Re: Precision Piezo Z-probe Now available. May 27, 2020 01:33PM |
Re: Precision Piezo Z-probe Now available. May 27, 2020 01:34PM |
Re: Precision Piezo Z-probe Now available. May 27, 2020 02:01PM |
Re: Precision Piezo Z-probe Now available. May 28, 2020 09:06AM |
Re: Precision Piezo Z-probe Now available. May 28, 2020 01:22PM |
Re: Precision Piezo Z-probe Now available. May 31, 2020 03:11AM |
Moriquendi
You could put the piezo in series but there are some reasons why parallel is probably better; The wiring is simpler, you don't have to run a wire from one piezo to the other, just crimp the two piezos wires together at the connector. I'm going out on a limb here but, a piezo disk is a capacitor, if my understanding is correct the piezoelectric effect is a change in the capacitance of the ceramic due to applied strain (force). Adding capacitors in parallel adds their capacitance, adding them in series reduces the capacitance. If the change in capacitance and therefore the charge flow that we read is proportional to the total capacitance then by putting the disks in series we reduce the sensitivity, while by putting them in parallel we increase it. I'm not 100% confident of my reasoning here but I think I'm right, at least in part.
Idris
Re: Precision Piezo Z-probe Now available. May 31, 2020 06:09AM |
Re: Precision Piezo Z-probe Now available. May 31, 2020 05:47PM |
and to make it worse, my understanding of physics is horrible.|
Re: Precision Piezo Z-probe Now available. May 31, 2020 07:10PM |
Re: Precision Piezo Z-probe Now available. June 01, 2020 04:53AM |
Re: Precision Piezo Z-probe Now available. June 01, 2020 06:57PM |
Re: Precision Piezo Z-probe Now available. June 02, 2020 04:01AM |
sgali
Maybe my question boils down to that one: what does your gut-feeling tell you: what setup, series or parallel, is the most promising to start with? (I plan to use un-drilled 20mm piezos).
So I shall enter the holy war to free the path to the Garden of Eden one way or another.
Re: Precision Piezo Z-probe Now available. June 02, 2020 06:05AM |
A comical prototype that works proves that an idea is possible and not so dumb - although it may still not be practical
Re: Precision Piezo Z-probe Now available. June 02, 2020 08:42AM |
Re: Precision Piezo Z-probe Now available. June 02, 2020 09:04AM |
Re: Precision Piezo Z-probe Now available. June 14, 2020 07:48AM |
Re: Precision Piezo Z-probe Now available. June 25, 2020 02:31PM |
Re: Precision Piezo Z-probe Now available. June 28, 2020 02:18PM |
Re: Precision Piezo Z-probe Now available. July 01, 2020 06:31AM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: Precision Piezo Z-probe Now available. July 03, 2020 05:16AM |
Re: Precision Piezo Z-probe Now available. July 03, 2020 03:47PM |
Re: Precision Piezo Z-probe Now available. July 04, 2020 05:28AM |
Re: Precision Piezo Z-probe Now available. July 04, 2020 11:14AM |
leadinglights
The compliance is not enough to be called loose. There is an old posting at [reprap.org] where I measured the deflection with a 500 gram load and got less than 40 microns. That is for a single cell and includes a little compliance for the mounting. As you will be sharing your load between 3 piezos with a simpler mounting I think the figure at the piezos will be closer to 20 microns per kilogram on the bed.
Mike
Re: Precision Piezo Z-probe Now available. July 04, 2020 01:44PM |
Re: Precision Piezo Z-probe Now available. July 04, 2020 03:32PM |
Moriquendi
I'm really not making any more of the Piezo20 boards, not unless you want to special order a large number. The Piezo20 PCB was designed for a single product using a technique that I can no-longer support, drilling holes in piezo disks. The Universal PCB does everything you need to run a system like the Piezo20 but is also easy to use for underbed sensing, unlike the Piezo20 PCB. The mounting hole is designed to be easily removable, or, you can mount board a little further away.
The functionality of the Piezo20, a compact, hotend mounted probe, has been replaced by the Orion.
Yes, everything that's sold in my shop is in stock and ships within 2-3 days. Shipping can be affected a little by the pandemic but not badly, depending destination only a few extra days.
I currently have no plans to release a new version of the Universal PCB
Idris
Re: Precision Piezo Z-probe Now available. July 05, 2020 08:53AM |
Moriquendi
I'm really not making any more of the Piezo20 boards ...
Re: Precision Piezo Z-probe Now available. July 05, 2020 03:32PM |
Re: Precision Piezo Z-probe Now available. July 05, 2020 04:03PM |
Moriquendi
Idris
Re: Precision Piezo Z-probe Now available. July 05, 2020 04:58PM |
