Re: R2 Evo di NicolaP Thread Ufficiale November 22, 2017 03:11AM |
Re: R2 Evo di NicolaP Thread Ufficiale December 07, 2017 07:49AM |
//=========================================================================== //============================= Filament Runout Sensor ====================== //=========================================================================== #define FILAMENT_RUNOUT_SENSOR // Uncomment for defining a filament runout sensor such as a mechanical or opto endstop to check the existence of filament // It is assumed that when logic high = filament available // when logic low = filament run out #ifdef FILAMENT_RUNOUT_SENSOR const bool FILRUNOUT_PIN_INVERTING = false ; // Should be uncommented and true or false should assigned #define ENDSTOPPULLUP_FIL_RUNOUT // Uncomment to use internal pullup for filament runout pins if the sensor is defined. #define FILAMENT_RUNOUT_SCRIPT "M600" // Script execute when filament run out #endifE' sufficiente impostare FILRUNOUT_PIN_INVERTING a true?
Re: R2 Evo di NicolaP Thread Ufficiale December 07, 2017 07:56AM |
Re: R2 Evo di NicolaP Thread Ufficiale December 07, 2017 09:25AM |
Re: R2 Evo di NicolaP Thread Ufficiale December 07, 2017 02:54PM |
Re: R2 Evo di NicolaP Thread Ufficiale December 12, 2017 11:36AM |
Re: R2 Evo di NicolaP Thread Ufficiale December 30, 2017 07:52AM |
Re: R2 Evo di NicolaP Thread Ufficiale January 12, 2018 10:35AM |
Re: R2 Evo di NicolaP Thread Ufficiale January 14, 2018 05:05AM |
Re: R2 Evo di NicolaP Thread Ufficiale January 14, 2018 06:10AM |
Re: R2 Evo di NicolaP Thread Ufficiale January 14, 2018 06:36AM |
Re: R2 Evo di NicolaP Thread Ufficiale January 14, 2018 08:47AM |
Re: R2 Evo di NicolaP Thread Ufficiale January 15, 2018 02:36PM |
Re: R2 Evo di NicolaP Thread Ufficiale - questa dovevo ancora vederla! February 13, 2018 09:56AM |
MagoKimbra
Nicola... Ti devi decidere a rilasciare il nuovo fw... Ho messo il doble check sul fine filo... Praticamente se legge sullo switch il fine filo continua e dopo pochi millisecondi ricontrolla se rileva ancora la mancanza allora parte la procedura fine filo altrimenti continua come nulla fosse...
Purtroppo gli switch messi cosi sul pin diretto senza un filtro possono dare questi disturbi...[/quote
Nessuna novita' a riguardo??
A.
Re: R2 Evo di NicolaP Thread Ufficiale - questa dovevo ancora vederla! February 15, 2018 12:50AM |
Re: R2 Evo di NicolaP Thread Ufficiale February 15, 2018 09:24AM |
Re: R2 Evo di NicolaP Thread Ufficiale February 15, 2018 12:58PM |
Re: R2 Evo di NicolaP Thread Ufficiale February 15, 2018 05:38PM |
Re: R2 Evo di NicolaP Thread Ufficiale February 16, 2018 08:55AM |
Re: R2 Evo di NicolaP Thread Ufficiale February 16, 2018 11:25AM |
Re: R2 Evo di NicolaP Thread Ufficiale February 16, 2018 01:48PM |
Re: R2 Evo di NicolaP Thread Ufficiale February 16, 2018 02:38PM |
Re: R2 Evo di NicolaP Thread Ufficiale February 16, 2018 03:02PM |
Re: R2 Evo di NicolaP Thread Ufficiale March 14, 2018 05:29AM |
Re: R2 Evo di NicolaP Thread Ufficiale March 15, 2018 01:34PM |
Re: R2 Evo di NicolaP Thread Ufficiale March 19, 2018 09:07PM |
Re: R2 Evo di NicolaP Thread Ufficiale March 22, 2018 03:25PM |
Re: R2 Evo di NicolaP Thread Ufficiale April 02, 2018 10:34AM |
Re: R2 Evo di NicolaP Thread Ufficiale April 02, 2018 05:43PM |
Re: R2 Evo di NicolaP Thread Ufficiale April 03, 2018 01:49AM |
