Re: Migbot Prusa i3 Unofficial Support Thread August 09, 2015 08:25PM |
gatorNic
jbehan
Anyone have their acrylic Y axis carriage warp from heat while printing ABS? I did tonight, son-of-a...just found the sweet spot too. Thoughts on a replacement?
I haven't started printing with ABS yet. Was just about to. Was it a long print?
Think I remember somebody on this thread buying this one:
Amazon
but if you don't need the bearings, etc I think this one might work and its US:
Ebay
Re: Migbot Prusa i3 Unofficial Support Thread August 09, 2015 08:31PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 10, 2015 06:03AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 10, 2015 03:49PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 10, 2015 04:00PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 11, 2015 03:14AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 11, 2015 08:53AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 11, 2015 09:42AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 11, 2015 10:58AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 11, 2015 03:44PM |
veaceonee
Every time I try to connect my computer to the printer it keeps saying "NON GENUINE DEVICE DETECTED". It will not connect to the printer. How do i fix this? Stupid Windows 10..
Re: Migbot Prusa i3 Unofficial Support Thread August 11, 2015 03:58PM |
gatorNic
veaceonee
And this is with doing a "have disk" manually loading drivers? Usually the Genuine stuff just has to do with the drivers not being signed, but you can force drivers with have disk.
Re: Migbot Prusa i3 Unofficial Support Thread August 11, 2015 04:14PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 13, 2015 09:48PM |
Anonymous User
Re: Migbot Prusa i3 Unofficial Support Thread August 13, 2015 10:22PM |
Anonymous User
Re: Migbot Prusa i3 Unofficial Support Thread August 13, 2015 10:25PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 13, 2015 10:35PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 13, 2015 11:35PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 13, 2015 11:47PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 14, 2015 08:08AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 14, 2015 08:14AM |
3DST
veaceonee, has anyone been able to print this extruder frame part for you? If not, I can get one done for you.
Re: Migbot Prusa i3 Unofficial Support Thread August 14, 2015 08:18AM |
RRuser
The alignment of the brass nut for the Z threaded rods does seem very important. I have a similar one in my steel i3, and if slightly tilted, the brass nut will really bind that Z threaded rod, so much so that you can't turn it by hand.
As for warping acrylic frames, at least I can avoid that problem, with the steel frame.
Anonymous User
Re: Migbot Prusa i3 Unofficial Support Thread August 14, 2015 11:40AM |
Re: Migbot Prusa i3 Unofficial Support Thread August 14, 2015 12:21PM |
Anonymous User
Re: Migbot Prusa i3 Unofficial Support Thread August 14, 2015 12:46PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 14, 2015 12:50PM |
3DST
gatorNic, I mentioned the warped bed because anytime the head gets too far off the bed, the filament can pour our and sometimes "curls" up and attaches to the print head. Little by little the blob gets bigger.
Re: Migbot Prusa i3 Unofficial Support Thread August 14, 2015 07:21PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 14, 2015 08:00PM |
veaceonee
What glass do you recommend I get to replace the aluminum plate? Does the glass replace, or add on to the aluminum plate? Iv heard the Z sensor doesn't like glass plates, is this true? The aluminum plate does not appear warped.
Re: Migbot Prusa i3 Unofficial Support Thread August 14, 2015 08:13PM |
Re: Migbot Prusa i3 Unofficial Support Thread August 14, 2015 09:43PM |
veaceonee
So I messed with the retract and speed settings a little. Helped with the giant lump it was making in the print...but, now everything else is going hell......frustrating.
Re: Migbot Prusa i3 Unofficial Support Thread August 15, 2015 03:14PM |
gatorNic
veaceonee
I think probably do a methodical calibration of your x,y,z and extruder. Make sure they are doing exactly what they are suppose to do. Then starting with the default migbot settings again. Mine was pretty decent right out of the box with their settings, but it was after I methodically went through calibrating right from the start.
