Re: Folger Tech 2020 i3 Printer Kit (Official Thread)
January 27, 2016 09:03PM
Whew! This printer is a lot of work but fun! Just finished putting the top bar on the frame. So far I have only had 1 hiccup so thats good!
January 27, 2016 10:19PM
tjnamtiw
Bert3D
DaveA
Bert3D
DaveA
I just installed a BLTouch sensor but I'm a little unsure how to set up the Z axis offsets. I'm running on Marlin RC3 with the changes from the Wiki merged in. I just need a little help in getting the vertical position set right.
I'm using [www.thingiverse.com] as the BLTouch mount on the stock FT extruder head. Anyone recently done this?
With that mount, assuming yours extruder is just like mine, it will be 31mm offset to the left on x, and 0 offset Y. The Z will vary, depending on the adjustment of your BLTouch. I raised mine up a bit to give the probe more clearance. That is a 2mm hex adjustment socket in the top of the BLTouch, which raises and lowers the pin.
Here are my settings, but yours could be different, so consider them just an example:
#define X_PROBE_OFFSET_FROM_EXTRUDER -31      // Z probe to nozzle X offset: -left  +right
#define Y_PROBE_OFFSET_FROM_EXTRUDER 0     // Z probe to nozzle Y offset: -front +behind
#define Z_PROBE_OFFSET_FROM_EXTRUDER -4.3 // -3.8    // Z probe to nozzle Z offset: -below (always!)
#define Z_RAISE_BEFORE_HOMING 7       // (in mm) Raise Z axis before homing (G28) for Z probe clearance.
                                        // Be sure you have this distance over your Z_MAX_POS in case.
#define XY_TRAVEL_SPEED 8000         // X and Y axis travel speed between probes, in mm/min.
#define Z_RAISE_BEFORE_PROBING 9   // How much the Z axis will be raised before traveling to the first probing point.
#define Z_RAISE_BETWEEN_PROBINGS 9  // How much the Z axis will be raised when traveling from between next probing points.
#define Z_RAISE_AFTER_PROBING 9    // How much the Z axis will be raised after the last probing point.
Thanks Bert3D. How did you arrive at the -4.3 offset for Z. Did you just sneak up on the trip point of the BLTouch with the probe extended and record the position and then sneak up on the nozzle just slightly above the bed and recording that point and then do the arithmetic?
Using that method I came up with -3.9 so maybe that's the correct approach.
I'm going to revert to RC2 and my original Z stop for a test after work. With my current setup the prints are awlful - just a ball of filament. So I'm not sure if it's the bed leveling or something else I missed in RC3
I just homed using G28, then started lowering the printhead using negative Z movements, like G1 Z-0.5 then G1 Z-1, etc., until I got the nozzle to just touch the bed. Then I noted the distance that made it just barely make contact, which was G1 Z-4.3. To insure accuracy, I raised the head to 2mm using G1 Z2, then lowered it again, verifying he nozzle stopped just where I wanted it. Tweak the number until it goes down to the exact right height, and that number is your z offset.
If you can't get it to move to negative coordinates, you can compare with my config here https://github.com/AlwaysTinkering/Marlin to see what's different.
My other code changes are for my hardware setup with the Graphic controller, Z Lead Screws, and X endstop on the left. I'm using the stock extruder and hot end setup.
I too am in the short strokes of installing/setting up the BLTouch. Mounted, wiring done, etc. I was under the impression that the Z offset was how high the nozzle was when the BLTouch tripped but it sounds like you used the point where the probe, while extended, hits the plate as the height below when the nozzle hits. I wonder which it is.
Incidentally, to get the X and Y offsets, I put a piece of masking tape on the table, raised the Z axis, put a little lipstick on the probe tip and nozzle and then lowered them down until they both made marks. Worked great.
The offset is the distance between the trigger point of the BLTouch, which will be at Z=0 once you home the Z axis, and the tip of the nozzle. When you home (G28) the BLTouch will trigger, and that sets the Z=0 height. Then move the head further down than zero using negative Z coordinates (ie G1 Z-1.5) just until the nozzle touches. Mine touched at G1 Z-4.3, so I knew the nozzle was that the trigger point was 4.3mm below the nozzle.
The only thing to be careful of, is to insure that the Z_RAISE_BEFORE_HOMING is enough that the BLTouch can deploy, and that your BLTouch is mounted such that it will trigger before the nozzle hits. (This is true for the bracket you listed and the BLTouch as it comes).
Folger Tech 2020 i3 Wiki
Custom google search for the Folger Tech 2020 i3 forum topic by Animoose
My Thingiverse Designs
January 27, 2016 10:24PM
sonnylowe
therippa
sonnylowe
mindstormmaster1
I need to calibrate my printer, but before I do I wanted to I wanted to upgrade my firmware from the stock firmware. I keep seeing talks about a new version (Merging RC2 and RC3) so I am wondering should I wait?
Also since my printer is running well what is the best process for upgrading without messing up all my settings?
You want therippa's version of Marlin (it's in his sig or the Wikia page), it is already RC3. The talk about merging RC2/RC3 was between a few select people. You will most likely still need to merge your current version of marlin with RC3 as there are a few setting that will need to translate over (E-Steps, PID if you ran autotune, Etc.).
As far as waiting to calibrate, it doesn't really matter if you do it now or later, either way those setting (mentioned above) will need to be transferred.
Hmmm, now that I think about it a bit more, I guess if you did it before you calibrated and missed an e-step setting (or got it wrong) it wouldn't matte as much since you'd be calibrating it after anyway...so now might actually be better in the long run!?!?
The firmware in my sig isn't RC3, it's the latest stable release.
My bad...I thought you were running RC3!?!?
I am personally running RC3, but the link in my sig is for the latest stable with the Folgertech stock settings
Need help? Visit the Folgertech Wikia Page
The latest Marlin firmware with Folgertech Prusa i3 settings merged in, get it here
And check out my designs on Thingiverse, and follow me if you like what you see!
January 27, 2016 10:46PM
I can't get the aluminum bed baring to pop in, did you guys sand it down?
January 27, 2016 10:50PM
therippa
sonnylowe
therippa
sonnylowe
mindstormmaster1
Okay, I feel a bit better now, I thought I was losing my mind LOL
My Stuff on Thingi
FolgerTech Wikia Page
Custom Search by Animoose
MakerSL.com
January 27, 2016 10:51PM
UltiFix
Do whatever it takes to make it fit, you can always print out therippa's version once your printer in up and running smiling smiley
My Stuff on Thingi
MakerSL.com
January 27, 2016 11:08PM
Well I had some printer downtime tonight so I decided to install the Gen-2 Offset Belt version of my Y-Axis upgrade. Here's a couple pix and a short video of it homing. I have used a lot of force to try to get the gantry to wobble, shift, sway, pitch, roll, yaw, move in any way other than right down the rail...I am happy to say it is as stable as the center belt version, but we all know time (and printing) will tell the full story ;-)
ALBUM
VIDEO
BTW: I am currently testing a Capacitive Sensor, I used my finger to trip it when probing Z...pretty damn cool if you ask me cool smiley
My Stuff on Thingi
MakerSL.com
January 27, 2016 11:18PM
sonnylowe
ALBUM
VIDEO
Pretty cool, printer seems nice and quiet. Does the capacitive sensor plug right where the z min sensor goes?
January 28, 2016 12:41AM
sonnylowe
UltiFix
Dremel works nice, It's all in place now grinning smiley Sadly I need to go to bed soon -_- and I have a busy day tomarrow. But the weekend is coming! Wahoo! I hope to have it done by sunday night... If all goes according to plan, which it definetly will not LOL
Thanks guys! That wiki is AWESOME!
January 28, 2016 03:33AM
sonnylowe
ALBUM
VIDEO
Looks awesome. Might be tempted to swap mine over to this.
January 28, 2016 03:55AM
marc2912
sonnylowe
ALBUM
VIDEO
Yeah, it should run just as quiet as Gen-1 smiling smiley
Yes, a Capacitive Proximity Sensor wires up exactly like the Inductive Prox Sensor...if it's NO it will also have the same exact firmware changes. In the case of this particular sensor, it is NC so the firmware setting are a bit different.
My Stuff on Thingi
MakerSL.com
January 28, 2016 09:20AM
Used an x-acto knife to take off just enough plastic for the bearings to go in. Onward to mounting the motors. My goal is to turn it on on Sunday.
January 28, 2016 04:37PM
The guide calls for two 2.6 motors and one 4.8, I have no 4.8, but I do have a 5.3, is that ok?
EDIT:
Never mind, I see this is common.
Edited 3 time(s). Last edit at 01/28/2016 04:53PM by UltiFix.
January 28, 2016 04:57PM
Im stuck on a supposedly simple step, I need to attach the motor's to the mounts and use an acrylic rod keeper, they don't picture it and im not sure were it goes or what it is...
Edit
Im assuming the clear pieces are what they are talking about? In the picture they are black and blend in....
Edited 1 time(s). Last edit at 01/28/2016 05:00PM by UltiFix.
January 28, 2016 05:34PM
UltiFix
Edit
Yes, it's hard to see in the picture because they're clear. Just get the orientation correct where the hole goes (that holds the rod). It's explained in the text of the manual.
January 28, 2016 05:44PM
markts
UltiFix
Edit
Awesome thanks! I don't think having the bearing holders 3d printed was a good idea...
January 28, 2016 06:19PM
Am I supposed to cut the 2 meter belt in half? It doesn't say in the instructions... It just calls for a 1 meter belt. Also I didn't see anything in the build blog. Just don't want to mess up the parts!
Thanks!
Sam
Edited 3 time(s). Last edit at 01/28/2016 06:40PM by UltiFix.
January 28, 2016 06:56PM
When I installed the bearings into the left side 3d printed part the side cracked, think it will still hold up fine? Not exactly sure why it's attached there anyway.
[prntscr.com]
January 28, 2016 08:26PM
UltiFix
[prntscr.com]
That's supposed to have a seam there so it can expand to let you get the bearing in there.
Newbie with Folgertech 2020 i3.
January 28, 2016 08:33PM
Quick question: My X-Axis motor is pretty hot to the touch, I can leave my thumb on it for about 30-45 seconds before I have to pull it off. Whereas my Y-Axis motor is warm but not at all hot.. Is the X-Axis motor suppose to run so warm? If not, what do I need to do to run it cooler?
New Wikia page: [folgertech.wikia.com]
January 28, 2016 08:37PM
john-i
You need to tune the driver, it's probably sending too much current and is very common. Be careful when you do this, many have fried their board doing this.
January 28, 2016 08:39PM
UltiFix
Thanks!
Sam
When I built mine, I just connected the entire belt to one side of the X carriage, and then fed it around to the other side so that I knew where to cut to have a proper length. You can cut the belt a bit long, and you should have enough for the other axis if I remember correctly.
Folger Tech I3 2020 Wikia page: [folgertech.wikia.com]
Custom Folger Tech I3 2020 custom search
January 28, 2016 08:48PM
sonnylowe
ALBUM
VIDEO
That is downright beautiful work!
Folger Tech 2020 i3 and FT-5 as well as modified JGAurora A5 with direct drive E3D/Titan. All running the BLTOUCH.
Great kits. Having fun and running the heck out of them.
Running Marlin 1.1.0 RC8 on the i3 and FT5. Custom firmware on A5.
Folger Tech Wiki board >[folgertech.wikia.com]
January 28, 2016 11:23PM
Still working to get the BLTouch to work with my 2020 and RC3. I tried the settings on the Wikia as well as those on Bert's git page. My Z axis goes up instead of down, which it never did before. Strange.
The biggest head scratcher is that with the laptop hooked up via USB, the BLTouch goes through it's self test and then solid red waiting for a probe. If I unhook the USB and go strictly off of the power supply, I get no self test and just flashing on the BlTouch. Any idea what that might be? Searches yield nothing.
Thanks! I WILL PREVAIL!!!! Grrrrrrrrrr.
January 29, 2016 12:42AM
Installing the bearings are a total pain in the BUT! 3D printed mounts was definietly not the way to go... Fortanetly I have 1 left, then im done with bearings!!! Yay! Im having to remove material on all of the bearing mounts.
January 29, 2016 01:54AM
Well I can't attach the extruder to the 3d printed part... The holes arent lined up and I may have stripped the motor a bit.
I got it on, after drilling out a hole... Did you guys tape your extruder on at all or attach it any other way than the screws?
Edited 1 time(s). Last edit at 01/29/2016 02:03AM by UltiFix.
January 29, 2016 02:09AM
UltiFix
Well I can't attach the extruder to the 3d printed part... The holes arent lined up and I may have stripped the motor a bit. Am I screwed?
The holes on my X carriage did not line up either. What I had to do is hold the motor as far away from the X carriage as I could while having the screws in all the way into the carriage, and then work the motor towards the carriage by screwing the screws into the motor equally.
January 29, 2016 04:28AM
tjnamtiw
If it moves up instead of down most likely the "endstop inverted" setting needs to be changed. The BLtouch like the Prox sensor are NO unlike the FT endstops that are NC
// Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup).
const bool X_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Y_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Z_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool X_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Y_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Z_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Z_MIN_PROBE_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
//#define DISABLE_MAX_ENDSTOPS
//#define DISABLE_MIN_ENDSTOPS
Is your BLt getting power directly from the Ramps, if so there could be a lack of power from the ramps, usually the BLt can run off the lower current on those contacts!?!? Does it go into alarm mode when you unplug the laptop? In that case the simple fix might be to unplug the BLt power leads from the Ramps to reset it. These is a command prompt that will do that as well but I can't think of it off the top of my head!?!?
Here's my config-h
Edit: Check your ednstop status to see what's triggered, I really think this is an endstop issue... The command is M119 I think!?!?
Edited 1 time(s). Last edit at 01/29/2016 05:28AM by sonnylowe.
My Stuff on Thingi
MakerSL.com
January 29, 2016 04:50AM
sonnylowe
tjnamtiw
Here's my config-h
I'm seeing pretty much the same thing on mine...except my BLTouch gives me a fast flashing LED no matter what I do. Is that a power issue? If so, where besides the servo pins is good to get power to it?
Folger Tech 2020 i3 w/Misumi bearings, Borosilicate bed, BuildTak, BLTouch, 12864 LCD, lead screw z-axis, DRV8825, Toranado extruder & E3D V6 driven by Simplify3D and an Octopi.
January 29, 2016 05:26AM
GrouchoDuke
sonnylowe
tjnamtiw
Here's my config-h
I'm honestly not sure as I never had a power problem, I just know it's not recommended to drive a servo from the board due to low current. However the current draw on the BLt is super low, so mine always worked...I beleive the draw on the White version is even lower!?!?
As far as 5V from elsewhere, you could just use a phone changer and hack the connect...although I wouldn't use a cheap wimpy one, maybe one from a table would be better...
The other option would be a step-down circuit, just like dropping the voltage on the Prox Sensors...Tom's guide shows you how to do that, then you could pull power directly from the PS or the aux 12V pins.
I am currently running a different sensor, but if I went back, I'd use a Tablet Charger to be on the safe side smoking smiley
My Stuff on Thingi
MakerSL.com
