Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 15, 2016 01:59PM |
Bert3D
Reply to Rollinns
You may be masking the problem rather than fixing it. If you aren't moving at slow step rates, your driver current is probably not correct. You may have just never noticed it because you never tried to move slow before.
Do you have your X endstop on the left and plugged into the min-x position? Auto level doesn't work with x endstop at the max position and the endstop on the right. I have no idea why it wouldn't stop when it hits the x endstop unless the movement and endstop indicators are messed up somehow. But if it worked before, this shouldn't be the case. There are a lot of things than can keep G29 from working right, so it may be related to the x issue. I would fix that first.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 15, 2016 02:18PM |
rollinns
Bert3D
Reply to Rollinns
Sorry I didn't see your reply earlier. Thanks for the help! I'll switch my x endstop to the left, make changes to x-min and see where that gets me. You're right, there seems to be lots of quirks with ABL, but there also seem to be a lot of eyes looking into it. It's one of the main things I like about OSS.
Is your insight about G29 not working on x-max endstops documented anywhere? If not, have you considered submitting a pull request to get it documented somewhere?
If I need to change my hardware to get G29 working, I have no problem with that, I just didn't know that was the case until now. I really appreciate your help.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 15, 2016 03:59PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 15, 2016 04:34PM |
chking
It seems like all discussion on this topic ended 6 months ago. Any reason why? I just ordered a Folger Tech RepRap 2020 Prusa i3 Full Aluminum 3D Printer. Is there another forum that is more up-to-date?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 15, 2016 06:00PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 15, 2016 06:56PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 15, 2016 08:13PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 04:44AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 08:49AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 08:58AM |
Jeff000
First I want to say thanks for all your information that you've posted. And for your marlin version.
In regards to that magnetic feet... Would it actually help much at all? Those vibration isolation feet you recommend work wonders.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 10:31AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 10:45AM |
LancelotL
[attachment 69944 image.jpeg]This is probably the coolest thing I have printed so far. The files are available on Thingiverse. The base was printed using 0.1 mm layer and the letters came out great. The rod was printed using a raft. I polished the teeth with some acetone.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 10:53AM |
marc2912
Quick question I can't wrap my head around to find an answer yet...
On Thingiverse there os an extrusion calibration I'd like to do.
From what I understand the standard folgertech is set to a .4mm extruder diameter. I have settings with cura for both .2mm and .3mm heights. When I try to slice the 0.2mm thin wall and slice I get no result. This makes sense since that's smaller than my minimum extrusion due to the extruder precision. When I do the .45mm one it works, as expected. The one I don't understand is the .4mm thin wall. This, I would think, should work, yet once sliced there is no result. Can someone explain to me why or are my settings wrong somewhere?
Thanks
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 12:27PM |
randym
I've had my 2020 up and running for a few weeks now. Build almost completely stock for now. I'm having a problem with the temperature control for the bed. No matter what the temp is set for, it just goes full on. I've even turned it off in Slic3r and it still heats up.
I'm not sure what to try next and wondering if anyone else has seen this problem.
Will the new version of the software help?
Or is it a hardware issue with the Ramps board?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 05:39PM |
sonnylowe
Jeff000
I love magnets, and might have gone this direction had I seen them first, but I have already done THIS
It's a remix of one that used tennis ball (way to big).
I used the foam golf balls. I must say this is by far the quietest my printer has even been. I used to feel a bit of vibration in my desk while it was running, and could even hear it down stairs. Now I have neither. I'm very happy with this setup, it will also allow me to move my power supply off the rail and mount it under the bed
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 06:17PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 06:32PM |
UltiFix
So im interested in getting this printer, im a newbie and im wondering if it's hard to get good results from this, Im good at soldering, and I have dabled in arduino.
Im thinking about the Folger tech 20 20 I3 or this one.
[wanhaousa.com]
UltiFix
[wanhaousa.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 06:46PM |
Jeff000
UltiFix
[wanhaousa.com]
Like any kit the results are a direct result of the effort you put in.
I really like my i3 2020 from folgertech, and without much of anything special printed a pretty good benchy, and now that I actually understand what I'm doing can make a damn near perfect one at 0.1mm layer heights with petg.
One nice thing about the folgertech i3 2020 is its easier to modify than the wanha.
From a hardware standpoint I have no complaints or issues, I am having a software issue printing prints that take up a lot of surface area right now, but I can't fault folgertech for a slic3r problem, lol.
Is it easy to put the kit together?Quote
animoose
UltiFix
[wanhaousa.com]
This was my first 3D printer; I had some electronics and general engineering skills. I got acceptable results easily, and have been able to get better and better results over time. I don't know much about the wanhao, though if you look on other threads on this forum I think it has been discussed. In case it's not clear, the Folger is a kit while the Wanhao is ready built.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 06:52PM |
UltiFix
Jeff000
UltiFix
[wanhaousa.com]
From a hardware standpoint I have no complaints or issues, I am having a software issue printing prints that take up a lot of surface area right now, but I can't fault folgertech for a slic3r problem, lol.Is it easy to put the kit together?Quote
animoose
UltiFix
[wanhaousa.com]
Im pretty good at that kind of stuff though, I have built an arduino robotic arm.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 08:11PM |
Looking over your blog it looks like you ran into a lot of issues, I wouldn't really call that easyQuote
animoose
UltiFix
Jeff000
UltiFix
[wanhaousa.com]
animoose
UltiFix
[wanhaousa.com]
I had one or two sticky moments, but it was mostly easy. Look at the blod in my signature and you'll find the diary I kept as I was doing it.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 08:33PM |
UltiFix
After it was all said and done, how much did you spend in replacement parts?
What was the total?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 08:39PM |
Not trying to bash this printer or anything, and im sure you learned alot through the procces you have gone through. But wouldn't it have been cheaper to just get a nicer printer right away? Im just trying to decide if I should go cheap as can be *this printer* or a bit nicer one. Like this one "http://wanhaousa.com/products/duplicator-i3-steel-frame" Not sure what to do.Quote
animoose
UltiFix
What was the total?
I might have made it sound harder than it was. Looking back, it doesn't seem so difficult :-)
Regarding replacements: the only thing I had to replace was the RAMPS+Mega, and that was I think around $30. Everything else I've done has been through choice. In total, I've probably spent an extra $150-$200, but that includes a second Mega, an E3D hotend, leadscrews in place of threaded rods as part of the Z rebuild, some better quality LM8UU bearings, a new extruder mechanism (only $5, and the same as the one that Folger now supply) and a replacement 40mm fan.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 08:56PM |
UltiFix
animoose
UltiFix
What was the total?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 10:09PM |
animoose
Right now I am thinking about building a CoreXY printer from scratch for the same reason of interest in the process of building it, and I would not have considered that if I hadn't learned so much by building and modifying the Folger.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 10:20PM |
Mach
animoose
Did I hear someone say Corexy printer? I was recently in the process of making a custom one myself. I finished designing and modeling it, but then tallied the cost to make it and found out I could not really afford it right now, lol. How large of a build volume are you planning on, and do you plan on keeping your current printer once you have the corexy built? I plan on using as many of the parts from my FT printer, and then disassembling the rest after I have printed all of the parts I would need.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 10:47PM |
Jeff000
sonnylowe
Jeff000
Mounting the power underneath would be nice for sure.
The vibration isolation I got works excellent but only raises it like 1/2". Was looking at more 2020 so I could build it up a touch.
On another note, what's the display for in that picture?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 11:05PM |
UltiFix
animoose
UltiFix
What was the total?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) January 16, 2016 11:28PM |
Yea, I know im gonna get biased results.Quote
sonnylowe
UltiFix
animoose
UltiFix
What was the total?
I can't imagine enjoying a pre-built printer any were near as much as I've enjoyed putting this kit together, running it and modifying it. Many people have built this kit and run it bone stock with great results, hell I was getting near perfect prints stock...I upgraded as much for the "love" of it, as to build a better printer. If you buy pre-built you learn nothing about the printer, how it assembles, how it works, why it works, you just download some stuff, pick from a couple options, and push print. I'm not saying it's a bad thing, it's not, it's just not the direction I wanted to go in...
I think most people here (like myself) will be bias to this printer (I simply love it)!!! I'm not sure you're going to find an answer here...so it really just boils down to what you want
