Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 28, 2015 12:58PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 28, 2015 01:59PM |
Easy
Sorry if this has been covered already, but is there a kit from Folger to convert my Folger acrylic frame printer to the 2020 aluminum frame?
Or a parts list?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 28, 2015 02:47PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 28, 2015 08:52PM |
animoose
It's the other way round for me: my printer kit has shipped and should arrive tomorrow, but my filament has a label and hasn't shipped. Both labels were printed on Monday (which was a holiday, so let's give Dan and John a break!).
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 29, 2015 10:07AM |
Devil Inc
Dan/John. I'm having issues with the side mounted spool. The extruder is 'slipping' trying to pull the filament once it gets tight with the spool. I had a jam because of it. If I can source a piece of 20/20 quickly, I'm going to relocate the spool up top similar to the OG i3 users to see if removing the side load helps. Just an observation I'm noticing. A 6" long piece and a few mounts would work, if my measurements are correct.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 29, 2015 10:09AM |
animoose
... or not. I got the filament today, but with the tracking number for the printer kit.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 29, 2015 11:10AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 29, 2015 11:40AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 29, 2015 09:41PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 29, 2015 09:50PM |
Devil Inc
Dan, I did see the updated guide, unless it was updated today. As for my extruder motor temps, dialing the current up or down, doesn't make a difference. It's HOT after a 6 min print.
I'm going to try the spare driver board tonight to see if that helps.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 29, 2015 11:12PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 30, 2015 03:40AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 30, 2015 08:50AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 12:06AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 01:09AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 01:10AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 01:46AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 11:05AM |
Tenny
markts
Anyone have trouble tightening the SK8 screws to grab the rods? I cranked down on one and the rod still slid right through. Am I doing something wrong?
How easy is it sliding?
At first I forgot to tighten mine and it moved but after that I tightened it and no movement since.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 12:29PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 12:53PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 02:17PM |
Tenny
I just realized all my prints are backwards as far as the x-axis. I think it was designed to have the limit switch on the right (when looking towards the front of the printer) as that stepper motor wire is backwards compared to the rest. Still though all prints are backwards which presents a problem...
Not sure if I invert the x in the printer software will fix it? Don't really want to re-wire that aspect.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 03:05PM |
Vanbot
Yep. Once again this is something the Folger manual gets wrong. Looks like they haven't fixed it in the manual for the new printer.
Just flip the motor cable where it plugs into the RAMPS. You can also do it in firmware but this is easier. Turn off power to the board first.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 03:43PM |
Tenny
Vanbot
Yeah I tried this and it's still not working properly. It would just go the opposite way of the end stop.
Steps I've done thus far: So I changed the firmware and inverted the x axis: #define INVERT_X_DIR false (was true before) Then I changed it to a max-end stop versus a min end stop: #define X_HOME_DIR 1 Then I manually moved the endstop cable from the x-min to the x-max.
Now my problem is that technically (I think) when it hits the end stop it should realize that's 200 not 0? So right now in the rep host if I home the X-Axis, it hits the max end stop and then it sets the number to 0. So when I press right it increases the "x number" but it doesn't move (it just increases the x value). It will not go left unless that number is > 0 obviously.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 03:45PM |
Vanbot
In Repetier if you open Printer Setting and then the Printer Shape tab what values do you have for Bed Left and bed Front?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 04:03PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 04:18PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 05:01PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 05:22PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 05:33PM |
markts
How well do your bearings slide down those chrome rods when it's all connected to the aluminum bed?
. When I first put the bearings on the rods in step 4 they felt graunchy. They are a little smoother after manually moving them back and foward. I've read about this in other forums, so I'm not worried by it.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 31, 2015 06:11PM |
