Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 22, 2015 02:10PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 22, 2015 03:58PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 22, 2015 05:04PM |
Devil Inc
markts
After witnessing some "play" in the Y belt, I installed a spring tensioner. It seems much better, so I started a 2 hour print. About 20 minutes in I heard a strange sound and found the bed had shifted. I thought the belt slipped because it started printing basically off the bed (on the side away from the endstop). Something must have bound up, so I tried removing the tensioner, but now the belt is stretched so that's not an option.
I'll have to do a smaller print to see what's going on. I'm hoping it's something simple.
I'm having the same trouble with mine now that I've added the adjustable tensioner to the X-Axis. Not sure if it's a 'that's too tight' condition or what. I'm going to work on troubleshooting it tonight, ran out of time to mess with it last night. I have to get it working smoothly, my E3D V6 hot end should be waiting for me when I get home from work. Still need to get an extruder mount, etc. printed for it.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 22, 2015 05:08PM |
widespreaddeadhead
Can you post a picture?Quote
Tenny
So I'm thinking about purchasing the E3D-V6 Lite for this now, but I have one major concern.
Most of my prints have more zig-zag lines on them...
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 22, 2015 09:19PM |
Devil Inc
markts
I'm not having much luck with ABS, and now I have the belt slipping or something. Darn!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 22, 2015 09:29PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 22, 2015 10:23PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 22, 2015 10:31PM |
DMPurdy
How did you put the tensioner on? I didn't see anything on how to do that in the instructions.I am having trouble with my bed not heating. It is the first time I have started it and tried anything so not sure what I am missing.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 22, 2015 10:39PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 22, 2015 10:44PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 22, 2015 10:50PM |
Uncertainty
Also FYI I'm having the best print so far with ABS (black from FolgerTech) @ 215cExtruder 95cBed using skirt/brim with elmer's purple school glue on a clean glass plate
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 22, 2015 11:02PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 22, 2015 11:06PM |
DMPurdy
Thanks I will give it a try...Also, is the the glass piece supposed to be secured down to the heat bed or just loose? It seems like it may slide around.
markts
Uncertainty
You give me hope! I kept cranking up the heat when it didn't seem to be working - I was up to 245. Maybe I should have been going lower.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 22, 2015 11:10PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 22, 2015 11:18PM |
Uncertainty
markts
Uncertainty
I found that at 230-245c that the extruder was clicking, probably because it was oozing out faster than it could extrude or something?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 22, 2015 11:49PM |
markts
Uncertainty
markts
Uncertainty
I'll be darned - the clicking made me think the stuff wasn't melting/extruding so I thought it needed to be hotter. I'm also using glue stick on glass, 105 degrees to start. Haven't had an issue with it sticking yet.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 23, 2015 12:23AM |
animoose
What is the right thing for lubricating the bearings and rods? I've heard people say white lithium grease. Would 3-in-1 oil do (I ask this only because I have some)? And do you have to take the bearings off the rods to apply it, or can you just put some on the rods and then works the mechanism back and forth a few times?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 23, 2015 12:27AM |
Uncertainty
animoose
I used 3-in-1, I figure if it's good enough for a sewing machine, why not the printer... I just applied it with a rag and then moved the printer around in x,y,z. If only I could get rid of my z threaded rods to stop squealing (only does it on the way down -- I think the nut may be at fault, not sure yet...)
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 23, 2015 01:17AM |
animoose
Uncertainty
animoose
I had squealing Z rods as well. Squeaking, screeching might be other words for it, and it was also only on the way down. I listened carefully and worked out it came from just one side. Then I saw that the motor was just slightly off true with respect to the threaded rod. Undid the screws on the motors bracket, moved it a fraction, and all was good after that.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 23, 2015 05:36PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 23, 2015 07:05PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 23, 2015 07:15PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 24, 2015 07:58PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 25, 2015 12:25AM |
go_gn
Any tips for tightening those nylock nuts in step 6: 3 ?
I'm guessing a nut driver should do the trick, but I don't have one handy and even so, the nut simply locks on the seal after going in a few threads.
Thanks in advance!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 25, 2015 03:56AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 25, 2015 04:05AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 25, 2015 09:06AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 25, 2015 10:07AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 25, 2015 12:27PM |
Agedashi
Almost finished with my enclosure. Still dialing down the settings though. Extruder clicks if I go below 210C with PLA at default speeds... print quality sucks at that high of a temp. Any ideas?
