Re: P802M Prusa i3 Unofficial Support Thread January 27, 2017 09:35PM |
Evorowy
Hello folks!
As with the Marlin Firmware update (and skynet) I want to upgrade current software which my P802 is running now.
AFAIK i need to tune certain Header to make all Working for intstance the auto-level sensor distance from extruder.
Also during some prints i Have few i suppose logical questions connected to printer behaviour.
Why, on earth, during heating extruder and bed, fans are on full speed? (Extruder fan is preventing from filament spilage, but the "printing" fan? Why it is on full speed?)
Why homing and autoleveling catches AFTER extruder became fully heated? It makes filament spill scross the heating bed and is really nasty.
Why the "wiping across distances" dosen"t work?
I Have to admit that i use the stock pre uploaded on Melzi.
Kind regards!
Re: P802M Prusa i3 Unofficial Support Thread January 31, 2017 07:11AM |
Re: P802M Prusa i3 Unofficial Support Thread February 07, 2017 12:25PM |
Re: P802M Prusa i3 Unofficial Support Thread February 27, 2017 05:45AM |
leonard9500
Any help would be very appreciated, thank you.
Re: P802M Prusa i3 Unofficial Support Thread March 16, 2017 05:21PM |
Re: P802M Prusa i3 Unofficial Support Thread March 26, 2017 03:18PM |
Re: P802M Prusa i3 Unofficial Support Thread March 26, 2017 07:36PM |
Re: P802M Prusa i3 Unofficial Support Thread March 29, 2017 10:40PM |
gwc2795
I have added the P802M Firmware, P802M Printed Parts and P802M Instructions on a Google Drive.
Hope they help.
[drive.google.com]
Re: P802M Prusa i3 Unofficial Support Thread April 02, 2017 05:29AM |
Azurha
Hi o/
My melzi board was failing. So i replace it by ramps 1.4+ arduino, but i have some problem for fix the Z prob, my print start more or less 10mm above the bed.
i have a metallic sensor for the Z.
Anyone can share the configuration.h please ?
Thanks
Benoit
Re: P802M Prusa i3 Unofficial Support Thread April 02, 2017 09:18PM |
Re: P802M Prusa i3 Unofficial Support Thread April 19, 2017 11:41PM |
Supermec
Twmaster, first check for dry joints where the bed connector pins are soldered into the board. Check that the resistance connected to the gate of the bed mosfet reads correctly at 10K and that there are no dry joints associated with the soldering of the mosfet onto the board. Make sure that the bed power feed wires are correctly inserted into the connector and well tightened. For the next bit just be careful with the voltmeter probes not to accidentally short anything. With everything connected, power up the board and check the following voltages relative to the board ground with the bed OFF- both sides of the bed power connection should read +12V and the bed mosfet gate voltage should read 0V. Set the controller to heat the bed, the voltage at the gate of the bed mosfet should now read +5V and the voltage on the bed power connection nearest to the hot end connector should have dropped to close to 0V.
If you don't get +12V on both bed connections with the bed turned OFF then you have a power feed problem. If you get +5V on the gate of the bed mosfet with the bed turned ON and both of the bed connections still read +12V then the bed mosfet has gone open circuit. If you don't get +5V on the gate of the bed mosfet with the bed turned ON then you either have a processor problem or the track that feeds the gate from the processor has a break or a dry joint in it (turn off before checking for these).
Re: P802M Prusa i3 Unofficial Support Thread November 02, 2017 05:42AM |
Re: P802M Prusa i3 Unofficial Support Thread November 04, 2017 04:18AM |
Re: P802M Prusa i3 Unofficial Support Thread November 29, 2017 05:43PM |
