Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 06:29PM |
markts
I'm so glad you said that! What forum did you see that in?? Mine are also crunchy, but when I installed then into the holder they get very difficult to move.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 06:56PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 07:58PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 09:42PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 10:43PM |
madkow007
I have one question...is the board already flashed or do I need to flash it before I can use the printer?
The documentation is not clear on this at all.
If I do need to flash it...where can I get a Folgertech Marlin ZIP file?
Or do all the changes need to be made by hand? (entered one at a time)
I would be grateful for any help with this.
Thanks
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 11:39PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 11:45PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 11:55PM |
animoose
Markts: now I have the bed in place. It feels a little rough when I move it, but not too bad. I compared the sound it makes to a video of a different design, and they sound similar (https://www.youtube.com/watch?v=syId1BPUN8o around the 12:50 mark). One thing that helped was not to overtighten the nuts on the bearing mounts. I had them very tight at first, and when I slacked them off just a tiny amount the bed seemed to move better. Also you can slightly adjust the position of the SK8s.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 01, 2015 11:57AM |
Tenny
sent the Z to home and as it got close to home I suddenly heard a pop and my computer shut down
go_gn
What is the weight and dimensions of a packed kit?
markts
I do have to say, the manual is extremely well written. Kudos to Folger Tech for that. I'm not getting stuck trying to understand what to do, it's just doing it that sometimes is a challenge
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 02, 2015 10:07AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 02, 2015 10:24AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 02, 2015 10:32AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 02, 2015 10:35AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 02, 2015 11:37AM |
markts
animoose
Excellent. I was also able to get the bed mounted so it moves relatively freely.
I hope others on here don't mind my chronicles on putting this together.
I'm on page 14, step 3, mounting the 2.6 motor. It calls for using 20mm bolts but I'm finding all three bottom out a millimeter or two too early. The printed piece is still slightly loose. I'm considering drilling it slightly or going to to pick up shorter bolts. Thoughts?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 02, 2015 11:45AM |
madkow007
I printed off a new part and still did not fit.
I ended up using a couple washers there and I think 35mm bolts in another place that called for 40 mm bolts that would not fit. Starting to look like you get what you pay for and don't even get me started on the extruder design
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 02, 2015 12:19PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 02, 2015 12:28PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 02, 2015 12:39PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 02, 2015 01:36PM |
JoeH
Hey guys,
I ordered a Folger Tech 2020 i3 Prusa from ebay last Thursday, along with 2 spools of filament. The seller is asidewinderinc, I was just wondering if this is Folger tech's ebay store? or if they are affiliated in some way?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 03, 2015 01:28AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 03, 2015 08:21AM |
animoose
My construction continues. I am on step 10 (the Z carriage). This is physically the hardest step so far, in getting the bearings into the printed parts and in getting the Z carriage to the suggested size of 300mm. I found it hard to get one of the bearings in the extruder carriage to lie flat. I know I knocked some balls out of the LM8UU bearing when I fitted it, though it still seems to move quite smoothly. Maybe I'll fix this up later.
When I get to adding this step to my construction diary in my blog, I'll have a few suggestions on both the process and instructions. One immediate thing that would help is knowing what the tolerance on the 300mm distance between the left and right ends should be. Getting the last few millimeters was very hard and I think it ended up more like 302mm. I also think a better measure would be the center to center distance of the vertical bearings, which I think should be 360mm, by measuring it from the motors.
@markts: I didn't have any problems with the 20mm bolts for the 2.6 motor. There is a tiny amount of play after attaching it to the left end printed part.
I really don't want to have to start tearing things apart later trying to debug bad prints ("Is the problem those #$%#$% bearings that aren't smooth?")|
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 03, 2015 09:43AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 03, 2015 09:58AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 03, 2015 03:53PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 03, 2015 04:39PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 04, 2015 10:32AM |
animoose
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 04, 2015 12:26PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 04, 2015 12:36PM |
The7ank
So, I'm getting my kit today and I've read both the guides. But the guide for the older kit includes something about stepper motor driver tuning. Is that not needed with the new kit, or what?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 04, 2015 01:48PM |
