Category:DriveTrains
Drive trains, also called mechanisms or mechanical systems,
are ways to transform mechanical motion from the stepper motors or DC motors into a precise movement of the desired part of the RepRap.
The mechanical systems are the part of the RepRap machine that move either the print head, the build platform or both. Generally you have a motor which rotates and that rotation is either used directly as rotational movement, or it is converted into linear movement. The various forms of movement are discussed below.
Some of the articles in this category focus on one specific part of a drive train -- an improved gear, pulley, or rack-and-pinion.
rotary to linear motion conversion
Most drive trains convert the rotary motion of the motor into linear motion. There are 2 popular techniques used by most RepRaps and RepStraps so far:
- Belt or chain drive: belt, PonokoBedChainFitting
- threaded rod (very popular for CNC mills): Screw-drivenLinearAxis
Other promising techniques currently under development that may turn out better than both include:
- scrap 35mm film (perhaps with encoder stripes printed on it): RepRap forums: "35mm film driven repstrap"
- rack and pinion: RBS/Rack; RepRap forums: "rack and pinion versus belt?"; "A printable, high speed alternative to belts?"; "using kapton tape as a slide ... rack and pinion system"
- "linear actuator" has a motor that spins a nut around a fixed, threaded rod.
- capstan and bowstring: Spooled wire or cable fiddle drill: Wrap turns of cable around a shaft and turn the shaft. Examples: Tantillus, SLS wax printer, http://web.mit.edu/imoyer/www/portfolio/foamcore/index.html
- winch: B&TRap
overall layout
Other articles in this category describe the overall layout of a complete drive train, of which there are currently 3 major categories being developed by RepRap developers:
- serial Cartesian drive train (the first ones to successfully RepRap)
- serial polar drive train
- parallel drive train
(This is far from exhausting the theoretical space of all possible drive trains -- for example, there has been a brief discussion[1] of a parallel Cartesian drive train.[2], and the Columbus design has a partially parallel Cartesian drive train).
Cartesian Robot (3-axis machine)
Have all possible ways to connect X, Y, and Z in series already been explored?:
- up-and-down axis supports one horizontal axis: Mendel, Doboz.
- one horizontal axis supports one up-and-down axis: WolfStrap
- up-and-down axis neither supporting nor supported by a horizontal axis: Darwin, Development:McWire
- ... is there some other series arrangement I'm missing?
- Is there any significant advantage or disadvantage of one series arrangement over another?
- Which (if any) parallel or partially-parallel drive train is better than the best series drive train?
The Cartesian Robot is a very standard style of positioning system that uses the familiar X/Y/Z coordinate system. Basically, you have 3 perpendicular linear axes: X, Y, and Z. A stepper motor controls each axis and can move it back and forth. One axis will generally be mounted on another axis, while the other axis is standalone. The build platform will be mounted on one axis, and the print head will be on the other. Common configurations are:
- Print head on X/Y assembly, build platform on Z axis
- Print head on Z axis, build platform on X/Y
- Build platform on X axis, print head on Y/Z
The RepRap project has developed many different Cartesian Robot machines:
- Darwin's 3-Axis System - print head on X/Y axis, build platform on Z. Made from RP parts and steel rod. Belt driven.
- McWire Cartesian Bot - McWire Cartesian Bot. Print head on Z, build platform on X/Y. Threaded rod driven.
- Mendel -- Print head on X/Z axes, build platform on Y. Belt driven X and Y, screw driven Z.
Polar Coordinate Robot
see Polar
This style of printer consists of a turntable, an X axis, and a Z axis. The table rotates a build platform, the X axis moves a print head from the center of the table to the outside of the table, and a Z axis moves the print head up or down vertically.
The RepRap project does not currently support a particular polar robot, but we are excited to see several promising prototypes. See Polar for details.
Pages in category "DriveTrains"
The following 28 pages are in this category, out of 28 total.
