Re: RepRap Guru i3 Printer Kit (Official Thread) February 22, 2017 01:59PM |
QuoteQuote
lsmith1437
I've designed an X-Axis tension block as a drop-in part for the RepRapGuru. Works with the V1 and V2:
[www.thingiverse.com]
It requires some very inexpensive hardware from the likes of Ace Hardware. I'm using it right now, it works like a charm.
I also started a group for RepRapGuru group on Thingiverse:
-L. Smith
Re: RepRap Guru i3 Printer Kit (Official Thread) February 25, 2017 12:33PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) February 25, 2017 12:43PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) February 27, 2017 04:35PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) February 28, 2017 05:53PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) March 01, 2017 05:23PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) March 04, 2017 11:00AM |
Re: RepRap Guru i3 Printer Kit (Official Thread) March 04, 2017 04:29PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) March 05, 2017 12:57PM |
MostTornBrain
adlammons
I am running REPRAP_GURU_MARLIN_V.2 but it doesn't include auto bed leveling. MARLIN 1.1.0RC8 does have auto bed leveling. However, I can't tell if it would be an issue to use it instead.
Is there a newer version of the Marlin software?
Or, can I just load the Marlin-1.1.0-RC8?
I've switched to the RC8 version of Marlin and it is working well for me, however I have not enabled the bed leveling as I don't have the hardware for it. The RC8 firmware has some new features which are very nice. However, the Marlin firmware configuration files have changed a lot since the REPRAP_GURU version (which was from 2014, I think) so it is a bit tedious having to make sure you bring over all the right settings from configuration.h and configuration_adv.h.
One key thing is they've changed the algorithm for how the jerk and acceleration are calculated, so you may need to adjust the value your were using (I've found cutting it by 50% was needed) otherwise you may notice some worse ringing in the walls of your prints after the nozzle turns a corner.
If you enable and calibrate the LIN_ADVANCE feature, it makes a significant improvement in the quality of the prints. There's a tutorial here for it: [marlinfw.org]
Re: RepRap Guru i3 Printer Kit (Official Thread) March 05, 2017 01:35PM |
Turboaddiction
Maybe you could share your copy to help the less experienced of us on getting this setup and working? Im working on getting this all setup and for me ill just have a lot of trial and error. But maybe at the least we will get this going with help as a group.
Re: RepRap Guru i3 Printer Kit (Official Thread) March 05, 2017 08:35PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) March 08, 2017 10:38PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) May 15, 2017 04:39AM |
Re: RepRap Guru i3 Printer Kit (Official Thread) May 21, 2017 02:28PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) May 24, 2017 02:30PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) May 25, 2017 07:00PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) May 25, 2017 07:11PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) May 26, 2017 06:48PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) May 26, 2017 06:58PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) May 26, 2017 09:23PM |
. If something is going backwards you can see in the diff of the configuration linked above where I'm telling it to reverse some of the steppers so just toggle those true/false values to get things moving the right way or flip around the wire plugged into the ramps board either way will work. Make sure if you do start plugging and unplugging things on the board it's all powered down until things are plugged in or you can accidentally short things or just cause sparks and rushes of current through components and wires which they don't seem to appreciate.|
Anonymous User
Re: RepRap Guru i3 Printer Kit (Official Thread) June 11, 2017 05:10PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) July 24, 2017 02:16PM |
Anonymous User
Re: RepRap Guru i3 Printer Kit (Official Thread) July 24, 2017 02:41PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) July 24, 2017 03:39PM |
3disforme
When I got my reprap Guru a few months ago, the bed was actually missing the thermistor completely (so I got no reading, just like you). No big deal, I just printed without heating the bed for a few days. I emailed the manufacturer and they promptly sent a replacement part, no questions asked.
Anonymous User
Re: RepRap Guru i3 Printer Kit (Official Thread) July 24, 2017 03:51PM |
Anonymous User
Re: RepRap Guru i3 Printer Kit (Official Thread) July 24, 2017 04:25PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) July 24, 2017 04:51PM |
3disforme
The extruder fan should be always on (not controllable). The fan control in Repetier and on LCD is for a cooling fan which can be added later. The extruder fan is supposed to run %100 at all times to keep the filament from melting inside your extruder. I've seen a lot of people in forums say that they have disabled the extruder fan without issues but thought I'd mention it. So no resistance reading on the heat block thermistor either? Hmmm... Hopefully tech support gets you quick resolution! Working through these issues is a great way to familiarize yourself with the printer. Good luck! Let me know if I can help. Also, Facebook has some great 3D printing groups with a lot of experienced users. I've learned a lot by reading through comments in groups!
Anonymous User
Re: RepRap Guru i3 Printer Kit (Official Thread) July 24, 2017 07:06PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) August 25, 2017 08:51AM |
Re: RepRap Guru i3 Printer Kit (Official Thread) August 31, 2017 10:43PM |
