Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 12, 2015 10:46AM |
mel0n
therippa
Pics...
[i.imgur.com]
[i.imgur.com]
[i.imgur.com]
[i.imgur.com]
STL's...
Extruder - [www.thingiverse.com]
Hotend holder - [www.thingiverse.com]
The hotend holder's mounting holes didn't line up with the hole on the Folgertech X-carriage, so I just brought out the drill. This weekend's project will be hooking up the fan (easy) and the capacitive sensor (not as easy) to it.
I know I said I would post, but at the time you posted, My E3D had a catastrophic failure. The guys at filastruder were great, and they comped me a new nossle and heat block. I got my parts in last week and my printer has been running happily since. So I am finally getting around to uploading pics and all and making this post.
Here is an album of pics prior to the failure: [imgur.com]
The failure itself was basically a HORRIBLE clog. I can't advise against Hatchbox ABS enough. Their ABS is complete crap, is full of impurities, and as has been proven multiple times in the community, ISN'T REAL ABS (it doesnt dissolve in acetone). The tolerances of the filament were terrible, I had all kinds of weird things show up in my prints that were exclusively filament related, and from the time I installed my E3D I never removed the filament/changed filament/etc until the clog event. I threw away the roll after I saw how badly it clogged. I also followed instructions I found online for taking apart the E3D and heated the hotend before loostening the nossel, yet it still broke clean off with little force. I could not clear the clog in the heatbreak and had to order a new one with the new parts that filastruder comped for me. ABS should not clog your heatbreak/ptfe, this is further testament to how poor the hatchbox abs is.
Anyways pics of the failure : [imgur.com]
Since it has been fixed, I replaced a bunch of parts on my extruder with the correct/better ones. This is the current state of my printer: [imgur.com]
Also here is a link to the Extruder: [www.thingiverse.com]
P.s. don't worry about my cable management, I have been taking the thing apart every few days and I will put everything in a more permanent spot when I am happy with everything.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 12, 2015 12:54PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 12, 2015 01:05PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 12, 2015 01:09PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 12, 2015 02:44PM |
mel0n
blank64
blank64
Blackbird
Are you sure the bearing with teeth on the motor isn't puched too close to the motor body? If it sits right against the motor housing and you have the set screws tightened, it won't spin properly. Easy thing to overlook while putting everything together.Quote
blank64
So I have now finished the build, but am now having some problems trying it out with repetier: (I tried both the marlin included in the drive folder, and the one posted a few pages back)
My y-axis motor doesn't seem to be able to turn the belt (it either barely turns, or skips the belt entirely while turning), I used one of the included belt tensioners so it's pretty tight.
My x-axis motor doesn't seem to be working at all (Although it gets a bit warm after a couple of minutes)
Only one of my z-axis motors is actually turning (the one which I can turn by hand while off), I tried switching where the 2 motors are plugged in, but in each case the same one turns.
Has anyone experienced any of these problems?
I had a couple of the bearings right against the motors, but have now moved them and am getting the same results. I took the belt off of the y axis, and it just vibrates the bearing when I tell it to move. The x axis makes no movement whatsoever, but I can hear different high pitched tones for each of the steps (like my one working motor), so I don't quite know what to make of that.
So right now I'm thinking that 3 of my stepper motors may be broken. I am not able to turn any of them by hand (at all) , and switching their connections to my working one has proved that their drivers are working. My y-axis shudders the shaft when I try to make it move, and the other two make no movement at all but emit a high pitched whine after attempting a step.
Has anyone else encountered a problem like this?
Don't really feel like explaining it, so I will just paste a response from another thread about motor whine here:
Mel0n
When motors make high pitch noise but do not move, its because the printer thinks your trying to move it in an INCREASING direction, so they turn on and hold their position but wont move further because it doesn't want to crash before it homes. Look at your printer shape settings in repetier, this is really important. If you change your endstop/firmware settings, repetier is still going to tell it to go the wrong way.
Theoretical home is front left of the print bed. So look where you have your endstops and adjust accordingly. An example, your x end stop is on the right, which is max (200). But the software doesn't know this, it thinks min(0) is the endstop. So by telling repetier in printer settings, X-home : max, your letting it know that it should be trying to go to the max value. If this is the case, you also need to switch the position of the endstop plug on your RAMPS from x-min to x-max (reference the schematic, or look at any of my posts on this in the main thread).
Also a link to his thread since you are having (basically) the same problem he was, which has been explained, solved, solved again, and explained in this thread multiple times [forums.reprap.org]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 12, 2015 03:23PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 12, 2015 03:40PM |
mel0n
Also for those who PM'd me about my camera/RasPI setup in the pictures of my printer, here is what my camera view looks like. Thats a wheel for a robot I am working on btw.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 12, 2015 03:41PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 12, 2015 03:46PM |
TimJC
I setup OctoPrint on my old RPi Model B, but I will be a USB port short if I use WiFi, USB webcam (carppy VGA currently plugged in), and the printer, which should be on my front porch. My options are to get a RPi 2 with 4 USB ports, or use Pi Camera with the older Model B. Does OctoPrint benefit from the added performance of the RPi 2?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 12, 2015 03:49PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 12, 2015 03:57PM |
Danmst3k
Got my i3 2020 up and printing about 5 days ago. I'm very happy with it so far. I'm still in the tweaking faze and have been doing test prints. I printed the 20x20x20 cube and I'm getting a ripple pattern on all of the sides. There's 5 ripples on each side on a 45 degree angle. I noticed my X stepper was making a lot of noise/buzzing when it moved and that would vibrate the whole machine to some degree. I didn't tune my stepper drivers yet but I realized maybe the x was too high voltage wise. While it was printing I used the ceramic screwdriver that came with my printer and turned the pot on the driver. I got it to be a lot quieter but there's still that ripple patteren. But, the ripple pattern became a lot smaller and there's now maybe 20 ripples but they're less pronounced. The Y stepper is very smooth however. These pots on the drivers... do they spin forever in each direction or do they eventually bottom out? I didn't want to try it as it was running. Has anyone else had this buzzing problem? Maybe I have a bad stepper motor?
Thanks,
Dan
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 12, 2015 05:33PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 12, 2015 06:09PM |
TimJC
The 4-10 (probably 12 for me) hour struggle begins. Here's to hoping there are no missing parts.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 12, 2015 06:37PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 12, 2015 07:11PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 12, 2015 10:26PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 12, 2015 10:31PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 12, 2015 11:43PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 13, 2015 10:34AM |
mike3
mel0n
mike3
but my hotend stopped heating and lost control of bed heating..will up date after replacing...
Sounds like a bad FET :[ it was probably correct for them to send you a new Ramps. Hopefully your arduino is ok.
Eureka !!! its alive.... just printed a part for the Smart Core .. came out perfect... using the Smart LCD .. havn't tested it with the USB yet.. but I can now print again...
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 13, 2015 11:42AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 13, 2015 06:13PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 13, 2015 06:40PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 13, 2015 06:59PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 13, 2015 07:55PM |
Neverdone
So I finally powered it up last night. Started trying to calibrate it. When I hit the button to home the X-Axis the motor moves maybe 1/2" and then stops. I thought it seemed to me that it was the motor stalling from not enough power. I started trying to turn the stepper driver up but this did not help. when not powered it seems that the axis moves very easily no binding. Does anyone have an suggestions? I lubed the rails with a dry moly lubricant. But still nothing.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 13, 2015 08:15PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 14, 2015 04:30AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 14, 2015 05:10AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 14, 2015 06:11AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 14, 2015 11:22AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 14, 2015 11:39AM |
Danmst3k
Thought I'd post a couple photos of some tests. Pretty happy with the quality of this printer so far. The cubes are 20mm and hollow with only 1 layer wall thickness. The one on the right was printed first and is totally smooth. I was having issues with a ripple pattern previously so I tweaked my stepper drivers and that was the result. The weird thing is the cube on the left was printed pretty much right after it and the ripples came back. I was messing with the feed rate though, I think I changed it to 140% on that cube. I put it back to 100% and printed the robot and it seems to be smooth again so there you go. These are printed at .3mm. The robot is 1 1/8" tall, which is the default size.
Thanks,
Dan
