa i3 Kit from ebay May 12, 2015 12:20PM |
Re: Folger Prusa i3 Kit from ebay May 12, 2015 12:38PM |
Re: Folger Prusa i3 Kit from ebay May 12, 2015 12:51PM |
Re: Folger Prusa i3 Kit from ebay May 12, 2015 12:55PM |
Re: Folger Prusa i3 Kit from ebay May 12, 2015 03:16PM |
Re: Folger Prusa i3 Kit from ebay May 13, 2015 03:58AM |
Re: Folger Prusa i3 Kit from ebay May 13, 2015 04:23AM |
Re: Folger Prusa i3 Kit from ebay May 13, 2015 06:42AM |
Re: Folger Prusa i3 Kit from ebay May 13, 2015 01:43PM |
Re: Folger Prusa i3 Kit from ebay May 13, 2015 02:45PM |
Re: Folger Prusa i3 Kit from ebay May 13, 2015 02:48PM |
Re: Folger Prusa i3 Kit from ebay May 13, 2015 03:18PM |
Re: Folger Prusa i3 Kit from ebay May 13, 2015 05:17PM |
hockey9999
Thanks! That would be awesome, I don't have a way to measure the bed temp other than trusting the thermistor reading - which is definitely different between firmware versions.
I've read elsewhere that it seems to take longer to heat in 1.0.2 - maybe it doesnt actually take longer to heat, it takes longer because it is overheating?
Re: Folger Prusa i3 Kit from ebay May 13, 2015 05:29PM |
Re: Folger Prusa i3 Kit from ebay May 13, 2015 08:41PM |
Re: Folger Prusa i3 Kit from ebay May 13, 2015 08:47PM |
Re: Folger Prusa i3 Kit from ebay May 14, 2015 12:03PM |
Re: Folger Prusa i3 Kit from ebay May 14, 2015 08:58PM |
