Re: P802M Prusa i3 Unofficial Support Thread September 14, 2016 10:50AM |
Re: P802M Prusa i3 Unofficial Support Thread September 14, 2016 11:32AM |
Re: P802M Prusa i3 Unofficial Support Thread September 14, 2016 11:44AM |
Re: P802M Prusa i3 - suggestion to speed up bed heating September 15, 2016 03:38PM |
I've done some more experimentation today, sadly it seems to me that it really is the steel heating up so well -- stuffing the gaps with aluminum foil doesn't seem to help any. OTOH the piece of scrap metal gets screamingly hot compared to the rest of the bed, so (a) maybe I'm just heating up the thermistor better and (b) bodes well for the stainless steel build plate I have on order.Quote
robmilr
I think this effect has been the result of filling in air gaps between the bed heater and the build plate, rather than something special about the coefficient of heat transfer between iron and aluminum. If this is the case, you may be able to speed up your bed heating time with a few layers of aluminum foil (I would place shiny side up towards build plate) between the bed heater and the build plate.
Re: P802M Prusa i3 Unofficial Support Thread September 18, 2016 06:08AM |
Re: P802M Prusa i3 Unofficial Support Thread September 19, 2016 11:48AM |
yup, Melzi just ain't big enough. Sorry, can't remember what I turned off, but went ahead and ordered one of the 12864 display + RAMPS + Mega kits off Amazon when I ran into that. Just received it this evening, next to figure out how to mount the display -- but at least it is standard, so I can switch to Marlin easily too now.Quote
Gatchaman
"Sketch uses 130,084 bytes (100%) of program storage space. Maximum is 130,048 bytes."
Re: P802M Prusa i3 Unofficial Support Thread September 20, 2016 12:21PM |
Re: P802M Prusa i3 Unofficial Support Thread September 20, 2016 06:26PM |
Re: P802M Prusa i3 Unofficial Support Thread September 21, 2016 06:29PM |
Re: P802M Prusa i3 Unofficial Support Thread September 22, 2016 12:43AM |
davidmilunic
Awesome job on the RC5!
I was a bit frustrated with the original firmware supplied by Zonestar.
The autolevel never seemed to be right, particularly the very last corner that it would probe.
It always reported it as 2mm higher than all the other spots (which couldn't be possible).
Re: P802M Prusa i3 Unofficial Support Thread September 22, 2016 01:16AM |
Re: P802M Prusa i3 Unofficial Support Thread September 22, 2016 01:52AM |
glimpse79
In these days i had big trouble with my zonestar prusa, prints suddenly hangs after a variable number of hours (1 to 4), the problem happens either using serial and SD card.
I thought it was caused by too much ambient heat but it happens even at night; any ideas?
Thanks in advance
Re: P802M Prusa i3 Unofficial Support Thread September 22, 2016 06:52AM |
Re: P802M Prusa i3 Unofficial Support Thread September 23, 2016 01:17PM |
Re: P802M Prusa i3 Unofficial Support Thread September 25, 2016 11:53PM |
Re: P802M Prusa i3 Unofficial Support Thread September 27, 2016 10:49AM |
Re: P802M Prusa i3 Unofficial Support Thread September 28, 2016 06:07AM |
Re: P802M Prusa i3 Unofficial Support Thread September 28, 2016 07:40AM |
Re: P802M Prusa i3 Unofficial Support Thread September 29, 2016 05:49AM |
Gatchaman
Can anyone help me with the extruder heat sink .
When the heat sink is placed in position it isn't flush with extruder. The two bolts that hold the extruder stepper in place stick out by ~1mm so the heat sink doesn't actually touch anything. So I'm left with a ~1mm gap between the metal block and the heat sink.
I'm trying to dremel a space for the bolt heads to fit into so the heat sink is flush but I'm just asking if anyone has experienced this issue before.
Kind of fixed the issue with a lot of dremelling and a bit of foil.
Re: P802M Prusa i3 Unofficial Support Thread September 29, 2016 12:52PM |
Re: P802M Prusa i3 Unofficial Support Thread September 29, 2016 03:31PM |
Re: P802M Prusa i3 Unofficial Support Thread September 30, 2016 03:15AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: P802M Prusa i3 Unofficial Support Thread October 08, 2016 02:26PM |
Re: P802M Prusa i3 Unofficial Support Thread October 08, 2016 03:51PM |
I am not familiar with the M-505. Is it auto levelling? Did you follow the setup instructions on the sd card?Quote
MiniMfg
I'm pretty sure you've heard this before. I just finished assembling a Prusa i3 M-505 and I have NO IDEA what to do now. My specific question at this point is how do I limit the movement of the extruder? When I try to anything it moves outside the bed parameters and below or actually hits, the bed. I can't get help from the sellers. They got their money and simply don't care.
Any help would be greatly appreciated. Tony
Re: P802M Prusa i3 Unofficial Support Thread October 08, 2016 06:58PM |
Re: P802M Prusa i3 Unofficial Support Thread October 08, 2016 07:17PM |
MiniMfg
Yes. At this point: When I hit Start print, the extruder moves all the way to the stop on the left and stays there. Then the temp starts to rise. Every time it hits 240 degrees which I think is too high I hit the emergency stop because I'm thinking it might burn out. It's my understanding the temp only need to be about 175. Am I wrong? Should I let it go and see what happens?
BTW, I have a very simple gcode loaded for test purposes.
Also I don't know how long ago you responded. I didn't know how to find it. Just joined. Thanks very much. Tony
Re: P802M Prusa i3 Unofficial Support Thread October 08, 2016 07:33PM |
Re: P802M Prusa i3 Unofficial Support Thread October 09, 2016 04:36AM |
Re: P802M Prusa i3 Unofficial Support Thread October 09, 2016 01:36PM |
Re: P802M Prusa i3 Unofficial Support Thread October 09, 2016 04:25PM |
