Re: LISA Simpson January 03, 2014 06:19PM |
Re: LISA Simpson January 03, 2014 09:46PM |
uncle_bob
Scale up question:
The central axis of the machine is a hollow plastic shaft that's printed as part of hub_bottom. The shaft appears to be 15mm in diameter. I'm *guessing* that scaling up that shaft diameter would be a good idea on a 2X larger printer. 25 mm and 30 mm seem like pretty good candidates for a scale up from the standpoint of bearings to replace the 15mm 6702's.
So now the questions:
Is the shaft dimensioned based on the need to mount the hot end on the bottom or is it critical? (Do I need to scale it or not?)
If I need to scale it, is 1.5X (25mm) good enough or is 2X (30mm) the way to go?
Yes, I could go to something completely different. I'd prefer to go in as few directions at once as possible. The more I can retain from the original the better. At this point scaling is ok. Machining a different design from a solid block of tool steel - not so much.
Re: LISA Simpson January 03, 2014 10:17PM |
Re: LISA Simpson January 03, 2014 11:31PM |
Re: LISA Simpson January 03, 2014 11:58PM |
uncle_bob
I assume the idea is to more or less crush fit the bearings on the pipe (17 mm bearing ID and 17.14 mm pipe OD)
uncle_bob
what's a good cheap / easy bearing for the 1/4 IP stuff at 0.540" (13.716 mm) ? R10 or 1633 maybe?
nicholas.seward
I am talking about a printer that can print a very roomy tent.
Re: LISA Simpson January 04, 2014 12:09AM |
Re: LISA Simpson January 04, 2014 01:26AM |
Re: LISA Simpson January 04, 2014 03:09AM |
nicholas.seward
I would print with a two part quick expanding foam.
Re: LISA Simpson January 04, 2014 03:13AM |
Re: LISA Simpson January 04, 2014 01:31PM |
Re: LISA Simpson January 04, 2014 01:56PM |
A2
I think it might be a better practice to heat the surface of the plastic,
don't heat the precision lead screw, it could warp or loose it's temper, (if you're not careful with the heat).
Re: LISA Simpson January 04, 2014 02:12PM |
Re: LISA Simpson January 04, 2014 02:16PM |
Re: LISA Simpson January 04, 2014 02:25PM |
Re: LISA Simpson January 04, 2014 03:26PM |
Re: LISA Simpson January 04, 2014 04:21PM |
Re: LISA Simpson January 04, 2014 05:15PM |
Re: LISA Simpson January 04, 2014 05:17PM |
Re: LISA Simpson January 04, 2014 05:59PM |
Re: LISA Simpson January 04, 2014 06:01PM |
Re: LISA Simpson January 04, 2014 06:07PM |
Re: LISA Simpson January 04, 2014 06:11PM |
Re: LISA Simpson January 04, 2014 06:20PM |
Re: LISA Simpson January 04, 2014 09:18PM |
jason.fisher
Would an L-shaped piece be preferable over a tube? You could line it up so the rod is partially inside of the L? Maybe like a one-piece steel bed framing piece?
Re: LISA Simpson January 04, 2014 09:50PM |
Re: LISA Simpson January 04, 2014 10:04PM |
Re: LISA Simpson January 04, 2014 11:48PM |
Re: LISA Simpson January 05, 2014 04:12PM |
Re: LISA Simpson January 05, 2014 10:34PM |
Re: LISA Simpson January 06, 2014 04:47AM |
