Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 01:43AM |
GrouchoDuke
EXCEPT... My BLTouch started doing random reboots of itself again. It also calculated the bed at the wrong height after several G28/G29 attempts. So, I'm back to being frustrated. The regulator I used was very cheap. I may try wiring up my Anker USB charger instead. We'll see.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 02:02AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 09:23AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 09:32AM |
dlk4602
Hi, I just finished building my printer over the weekend and have been printing a bunch of stuff. So far I am pretty happy with the results. I do have a problem with melted plastic coming out the top side of the hot end. Eventually the melted plastic will run down the side of the nozzle and drip on my print. This is the stock extruder, I am not sure exactly how these are assembled. Is there a way to get a better seal?
Dave.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 09:38AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 09:40AM |
marc2912
dlk4602
Dave.
Your hot end isn't tight. I had the same issue with mine. It's good practice to take the whole thing apart. If you don't fix this it will eventually clog. It's basiccally a tube that screws into the block from the top and a nozzle from the other side. I had so much stuff oozing everywhere I had to heat up the extruder (with no filament going into it) and wearing heavy duty oven gloves I dismantled it hot and cleaned all the filament out. The extruder is attached to feed system via a set screw if I remember correctly (as in the top isn't screwed). This means that if you mess up the threads at the top a little when putting it together it won't be too bad because they don't thread into anything.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 09:54AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 11:41AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 11:44AM |
marc2912
marc2912
dlk4602
Dave.
Here is a high quality drawing i made for you
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 11:47AM |
UltiFix
I had an overnight print, woke up and my extruder had fallen off, looks like it fell of a few huors into the print. there goes 100 feet of plastic...
I also had recently tightened it. -_- Not sure how im going to keep it on.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 11:51AM |
marc2912
UltiFix
Guys I can't stress this enough, be careful. These printers can start a fire. Until you're totally comfortable with everything and have ran hundreds of prints don't leave your printer unattended, even then I probably wouldn't.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 11:54AM |
I had a feeling it wasn't a great idea. Im going to set a smoke alarm right next to it.Quote
Mach
marc2912
UltiFix
I second that. I never leave the house or go to sleep with the printer running, due to the amount of things that can go wrong and cause a fire.
marc2912
UltiFix
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 11:56AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 11:59AM |
UltiFix
Point taken... Will kapton tape be OK to keep the bottom of the extruder attached to the plastic? The screws are just there but slightsly stripped so the exturder can wiggle there way out.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 12:01PM |
Mach
UltiFix
I think the only way to fix your extruder would be to swap it with your x or one of you z motors. With the amount of weight and sharp acceleration involved, tape will not hold.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 12:03PM |
john-i
Mach
UltiFix
I was thinking the same thing.. probably Z would be better since it just rest on the bracket then you may be able to use a cable tie to help secure it.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 12:04PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 12:12PM |
UltiFix
Now my printer wont accept ANY commands, does nothing when I try manual control after than "shindig" overnight. Tried rebooting it etc etc.]
EDIT: When I came in and saw my printer was messed up I flipped off the power strip it was on, forgot I turned it off. Sigh
Not the best way to the start of a day I guess|
UltiFix
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 12:24PM |
See my edit, im just retarded LOLQuote
marc2912
UltiFix
Flipping off the power switch shouldn't have killed it. I wonder if the baking extruder baked anything else. Check one thing at a time. Connect the arduino alone. Can you see, it, can you upload to it. next connect arduino and ramps, what now... and go on from there.
marc2912
UltiFix
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 12:26PM |
See my post's edit, I forgot I turned off the power strip, so it wasn't getting any ac power - Dum meQuote
john-i
marc2912
UltiFix
I'm wondering if he busted his thermistor and getting a mintemp error, which I believe will keep it from responding.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 12:31PM |
UltiFix
marc2912
UltiFix
I think ill take the one of the z motors and swap it with the extruder one, good point they are attached on the other side so they should be fine. I have no idea how to extruder motor is attached to the extruder inside, and how to take it apart, is it fairly easy?
I looked on youtube and google and only found how to unclog the extruder. Ill fix the printer later today... Thanks guys!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 12:43PM |
I got the fan and heatsink off and am not sure which screw im supposed to do next, is the one circled in a red square the one I need to take off? I took it off but then the whole assembly was loose so I put it back.Quote
Mach
UltiFix
marc2912
UltiFix
It is pretty easy to take apart. Cut any filament going into the extruder and take the two screws for the heatsink and fan off. Once those are off, there will be a screw on the top right holding the lever arm on, unscrew that. Be careful not to lose the small brass tube. Then take off the screw on the left, and it should all be off of the motor.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 12:46PM |
UltiFix
Mach
UltiFix
marc2912
UltiFix
[prntscr.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 01:02PM |
Mach
UltiFix
Mach
UltiFix
marc2912
UltiFix
[prntscr.com]
Thats the one. Unscrew that and then pull the lever away from the motor. Be careful not to lose the brass tube that is holding the lever on. Then unscrew the screw on the other side
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 01:09PM |
You have to take apart the feed assembly to get to a screw that holds the motor onto the feed system. Kinda a dum setup if you ask me... Did you not have to take yours apart that way? I think there have been extruder revisions so I probably got a newer one.Quote
marc2912
Mach
UltiFix
Mach
UltiFix
marc2912
UltiFix
[prntscr.com]
Why are you taking apart the feed system? Losen the set screw in the heatsink and remove the extruder assembly.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 01:40PM |
UltiFix
Mach
marc2912
UltiFix
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 02, 2016 01:42PM |
UltiFix
Have any of you used cura over slicer? from some posts on the interwebs it looks like it does a finer job. I can obviously believe everything I read lol
