Cherry Pi III Is Available
Posted by AndyCart
Re: Cherry Pi III Is Available
February 02, 2015 06:00AM
Thanks Andy.
I have never got on with Pronterface to be honest, I remember having issues with it and my Ormerod. Once I switched to Daves firmware and the web interface, I never looked back.
I will maybe give Cura/Repetier Host a try and at some point down the road I may look at doing a custom web interface for the Smoothieboard.
As for the CP, it's at least printing, just needs some more tweaking.
(I did find another stupid error that I had made, and I probably shouldn't admit this, but I had assembled the mini v wheels incorrectly, I hadn't put the washer between the two bearings so they were binding when tightened. eye popping smiley Now it's running smoother and quieter. winking smiley)
Regards,
Les
Pointy's Things
Pointy's Blog
February 02, 2015 06:39AM
Pointy
Thanks Andy.
Regards,
Les
Oops but easy mistake to make as there is no instructions with them (I had just assembled a Shapeoko2 CNC Router that uses Grooved V Wheels and they assemble in the same way and there is instructions for them)
I have decided that I think my rods are a little short (And definitely not all the same length Think one at least had the Ball sit a little proud so is longer and throws the effector of at extremes.)
February 02, 2015 07:26AM
I did a very similar same thing when I first started using them. I bought just the delrin wheel from OpenBuilds as I had the bearings in stock. I tried to use a normal washer. It didn't work! I ended up buying the correct shim and spacer and all was well but it ended up costing me more than buying the kit in the first place due to shipping and customs costs. We live and learn! Glad you sorted it out.
I've just uploaded Rich Cattell's new 'testing' version of Marlin into one of my Cherry Pi builds. I took advantage of the fact that I now use an all metal hotend and a Mk3 aluminium build plate. I made a lead from a couple of croc clips. Clipped one to the hot end and one to the bed and the other ends went to the Z Min connector on my RAMPS. When the nozzle touches the bed the 'switch' closes. I successfully ran Rich's G30 A auto calibration routine and it was spot on.
I'm a great believer in the fact that once a delta is properly calibrated it shouldn't need auto bed leveling routines. Just the odd tweak to the Z height using M666 H should be all that's required.
It's saved me an hour or so of manual calibration too!
Andy
February 02, 2015 07:32AM
Hi Andy what all metal hotend do you use and do you have a modified holder for it .
February 02, 2015 09:29AM
AndyCart
Andy
Andy
Did you know that OOZnest have the Openbuilds wheels in stock in the UK at £3 ea?
February 02, 2015 10:29AM
Smoothieware presents the on-board SD card as a USB drive over the printer's USB cable. You can save the sliced file from Cura or your slicer du jour directly to the printer's SD card, open Pronterface (or any other host program), and type "@play /sd/sliced-file.gcode" to kick off the print. (Pronterface requires the "@" sign to run Smoothie commands, other host programs do not.)
Given the ease of printing via SD card with Smoothieware (ie: not even needing to swap cards), there is no reason to be using Pronterface, Repetier, or any other host program to print .gcode files other than if you do not have an LCD and want to see the printing status.....
February 02, 2015 01:50PM
mrorange26
I use this hotend [www.aliexpress.com]
and this heated bed [www.aliexpress.com]
I'm very pleased with both of them
February 02, 2015 01:52PM
Will that fit on the standard cherry pi lll mount.
February 02, 2015 01:56PM
mrorange26
I've attached the .stl files for the new effector
EffectorForAllMetalHotEndV2.stl
E3DMountCapV2.stl
E3DMountBaseV2.stl
Andy
February 02, 2015 01:58PM
mrorange26
The new effector is a drop in replacement for the Cherry Pi IIIS effector (the string and spring version)
Andy
February 02, 2015 01:59PM
dougal1957
Andy
I didn't but I'll check them out. Thank you.
February 02, 2015 02:00PM
What do you use to attach the fan to it.
February 02, 2015 02:02PM
Also can you post a picture of it completely setup thanks.
February 02, 2015 02:07PM
mrorange26
Here it is :-
February 02, 2015 02:09PM
I will have to get some alu tube aswell then.
February 02, 2015 02:15PM
You will need three lengths of 6mm OD tube 30mm in length, 3 x M3 50mm screws and 3 x M3 nuts. You can get the tube on the screws and fixings isle in B&Q. It's about £3.00 for a 1M length.
Edited 1 time(s). Last edit at 02/02/2015 02:16PM by AndyCart.
February 02, 2015 02:24PM
Thanks how did you mount the fan to it.
nka
February 02, 2015 03:05PM
small dot of super glue
- Sebastien Plante (nka)
February 02, 2015 03:08PM
Lol.
February 02, 2015 03:19PM
First part done.Bits ordered.
open | download - 2015-02-02 20.01.09.jpg (519.6 KB)
February 02, 2015 04:43PM
nka
CA glue has historically been the secret sauce that holds the CP together..... grinning smiley
February 03, 2015 10:14AM
AndyCart
What's the diameter of that heated bed Andy?
Regards,
Les
Pointy's Things
Pointy's Blog
February 03, 2015 05:25PM
Pointy
AndyCart
Regards,
Les
It's 220mm. It's good for PLA. Gets upto 60 or 70 quite quickly. I think you would need to run it at 24V for ABS. It only draws 4 to 5A at 12V (60W)
February 03, 2015 06:22PM
Do you need a fan for the alu fins and also a separate one to blow onto the plastic as it comes out.
February 04, 2015 05:50AM
ABS Help
Has anybody managed to print ABS with their cherry pi. I want to print the new all metal hot end mount and appear to be having issues with layers being a little bitty. I was wondering if people had used ABS and if so what there print settings might be.
I have tried temp at 240, bed 110 with the fan off but the layers don't appear very even.
Thanks
Matt
February 04, 2015 06:19AM
I printed 210c pla 80% infill 0.2 mm .came out fine.if you pm me email I can send you a picture of it.
February 04, 2015 06:38AM
Matt,Wheatley
ABS Help
Thanks
Matt
Matt
Where are you I may be able to help you with some.?
Abs temps depend on the filament that you are using I normally print at 235 110 onto clean Kapton Tape (Cleaned with acetone) this however is not on a cherry pi I am still building my Larger slice of Pi.
A lot can also depend on the Hotend as well.
Doug
February 04, 2015 07:15AM
mrorange26
You definitely need a fan to cool the cold side of the hotend. My design doesn't allow for a part cooling fan but if you look further up the posts (Page 12) you will see a picture of 'Adalina the Singing Dragon' that I printed in PLA with this setup. Came out great.
Edited 1 time(s). Last edit at 02/04/2015 07:18AM by AndyCart.
February 04, 2015 09:28AM
I print with ABS on mine. I have an E3D Mk6 all-metal hotend, and as Andy said, I keep the little hotend fan running all the time. I have slic3r make a 4mm brim to help hold it down, and use hairspray on glass as a print surface.
My temps are usually 90 degrees for the bed, 260 for the hotend.
I still use the print cooling fan as needed, but typically turn it way down since it's not as necessary as with PLA.
February 04, 2015 09:51AM
So will have to run another pair of cables for the all metal hot end as currently my fan goes on and off
