Re: New print surface material? January 31, 2017 10:05AM |
Re: New print surface material? February 20, 2017 06:29AM |
Re: New print surface material? February 20, 2017 07:14AM |
Re: New print surface material? February 20, 2017 09:12AM |
Re: New print surface material? February 21, 2017 01:08PM |
Re: New print surface material? February 21, 2017 02:55PM |
Re: New print surface material? February 24, 2017 06:14AM |
Re: New print surface material? February 24, 2017 09:34PM |
Re: New print surface material? February 25, 2017 03:51AM |
Re: New print surface material? February 25, 2017 05:58AM |
Re: New print surface material? February 25, 2017 10:23AM |
Re: New print surface material? February 25, 2017 11:03AM |
Re: New print surface material? February 25, 2017 09:20PM |
Re: New print surface material? February 25, 2017 11:40PM |
Re: New print surface material? February 26, 2017 02:36AM |
Re: New print surface material? February 26, 2017 03:39AM |
Re: New print surface material? February 26, 2017 07:10AM |
Re: New print surface material? February 26, 2017 10:20AM |
Re: New print surface material? February 26, 2017 01:51PM |
Re: New print surface material? February 26, 2017 06:25PM |
Re: New print surface material? February 26, 2017 06:36PM |
Re: New print surface material? February 28, 2017 10:20AM |
Re: New print surface material? February 28, 2017 01:35PM |
Re: New print surface material? February 28, 2017 02:40PM |
Re: New print surface material? February 28, 2017 06:55PM |
Mutley3D
Origamib - the post seems a little short on info.
Do you have a link to the specific item/file as there are a few shown in a search. And what material are you trying to use? I woldnt use a raft, nor even consider thinking about it, as this would be worse than a brim no?
I am not sure on the point you mention about "requiring maximum surface area". The footprint of a part is its footprint, and will stick on PrintBite surface. There is no claim that PrintBite can defy laws of physics or properties of molten plastic when it comes to overhangs. And does the item have to be printed in one go?
Ultimately I would advise getting your temp dialled into the specific material you are intent on using, for example when printing a benchy, the front lower bow section with steep overhang can be made to look perfect or imperfect with just a few degrees (ie <5) nozzle temp difference.
If you need to run fans, I would suggest using a skirt of say 20-30 lines, if you need to protect the heatbed from a cooling fan breeze. Also make sure your fans are optimal and directed at parts being printed instead of more inclined to the bed. Also try using a low speed on the fans. Cooling doesnt need a gale, just a light breeze, so be careful not to over cool.
Re: New print surface material? February 28, 2017 09:40PM |
Re: New print surface material? March 03, 2017 05:14AM |
Re: New print surface material? March 05, 2017 10:43AM |
Re: New print surface material? March 05, 2017 11:54AM |
Re: New print surface material? March 05, 2017 12:02PM |
