Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 25, 2015 12:28PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 25, 2015 12:32PM |
ejnelson
Has anyone compiled like a go-to list of all the problems/solutions found for this printer yet?
I'm about to finish up the mechanical assembly, and i've skimmed this thread a few times and there seems to be the most problems with the electronics. I guess my plan was to just go through the configuration guide as is and if I come to problems I could scour this thread to see if my problems matched any of yours, but if there was a compiled list of things, it would be easier to act preventative-ly instead of reactive-ly. would be more efficient i'd imagine as well. I know this forum kind of serves as the list, but it gets a little tricky connecting the right solution to each problem when all the posts aren't chained together very well. (it'd be nice if there was a hierarchical reply structure kinda like reddit or something).
Anyways, I'm a noob, i know, and any pre-warnings or advice before starting the electronics would be helpful.
Thanks,
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 25, 2015 01:52PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 25, 2015 04:02PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 25, 2015 07:17PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 25, 2015 08:06PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 25, 2015 11:22PM |
Next step is to buy a new ramps 1.4 correct? The one on amazon that animoose linked on his blog is out of stock, I found this one: link, should work right?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 25, 2015 11:40PM |
ejnelson
Ok thanks, i stole one from the second extruder control like you mentioned. So, i ended up running into problems like I was worried about. I was adjusting the Vrefs and heard the pop and got the smoke.Next step is to buy a new ramps 1.4 correct? The one on amazon that animoose linked on his blog is out of stock, I found this one: link, should work right?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 26, 2015 01:20AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 26, 2015 07:52AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 26, 2015 08:39AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 26, 2015 10:50AM |
stanger2k
Do you guys have any tips with making sure that my two Y rods are properly alligned?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 26, 2015 12:03PM |
go_gn
A quick question : I may not have access to a soldering iron until next week. Is it possible to skip the heated bed soldering step and continue further?
I know that PLA doesn't require a heated bed. Can I do the soldering later without needing to disassemble too much?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 26, 2015 12:04PM |
ejnelson
Thanks Animoose, the only symptom I noticed in my limited testing last night was that before the pop and smoke the z axis was moving both directions, x and y would move but only one direction. After the pop and smoke nothing was responsive. I will test the arduino like you mentioned tonight.
@uncertainty I was adjusting the Vrefs with both the power supply connected to the wall and usb connected to my computer. where were you before last night?!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 26, 2015 05:53PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 26, 2015 07:05PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 26, 2015 07:31PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 26, 2015 09:33PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 27, 2015 01:31AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 27, 2015 01:56AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 27, 2015 03:45AM |
ejnelson
oh frick, just kidding, duh moment. I didn't have the power supply plugged back in. I plugged the power supply in and now I can move the z axis in both directions and the y and x is one direction (but not the other).
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 27, 2015 09:26PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 27, 2015 10:07PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 27, 2015 10:50PM |
Uncertainty
I'm back to printing at 230c (abs)/ bed 110->105c with great results. Extruder motor gets hella hot though, I'm worried it will warp the carriage. My Vref is at 0.38 but I fear going any lower due to skipping.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 28, 2015 08:06AM |
Uncertainty
ejnelson
I'm curious. Can you look at the voltage regulator on the arduino? Does it look cracked? It is very likely this is what went if it is still functional?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 28, 2015 04:58PM |
markts
Uncertainty
Interesting! I was having problems with the extruder clicking and I figured the temperature wasn't high enough (also ABS). Someone suggested LOWERING the temp and yep, it works much better. I think my last print was at 205? I'm not crazy about the stringiness of the ABS though (some of my stuff looks like Mini Wheats) so I'm still getting it dialed in. Last two prints at the lower temp had no skipping or clicking though,.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 28, 2015 07:54PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 28, 2015 09:05PM |
Non-warping, no smell, PET filament: June 29, 2015 08:14AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 29, 2015 10:34AM |
I got some sheet metal from Home Depot and used a shear/drill press. You could probably print a set of usable corner brackets but you kind of need tools to work with sheet metal.Quote
msaeger
How did you make the corner brackets? I am just starting but I am imagining there should be something like those in the corners.
