Re: Cloned titan extruder review/opinion... February 19, 2018 12:09PM |
MKSA
Could you test if their hobbed gear is really heat treated ? That is hardened and a hacksaw or a chinese file should not bite into it.
Re: Cloned titan extruder review/opinion... February 19, 2018 04:13PM |
whosrdaddy
MKSA
I have no intention to ruin my perfect working extruder
I don't know if it is hardened steel (it is certainly steel) and frankly I don't really care as long as it is doing it's job...
Re: Cloned titan extruder review/opinion... February 19, 2018 04:30PM |
Re: Cloned titan extruder review/opinion... February 19, 2018 05:03PM |
Re: Cloned titan extruder review/opinion... February 27, 2018 04:14AM |
Re: Cloned titan extruder review/opinion... February 27, 2018 04:30AM |
jinx
wondering how the standard fairs with a couple of spools of carbon filament.Quote
Dj
Testing it aside, why does a hobbed drive gear need to be hardened. Is mild steel not hard enough to bite into filament.
Re: Cloned titan extruder review/opinion... February 27, 2018 04:53AM |
, probably there is too much friction/pressure in the hotend and something is wrong elsewhere... e.g. low temp.|
Re: Cloned titan extruder review/opinion... February 27, 2018 04:57AM |
Re: Cloned titan extruder review/opinion... February 27, 2018 04:58AM |
hear what you sayin but replacing a titan hobbed gear gets pricey at £22 a pop " for a genuine". if carbon weren't so expensive I test it myself.Quote
Dj
Poorly perhaps but then something like a brass gear, such as used in a Mk8 is a cheap and easy to replace part. Its the argument for hardened nozzles, worth it if they perform as well, and are not massively more costly. Otherwise, a £3 brass nozzle replaced every other spool is a small ongoing cost.
Re: Cloned titan extruder review/opinion... February 27, 2018 07:12AM |
Re: Cloned titan extruder review/opinion... February 27, 2018 01:02PM |
Re: Cloned titan extruder review/opinion... February 27, 2018 02:24PM |
Re: Cloned titan extruder review/opinion... February 27, 2018 02:36PM |
Re: Cloned titan extruder review/opinion... February 27, 2018 02:54PM |
Re: Cloned titan extruder review/opinion... February 27, 2018 03:02PM |
Re: Cloned titan extruder review/opinion... February 27, 2018 06:51PM |
Re: Cloned titan extruder review/opinion... February 28, 2018 05:44PM |
Re: Cloned titan extruder review/opinion... March 01, 2018 02:21AM |
lookin good I strained an eye looking for the layersQuote
Dj
Stronger - no, stiffer - yes, does a good job of looking engineered and hiding the layer lines
, what layer height you testing with? I thought it would be stronger than the normal stuff, was thinking the whole point of carbon filaments was an increase in strength.... you taking snaps of the hobbed gear with each print we looking for that degradation or not, once the fleet finished.
Re: Cloned titan extruder review/opinion... March 01, 2018 08:27AM |
Re: Cloned titan extruder review/opinion... March 02, 2018 03:16AM |
Re: Cloned titan extruder review/opinion... March 02, 2018 04:05AM |
Re: Cloned titan extruder review/opinion... March 02, 2018 04:25AM |
Re: Cloned titan extruder review/opinion... March 02, 2018 04:28AM |
Re: Cloned titan extruder review/opinion... May 01, 2018 02:58PM |
Re: Cloned titan extruder review/opinion... May 03, 2018 01:38AM |
Re: Cloned titan extruder review/opinion... May 03, 2018 05:34AM |
Re: Cloned titan extruder review/opinion... May 15, 2018 10:13AM |
Re: Cloned titan extruder review/opinion... May 15, 2018 12:02PM |
Re: Cloned titan extruder review/opinion... May 16, 2018 02:37AM |
Re: Cloned titan extruder review/opinion... June 15, 2018 03:51AM |
