Re: Flexidrive is Flex3Drive Early Birds December 07, 2015 02:06AM |
Re: Flexidrive is Flex3Drive Early Birds December 25, 2015 07:55AM |
Re: Flexidrive is Flex3Drive Early Birds January 02, 2016 12:27PM |
Re: Flexidrive is Flex3Drive Early Birds January 27, 2016 06:19PM |
Re: Flexidrive is Flex3Drive Early Birds January 28, 2016 12:13PM |
Re: Flexidrive is Flex3Drive Early Birds January 31, 2016 02:24AM |
The-Force
I'm very interested in this extruder but I use a lot the "pause at height" plugin in cura to change filaments while printing. After changing it I manually extrude until the filament comes out with the right color, manually meaning I spin the gears with my hand. How could I do the same with a flex3drive?
If I could extrude some filament using marlins interface... but as soon as I touch the button it resumes the print :/
Re: Flexidrive is Flex3Drive Early Birds February 17, 2016 03:27AM |
Re: Flexidrive is Flex3Drive Early Birds February 17, 2016 08:57PM |
Re: Flexidrive is Flex3Drive Early Birds March 17, 2016 05:54PM |
Re: Flexidrive is Flex3Drive Early Birds March 18, 2016 02:01AM |
Qdeathstar
Hello.
I was wondering if there are limitations in the types of material you can print. Also, what is the life expectancy of this product.. the gears are made of Nylon, how long do they last?
Re: Flexidrive is Flex3Drive Early Birds March 25, 2016 01:34PM |
Re: Flexidrive is Flex3Drive Early Birds March 26, 2016 09:13AM |
Re: Flexidrive is Flex3Drive Early Birds March 26, 2016 11:48AM |
Re: Flexidrive is Flex3Drive Early Birds April 15, 2016 05:50AM |
Re: Flexidrive is Flex3Drive Early Birds April 16, 2016 12:51AM |
Re: Flexidrive is Flex3Drive Early Birds April 16, 2016 04:58AM |
Mutley3D
lkcl - Not quite sure in my minds eye what you are describing regarding the 6mm hole, however it doesnt sound like anything overly difficult to cater for if it isnt already. As for quick release mounting, this shouldnt be too difficult either. The mounting arrangement would lend itself to a baseplate that the extruder assembly is bolted to, and then the baseplate can have the requisite features to interface with the quick fit/release arrangment. Alternatively the mounting wings on the side of the extruder base could be modified to interface with such an arrangement. Ill send you a PM regarding this.
Re: Flexidrive is Flex3Drive Early Birds May 09, 2016 10:00AM |
Re: Flexidrive is Flex3Drive Early Birds May 09, 2016 03:44PM |
Re: Flexidrive is Flex3Drive Early Birds May 24, 2016 05:13PM |
Re: Flexidrive is Flex3Drive Early Birds June 04, 2016 11:16AM |
Re: Flexidrive is Flex3Drive Early Birds June 21, 2016 03:13AM |
Re: Flexidrive is Flex3Drive Early Birds June 21, 2016 09:12AM |
Re: Flexidrive is Flex3Drive Early Birds June 29, 2016 12:26AM |
Re: Flexidrive is Flex3Drive Early Birds July 05, 2016 11:01AM |
Re: Flexidrive is Flex3Drive Early Birds August 06, 2016 06:25AM |
Re: Flexidrive is Flex3Drive Early Birds August 20, 2016 04:12AM |
Re: Flexidrive is Flex3Drive Early Birds August 20, 2016 07:09AM |
Re: Flexidrive is Flex3Drive Early Birds August 21, 2016 04:49PM |
Re: Flexidrive is Flex3Drive Early Birds September 22, 2016 12:48AM |
Re: Flexidrive is Flex3Drive Early Birds September 22, 2016 07:35AM |
