Spark Cube Laser Add-on December 17, 2015 05:36AM |
Re: Spark Cube Laser Add-on December 17, 2015 05:55AM |
Admin Registered: 16 years ago Posts: 13,906 |
Re: Spark Cube Laser Add-on December 17, 2015 06:13AM |
Jtech Seite
The laser has an ABSOLUTE MAXIMUM of 2W and should only be run at this level for very short times. Additional cooling techniques would be advisable if you want to run for extended periods at this high power. 1 amp at 1.2W will allow for longer “on” times and will not degradate the laser as quickly. Thermal issues are the number one reason for catastrophic failure of the laser. while the mounting case provides heat sinking capability for the laser diode, it is up to the consumer to make sure the laser is operating effectively within these limits.
Re: Spark Cube Laser Add-on December 17, 2015 06:25AM |
Re: Spark Cube Laser Add-on December 23, 2015 07:54AM |
Re: Spark Cube Laser Add-on December 26, 2015 05:10PM |
Re: Spark Cube Laser Add-on December 26, 2015 05:19PM |
Re: Spark Cube Laser Add-on December 27, 2015 04:39AM |
Re: Spark Cube Laser Add-on December 27, 2015 06:47AM |
Re: Spark Cube Laser Add-on December 27, 2015 07:46AM |
Re: Spark Cube Laser Add-on December 27, 2015 08:00AM |
Re: Spark Cube Laser Add-on December 27, 2015 08:24AM |
Re: Spark Cube Laser Add-on January 02, 2016 06:36AM |
Re: Spark Cube Laser Add-on January 02, 2016 10:51AM |
Re: Spark Cube Laser Add-on January 02, 2016 10:54AM |
Re: Spark Cube Laser Add-on January 02, 2016 11:23AM |
Re: Spark Cube Laser Add-on January 02, 2016 12:33PM |
SteffenS
Denkst du, du kannst mit deinem Laser dann auch solche Gravierkunststoffe bearbeiten? [cnc-plus.de]-
Re: Spark Cube Laser Add-on January 02, 2016 03:32PM |
Re: Spark Cube Laser Add-on January 02, 2016 04:36PM |
Re: Spark Cube Laser Add-on January 04, 2016 05:29PM |
Re: Spark Cube Laser Add-on January 05, 2016 03:01AM |
Re: Spark Cube Laser Add-on January 05, 2016 05:34AM |
Re: Spark Cube Laser Add-on January 11, 2016 04:48AM |
Re: Spark Cube Laser Add-on February 13, 2016 01:48PM |
Re: Spark Cube Laser Add-on February 13, 2016 02:36PM |
Re: Spark Cube Laser Add-on February 13, 2016 03:27PM |
Re: Spark Cube Laser Add-on February 13, 2016 03:32PM |
Re: Spark Cube Laser Add-on February 13, 2016 03:36PM |
Re: Spark Cube Laser Add-on February 13, 2016 04:33PM |
Re: Spark Cube Laser Add-on February 13, 2016 05:55PM |
